Old 10-20-2017, 06:36 AM   #1
Keenercarguy
Mountain Runner
Keenercarguy's Avatar
Drives: 2013 Subaru BRZ Limited 6MT
P0351 CEL DIY????
My 2013 BRZ now has about 80,000 miles and I'm getting a CEL for the ignition coil in cylinder 1. I intend to replace the coil myself but I CAN'T FIND ANY SORT OF DIY. I know it must exist but I'm just getting search results discussing the CEL and no concrete guides. Someone please link me? Thanks
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
Keenercarguy is offline   Reply With Quote
Old 10-20-2017, 06:38 AM   #2
Merlinop2000
Drives: Brz
You don’t really need a diy cylinder 1 is the passanger front so u have to take the injector ecu and fuel rail cover off to get to it. It’s really tight and frustrating but other than that is like a normal coil change
Merlinop2000 is offline   Reply With Quote
The Following User Says Thank You to Merlinop2000 For This Useful Post:
Keenercarguy (10-20-2017)
Old 10-20-2017, 07:55 AM   #3
steve99
Drives: FT86
http://www.ft86club.com/forums/showthread.php?t=88906
Old 10-20-2017, 09:46 AM   #4
Icecreamtruk
Drives: Track preped NA FRS
https://www.pointmeby.com/2017/09/10...-pack-how-fix/
Knock yourself out, be patient, its a hard to reach place, but tell yourself that it is still the easiest to reach coilpack (driver side is literal hell).
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Old 10-20-2017, 06:20 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
1. Open Hood
2. Right front of car, unbolt sound tube and ECU as pictured in the above DIY
3. Reach down to the side of the engine, feel around for the black plastic thing that sits on spark plug you might be able to see it a little bit, you want the one near the front of the car, unclip harness by pushing on the tab you cannot see, use a 10mm to undo the bolt holding the coilpack, don't drop the bolt, pull on the coil pack should pop right off.
4. Reverse #3 then #2 then #1
If you've ever changed spark plugs it should be rather straightforward except it's harder to reach and see.
ineedyourdiddly
Old 10-24-2017, 01:00 AM   #6
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Bro, I just changed mine out on Saturday, there is a video on YouTube about 4 minutes long that shows you what you need to remove on both sides, watch it.
Dr. BRZ is offline   Reply With Quote
CEL P0351 Ignition Coil A Exrald Issues | Warranty | Recalls / TSB 16 03-23-2017 11:09 PM
P0351 bad spark plug... Jaden Engine, Exhaust, Transmission 3 01-02-2016 10:19 AM
P0351 and out of warranty PrDarkKnight Issues | Warranty | Recalls / TSB 5 08-03-2015 10:09 PM
the infamous P0351 sickmint79 Tracking / Autocross / HPDE / Drifting 2 05-20-2015 06:28 PM
P0351 NickDC88 Issues | Warranty | Recalls / TSB 1 02-15-2015 11:33 PM
