Old 08-12-2017, 05:02 PM   #1
RedFRS4me
RedFRS4me's Avatar
Drives: Firestorm '13
OFT VVT Intake/Exhaust readings
Hey guys,
I recently had new cam sprocket and ecu replacements due to a p0018 cel a few months back. So far no engine check lights and its been running normal. I decide to go and check how its holding up and noticed that my VVT intake readings are all over the place anywhere from 0 degrees to over 100 degrees. What can be causing these fluctuating readings? Is it going to harm the engine with these bad readings? My VVT exhaust angles look good. They were fixed after the repairs. Somehow now my intake is screwy.
Please help!
Thanks!
'13 Firestorm
RedFRS4me is offline   Reply With Quote
Old 08-12-2017, 06:35 PM   #2
steve99
Drives: FT86
Originally Posted by RedFRS4me View Post
Hey guys,
Please help!
Thanks!
It possible its an oft channel logging issue, if the vvt cam sensor reading were that far off and erratic you would expect drivability isues and cel codes, maybe try logging same parameters on another car with same ecu calid as logging is specific ram addresses for each ecu calid
Old 08-13-2017, 07:54 AM   #3
makinen
makinen's Avatar
Drives: Toyota 86
My A01E Calid ecu has a same issue with OFT.
I reported it to Shiv on March, but not fixed on August yet.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 08-15-2017, 12:51 AM   #4
sw20kosh
Drives: 2013 Black FR-S
Hey guys,
Please help!
Thanks!
Were the VVT intake readings ok before the dealer did the repairs?
Old 08-15-2017, 02:14 AM   #5
Gringosteve
Drives: UK Spec GT86
That sounds very strange, have you tried double checking with another OBD based bit of kit
Gringosteve is offline   Reply With Quote
Old 08-17-2017, 04:36 AM   #6
RedFRS4me
RedFRS4me's Avatar
Yes. After the cam sprockets didn't fix the issue they replaced the ECU. An updated 2015 ECU I think.
'13 Firestorm
Old 08-17-2017, 04:38 AM   #7
RedFRS4me
RedFRS4me's Avatar
I don't have access to one at the moment. I'm leaning towards what steve99 and makinen. There's no cel or hesitation when driving. With my old ECU I never saw it behave in that way.
'13 Firestorm
Old 08-18-2017, 11:22 AM   #8
Submarinesonce
Drives: Frs
Mine does the same thing intake VVT is always erratic.
JDL UEL Turbo GT2860RS, AP Racing BBK, Verus Splitter/diffuser/canards, Sard rep carbon wing, TFF bash bar, HKS hi power, Tein Flex A, Hotchkiss FSB, Radium MCB, Konig Hypergram 17x8, FS Indy 500, 6k HID, Whiteline trans bushing insert, Verus AOS, grimmspeed strut brace, Racerx oil cooler w/ setrab 619, ES steering rack bushings, Whiteline subframe bushings, Toms tails, STi mirror caps, IRP shifter, TRD Steering wheel
Submarinesonce is offline   Reply With Quote
The Following User Says Thank You to Submarinesonce For This Useful Post:
RedFRS4me (08-24-2017)
High Afr readings. ristar Software Tuning 4 03-06-2017 04:53 AM
OFT strange IAM and FLKC readings...any help? Phil0rd Software Tuning 1 01-20-2017 03:14 AM
Decibel readings of 2017 BRZ vs other cars. ~el~jefe~ BRZ First-Gen (2012+) — General Topics 3 11-03-2016 10:33 AM
Weird O2 readings sw20kosh Software Tuning 22 05-15-2014 05:49 PM
TOM'S air intake + exhaust Juvenile Engine, Exhaust, Transmission 55 05-14-2014 08:37 PM
