Old 07-06-2012, 04:51 PM   #267
csaba
Drives: scion tc
Originally Posted by Marrk View Post
What can I say? You know I like how girls smell.
I picked it up right away...... your comment lol
They have to smell good. ....lol
csaba is offline   Reply With Quote
Old 07-06-2012, 04:59 PM   #268
csaba
Drives: scion tc
Originally Posted by gt86init View Post
just a lil over 100 miles and heard it last night while warming up the car.. i didnt hear it at first not until the temp gauge needle reached the first bar and i started hearing the chirping sound.. ;( so my concern is...
does this affect the performance of the motor? could it be possibly hurting the motor or maybe running lean because of the lack of lubrication on fuel system?
Its actually adds 25 more horses.
So don't worry about it
Old 07-06-2012, 05:19 PM   #269
gt86init
yoimlevinit
Drives: gt86
Question
Word
gt86init is offline   Reply With Quote
Old 07-06-2012, 10:13 PM   #270
sierra
Drives: Skoda Yeti DSG diesel 4x4
So how is the car sounds now are you happy with the fix?
Is it sounds like when it was new
Thank you
Csaba,
The part in heavy print was copied from another forum, not sure I could find it again? So it's not my car, my 86 is on order.
I posted it here, i'm in Oz, because it seemed to be the problem and made sense. If it is the problem then a bit of 2 stroke oil in the fuel might fix the noise until they modify the pump for your fuel. Not 1-20 or 1-50 as in a 2 stroke, just a light amount of say 1-500 might shut it up.
1-200 makes a diesel run much quieter, with better power and economy.
After all, 2T oil is a lubricant designed to be added to gasoline and there isn't enough lubricant in the US fuel.
sierra is offline   Reply With Quote
Old 07-06-2012, 10:20 PM   #271
sierra
Here's the link.
http://www.fr-sforum.com/forums/fr-s...-problems.html
FRS direct injection fule pump problems.
Just wanted to give you all a heads up. I had to replace this pump today due to the fact it was making a loud chriping noise almost like a wet drive belt. The toyota reps came out to my work and listened to it. It only happens once the temp gets to around 140f. They explained it to me as follows. The pump has a washer inside of it which if not lubercated properly it will make that noise. They said that Japan gas is way better and has more lub in it the USA gas. SO the usa gas casued the washer to not be lubed properly. There is no known fix or TSB for this. i got a new pump but keep your ears open so you can catch it and report it. Its not a preformance issue jsut an annoying sound thats all. Hope this helps.
Old 07-06-2012, 10:24 PM   #272
csaba
Drives: scion tc
Originally Posted by sierra View Post
Csaba,
Thank very much for your reply , its OK. Don't worry finding it,
I don't have the car yet but I'm all over it ,I do like to buy one soon, and reading a lot on this forum , and see how people like it and if there any issues .
I do hope they find the solution to the few problems.
Thanks again.
I just see you did thanks
Old 07-11-2012, 06:13 PM   #273
taosracer
Frickin' Genius
taosracer's Avatar
Drives: GBS BRZ 6sp, 2002 ts wagon WRX swap
I have an update on this issue. I received a call on Mon. A.M. from a rep with SNE asking about the noise, and the attempted repair with the idler pulley. He asked for a video clip to be submitted to the service dept. so that a E-QMR could be started, with video (and audio) attached.
Un-frickin-believably, my car hasn't chirped at all this week. It was quite a consistent noise since day one. Only thing I can cite as a change is that I bought fuel from Shell station this weekend (V-power 93oct) which I don't usually. I'm also racking up some mileage (at 3550 right now)
I will update when (or if) the crickets start chirping again.
Anybody else had the noise conspicuously go away ??
Cullen
I hear on occasion, people say that they are bored...wrong answer....An engine can be bored, a person would more correctly state that they are boring.
taosracer is offline   Reply With Quote
Old 07-11-2012, 06:15 PM   #274
Fenrir
Drives: Mazdaspeed 3
Need to drive the car (reasonably spirited) and get it up to temp. Mine never makes the noise until after 15-20 minutes of aggressive driving.
Fenrir is offline   Reply With Quote
Old 07-11-2012, 09:51 PM   #275
Hanzo
Hanzo's Avatar
Drives: Waiting for the ND Miata
We have been speculating different fuel from different gas station makes a difference. I've been using Shell 93 V power since I got the car and mine still makes noise. I do know different region of the country have different fuel additives from the same company.
Hanzo is offline   Reply With Quote
Old 07-11-2012, 09:55 PM   #276
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
Are u saying that after changing the idler pulley the chirping noise went away?
imravenit is offline   Reply With Quote
Old 07-11-2012, 10:11 PM   #277
taosracer
Frickin' Genius
taosracer's Avatar
No, that was a fail Guess you'd have to go back a few pages in this thread to know that.
Cullen
Old 07-13-2012, 11:34 AM   #278
solution
solution's Avatar
Drives: Scion FRS
Mine does this too once the engine warms up! Rather Annoying but I can wait till they make a fix as long as its not causing problems with anything else.
**Problem Solved** Flux Capacitor was replaced no more Chrip.
(Sorry just had to with all the speculation going on lol)
solution is offline   Reply With Quote
Old 07-13-2012, 11:40 AM   #279
Filipino Royale
Got Rice?
Filipino Royale's Avatar
Drives: 37J BRZ-L
Same thing shell vpower 93. Since day 1. I hope this can resolve soon.
Be a Leader, Be a Friend, Be at Service. -AɸΩ
Filipino Royale is offline   Reply With Quote
Old 07-13-2012, 12:01 PM   #280
drew935
Auto Salon Works
drew935's Avatar
Drives: wrb
Interesting and at least a fix with 93...my EJ20T doesn't sound like that
drew935 is offline   Reply With Quote
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 09:57 PM
Idle issue? yayforaddison Issues | Warranty | Recalls / TSB 891 07-14-2016 10:42 AM
What function can it be used for, the idle button place yuli8466 Cosmetic Modification (Interior/Exterior/Lighting) 50 01-29-2013 03:17 PM
Idle issue poll/role call Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 8 06-13-2012 12:00 PM
Scion goes normal terrypm Other Vehicles & General Automotive Discussions 21 05-02-2012 10:16 AM
