Old 11-26-2017, 02:44 AM   #1
Dacfrs
Drives: Reddy Whip
Suspension issue?
Okay, going down the interstate, truck blows tire, pipe falls off truck into road, I manage to get my FRS down to about 65mph, before I got no where else to go, and run over the pipe. Both driver side tires blow out, I pull over, call AAA, get new tires and continue my trip. Only now, something is not quite right, traction control comes on in corners now where it did not before. Car feels loose, basically as if the entire rear end is loosely mounted, feels like it wants to swap ends. Toyota dealer says they see nothing wrong, technician drove the car said he didn't notice anything odd, but I believe he doesn't know the capabilities of the car, so I don't think he put it through it's paces, so to speak... New tires were installed on the front...I've swapped them around, same thing. Struts appear to be ok, no leaks, no funny noises. Any suggestions?
Dacfrs is offline   Reply With Quote
Old 11-26-2017, 02:49 AM   #2
I'd suggest you take your car into a good alignment shop for an alignment and a complete suspension inspection.
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Racecomp Engineering (11-27-2017), Spuds (11-26-2017), strat61caster (11-26-2017)
Old 11-26-2017, 03:41 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Are the new tires installed one on the front and one on the rear? If so then that's your issue.
I would put the new pair of tires on the rear and the old set up front.
Strange as it seems but out LSD does not take to kindly for one new tire and one old.
Old 11-26-2017, 03:59 AM   #4
OP stated " New tires were installed on the front."
Gonna hafta slow down your speed readen, there Mr.ac ...... you're not as young as you used to be ......
Old 11-26-2017, 07:28 PM   #5
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Well, blame my readers they seem to only select the words that would cause a tiffy
As to the new info.... well, I would recommend you read the manual and put new tires on the back and used ones up front. Wait... that's what I said in the first place dam it humfrz
Old 11-26-2017, 07:41 PM   #6
Welp, Mr .ac , you're getten it more right.
I suggest you ditch those readers you got off the rack at Walmart and get some good ones off the rack at Walgreens.
Old 11-27-2017, 10:51 AM   #7
Icecreamtruk
Drives: Track preped NA FRS
Rear wanting to swap ends means when it wasnt doing it before means you have toe-out on 1 of the rear tires. I tapped a wall while doing a time attack event with my rear driver side rim and it got me an instant -0.25 toe there when there was 0 before. The car was soo loose at turn in after that. Like everyone else said, take it to an alignment shop and it should be a quick fix. Toe in the rear is just an excentric bolt so it can slip out of position without a big hit.
Icecreamtruk is offline   Reply With Quote
Old 12-08-2017, 10:14 PM   #8
speedyspaghetti
speedyspaghetti's Avatar
Drives: 2016 FR-S
Any luck on finding a solution? I have had a similar "loose" feeling recently develop.
speedyspaghetti is offline   Reply With Quote
Old 12-08-2017, 10:25 PM   #9
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I'm going to quote the first (and only) suggestion you need:
humfrz (12-09-2017)
Need Help with Suspension Issue Silverfox Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-04-2017 01:44 PM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 06:06 PM
Tein Street Flex suspension issue (lowering itself over time) Sportsguy83 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 64 07-26-2015 06:00 PM
Suspension Question/Issue slmducf20 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 05-04-2015 11:45 PM
Need help fast - suspension issue during spring install finch1750 Scion FR-S / Toyota 86 GT86 General Forum 5 07-08-2013 04:30 PM
