| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Scion FR-S
Check engine light
I got a check engine light and idk how to get rid of it or what it is ? Has anyone had the same problem and how did you fix it ! Thank you
![]() ![]() Sent from my iPhone using Tapatalk |
#2 |
Drives: Raven FR-S 6M
Google says it's your ambient air temp sensor malfunctioning. This isn't going to affect anything other than climate controls.
“The World is Flat”
[||•]=(86)=[•||] |
| The Following User Says Thank You to Apoc For This Useful Post: | H214M (09-17-2017) |
#3 |
Drives: Scion FR-S
#4 |
Well, to state the obvious, replace the sensor.
Since this doesn't really impact anything of consequence you could also clear the code and see if it comes back in case its a transient thing.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | humfrz (09-17-2017) |
#5 | |
![]() Sometimes when you clear a code with a OBD tool, it will come back, but by unhooking the battery, it will stay away ...... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Dadhawk (09-18-2017) |
#6 | |
Not sure an ambient temp sensor would have constant power, but certainly couldn't hurt.
| The Following User Says Thank You to Dadhawk For This Useful Post: | humfrz (09-18-2017) |
#7 |
Drives: FT86
If it the sensor is bad the dash display of outside temperature should not work.
| Check Engine light and Traction Control Light | JeRM | Issues | Warranty | Recalls / TSB | 25 | 06-02-2023 09:00 PM |
| Help! From check engine light to fouled plugs back to check engine + plugs refouling | larchamb | Issues | Warranty | Recalls / TSB | 44 | 04-03-2016 09:39 AM |
| Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? | djdrugga24 | Issues | Warranty | Recalls / TSB | 3 | 06-25-2014 06:06 AM |
| Will I get a check engine light on if the engine bay has a direct injection failure? | Astroboy | Engine, Exhaust, Transmission | 7 | 03-29-2014 06:16 PM |
| Engine sputtering while idling with check engine light flashing, WTF | speedy racer | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-27-2012 06:50 AM |
