Old 11-10-2012, 01:15 PM   #141
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by ultra View Post
Tried Hawk HP+ on my car and found that they wprked well on track but were very grabby, dusty, noisy and ate rotors on the street.
Based on that, IMO for a dual use pad, rotor friendliness is a critical thing to look at.
Ferodo DS2500s all around seem to be an interesting option...but impossibke to find rears for my lower-spec car which uses 2008 WRX rear calipers.
the Endless MX72s (on the Essex site) also look promising but unsure about availability for OEM calipers.
Open to suggestions...!
I'm going to try the AP S100's when i do my brakes in the spring, not sure if they have a rear for that fitment either though. What about Project Mu?
I haven't seen anybody running EBC either, i guess there is a reason for that.
Old 11-12-2012, 09:26 AM   #142
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Originally Posted by ft_sjo View Post
Hi there. Could you confirm if the part numbers i've got here of FCP1639 and FCP4187 are correct for DS2500's?
Yes, those are the correct part numbers front and rear.
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
The Following User Says Thank You to JRitt For This Useful Post:
ft_sjo (11-12-2012)
Old 11-12-2012, 09:37 AM   #143
JRitt
JRitt's Avatar
Originally Posted by ironchef View Post
I would agree in normal circumstances, but are the rears going to be a limited production run? Based on a lot of comments in this thread, the Ferodos are really highly rated and many people seem anxious to get them. Why wouldn't they produce them in high quantities?
Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
On the front vs. rear price issue...this is fairly common with larger pad manufacturers. They buy the components to make their various pads from different sources. A lot of times it comes down to backing plates. They may be the OEM pad supplier on a model that sells 100,000 cars per year. In that case, backing plates are likely cheap and cheerful. If they are only going to sell a few hundred sets per year, that is a far different situation. It may be difficult for them to even have a backing plate manufacturer make the plates! In that case, they may have to custom laser cut or water jet cut backing plates from other existing shapes.
"High quantities" is a relative term. Our idea of a high volume is likely far different from their idea of a high volume.
Also, because the volumes are far lower, production for racing pads is sometimes done in a special "race shop," rather than the main production line. They require special handling and higher production costs.
For all of these reasons, costs can sometimes be higher for a new shape, or a rear vs. a front, etc. It all boils down to their cost, which they have to cover and make their target profit. It's a completely variable cost, based on a long list of items.
On the FT86, the fronts were already a common shape currently being produced by most pad manufacturers. That made it easy. The rear however, was more rare.
www.essexparts.com
Old 11-13-2012, 03:34 PM   #144
JRitt
JRitt's Avatar
Ultra,
I checked on this for you. The CL Brakes RC5+ would probably be a good choice for you as a dual-use pad. We can get them in the standard OEM FT86 front, and the 2008 WRX rear shape.
They will make a little noise on the street, but they can take a solid beat-down. About a third of the way down this page you can see them on track in a fast Lancer Evo.
If you wanted to take a step further towards more track-oriented, the CL Brakes RC6E compound is an option. We have that compound in both shapes as well. They would be tougher on discs and noisier though.
As you said, Endless MX72 is an option as well. They would possibly be a little easier on discs when driven cold on the street. I talked to Endless, and they gave me the part#'s for the lower spec FT86 brake pad shapes (the RA model):
Front pads: EP386
Rear pads: EP418
On the higher spec model (standard in the USA):
Endless front: EP386 (same as RA model)
Endless rear: EP472
So...another confirmation that the front caliper pad shape is the same on all FT86 models...just the rears are a bit different.
Let us know if we can help.:happy0180:
www.essexparts.com
The Following 2 Users Say Thank You to JRitt For This Useful Post:
GT86_PRAGUE (05-19-2015), ultra (11-13-2012)
Old 11-16-2012, 11:52 PM   #145
james23
Drives: Automatic car
I use Carbotech XP8 as it is good for racing compounds. It is Good initial bite at race temperatures, high coefficient of friction, excellent modulation and release characteristics. Very high fade resistance and very rotor friendly. Excellent as a front brake pad for lighter applications. It is Perfect for track day use with any tire and can still be driven safely to and from the track. But a problem of noise I have to face.
james23 is offline   Reply With Quote
Old 11-18-2012, 06:02 AM   #146
ASSALBERT
ASSALBERT's Avatar
Drives: DC5
Originally Posted by JRitt View Post
Ultra,
Front pads: EP386
Rear pads: EP418
Endless rear: EP472
Jeff, I am thinking about trying the RC5+ compound but was wondering what other pads on the market these would compare to? Also, considering these pads are sintered, will there be an issue of the brake dust corroding/welding itself onto my wheels?
ASSALBERT is offline   Reply With Quote
Old 08-20-2017, 02:05 PM   #147
LudwigMiles
Drives: '13 BRZ
I need new pads (and maybe rotors).
I am fine with stock pads.
I might do one track day a year, so this is just for DD use.
I don't really want race pads or any performance upgrade.
Do you guys buy basic parts stuff at the dealer?
For my other cars, I never buy parts at the dealer. (ripoff)
I also don't buy parts from auto parts stores (Duralast, etc)
Instead, I buy from online vendors like FCPEuro that sell OE branded parts like Sachs, Lemforder, Mahle, Seimens/VDO, etc.
Is there something like that for Subaru?
LudwigMiles is offline   Reply With Quote
Old 08-20-2017, 03:26 PM   #148
Teseo
Drives: frs
Watch "Toyota 86 Brake Upgrade Install" on YouTube
Old 08-21-2017, 01:02 AM   #149
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
If you have questions regarding brake pads, we have one of the most extensive backgrounds in testing and working with a variety of brake pad manufacturers and applications. Depending on what your car is setup with and how it will be used is a more important aspect of what to choose for your application. Thanks!
CounterSpace Garage is offline   Reply With Quote
Old 08-21-2017, 01:41 AM   #150
Dawan
Le Ingenieur
Dawan's Avatar
Drives: 2015 Subaru BRZ Aozora
I am using Project Mu HC800s, while I like the bite of the pads, I seem to go through them way too quickly. In 3-4 track days or so, the pads will be cooked and have very little material left. (Im on oem brakes) Is there a recommendation on longer lasting pads that I can daily as well?
Dawan is offline   Reply With Quote
Old 08-21-2017, 10:27 AM   #151
Icecreamtruk
Drives: Track preped NA FRS
I have only tried Hawk pads well enough (easy, cheap and fast to get around here). The DTC-60, while its a race pad, can be used daily, it will be a bit harder on rotors, but rotors should still last you as much as pads (cheap blanks, nothing fancy). My DTC-60s can do 5-8 track days depending on the tracks Im doing before they get too thin for my liking, then I keep them as "spare" pads. I just did another 2 days on a "spare" set before they got to the metal backing plate, so to be safe I'd say 6-9 track days, averaging 2 hours of track each day, + a couple of months of daily.
I wouldnt recommend hybrid pads (DTC-30 or Street/Race for example), because while they might work, they last a lot less than race pads when used on track.
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Dawan (08-21-2017)
Old 08-21-2017, 11:59 AM   #152
LudwigMiles
Drives: '13 BRZ
Thanks. That was a nicely produced video.
But, I'm not looking to do upgrades, and just want OEM equiv.
Looks like Amazon is an option.
They sell Wagner, ACDelco, Akebono, and Centric. (And Hawk)
I believe all are reputable brands.
RockAuto sells Centric, Raybestos, Wagner, ACDelco, PowerStop, etc.
The point is, there seems to be non-dealer options.
Old 08-21-2017, 12:12 PM   #153
Dawan
Le Ingenieur
Dawan's Avatar
Do they squeal like crazy? I have friends on that type of caliber of pad, Endless ME22/20 and the ME20s squeal like crazy on the street basically no matter how much brakes have been applied. I can handle minor squeal at low to medium brake pressure like the HC800s on the street.
Old 08-21-2017, 12:21 PM   #154
Icecreamtruk
It depends. Right after a track day, they dont squeal at all. But as you use them on the street the become louder as the days pass. After two weeks, they are on full blast mode. The squeal is mainly with light/moderate pressure, but applying hard pressure to make them quiet might have the side effect of people ramming into you and your face meeting the wheel, as they bite quite hard, even when cold.
Brake cooling duct kit tranzformer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-14-2011 01:37 PM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 03:53 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 10:28 AM
Brake override system in the FT-86? mrKiKaZ Scion FR-S / Toyota 86 GT86 General Forum 10 02-22-2010 11:33 AM
