Old 07-19-2017, 06:07 PM   #15
lazyluka
Drives: GT86
Originally Posted by allowe View Post
Thank you for that ! And I don't touch the rear alignment right ?
You will probably get charged the same regardless, so if you want to make a change make it, but it looks OK. I can't really give you more advice than this as I am not a suspension expert, I am just going on what was said to me in the past which in summary goes along these lines: "Small amount of toe in on the rear aids stability, small amount of toe out on the front aids turn in, toe accelerates tyre wear"
Before you go in for a wheel alignment, is there anything else you are planning on doing in the short term?
If you are looking at lowering springs etc, you may wish to do all that at the same time to save you an additional wheel alignment.
lazyluka is offline   Reply With Quote
Old 07-19-2017, 08:47 PM   #16
allowe
allowe's Avatar
Man thanks for your reply! I'd love to get coilovers or sportline springs by eibach but I don't wana scrape on anything or be stupid low or have a really stiff ride. I do however want to improve handling. I've realized that on back roads, my tires tend to give up and slide quickly.
allowe is offline   Reply With Quote
Old 07-19-2017, 09:46 PM   #17
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The only down side is that you lose $30 (or so) and spend a couple hours installing. In other words- there IS NO down side. I have SPC cambolts up front and got -2 degrees of camber and the difference was noticeable. I should have dialed ina few degrees more camber int he rear (SPC camber arms -1.7 degrees) because the car is too easy to create oversteer now.
guybo is offline   Reply With Quote
Old 07-20-2017, 06:04 PM   #18
lazyluka
Drives: GT86
I am not sure about if the 1 degree camber difference on your rear axle could be an issue or not as seen on your earlier post. You may need rear camber adjustment? Again ask the experts, I am not one.
@Racecomp Engineering may be able to offer you some advice, or you could try reading/asking in this thread if you have time: http://www.ft86club.com/forums/showthread.php?t=45554
For lowering springs, the RCE ones seem very highly recommended.
You don't necessarily have to have a lower car with coilovers and handling mods, while lowering does add it's own benefits, it's not a requirement.
Old 07-20-2017, 06:09 PM   #19
allowe
allowe's Avatar
The guy who aligned my car said it was good. I know camber isn't adjustable with stock arms. Only toe is.
Old 07-20-2017, 06:15 PM   #20
allowe
allowe's Avatar
Oh shoot!! I forgot. I had my car realigned because I didn't like the alignment before with that camber being too far!
OEM front camber bolts B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-30-2014 09:05 PM
WTB Front Camber bolts manualmotive Want-To-Buy Requests 2 04-17-2014 03:45 AM
Front Camber Bolts option hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-10-2013 01:28 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
