Old 07-12-2017, 12:38 PM   #29
5hairpins
5hairpins's Avatar
Drives: 2013 MT Asphalt FR-S
Originally Posted by Silver Supra View Post
Oh wow! This really is a good (bad?) example of swapping parts that don't fix the problem!!
Has the dealer or Toyota indicated that this should be covered by a warranty or warranty extension based on this history of ineffectiveness??
My warranty had expired quite a while back as I bought my FR-S in May of 2012 and did not extend the warranty. I have only paid for the original work so far, neither of the tank replacements have been billed and my rep explained that I only was to be billed for the first tank minus the labor I have already paid.
That said, I have not heard back from my rep since I called last Friday to follow up. That was when I was notified that Toyota engineers have been involved trying to find the root cause. In short, I have no idea what the final bill will be but you can bet I will be pitching a fit should they try to stick me with an even bigger bill.
5hairpins is offline   Reply With Quote
The Following 2 Users Say Thank You to 5hairpins For This Useful Post:
Silver Supra (07-12-2017), Ultramaroon (07-12-2017)
Old 07-13-2017, 11:44 AM   #30
chate
Pharmasaurus Magnificus
chate's Avatar
Sub'd, also having a gas tank filling issue, mine was also may 2012 build 818. Your thread will determine if keep the car
2013 FRS 6MT (Delivered 5/12/12 - 1st86!)
AEM CAI / Magnaflow Catback / OFT / OFH / e85
2015 Nissan GTR
chate is offline   Reply With Quote
Old 07-13-2017, 06:06 PM   #31
5hairpins
5hairpins's Avatar
No pressure.
Old 07-18-2017, 09:28 PM   #32
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Originally Posted by 5hairpins View Post
No pressure.
Also been having the same issue for the past couple weeks, it's getting to the point where I have to fill up 20 cents at a time. I just ordered a cheap endoscope to verify if something is causing fuel to back up or if its the vapor issue.
SubaSteve is offline   Reply With Quote
Old 07-19-2017, 05:02 PM   #33
5hairpins
5hairpins's Avatar
5th update: All parts involved with filling fuel have been replaced (tank, fuel neck, filter canister and who knows what else) and still not filling. Toyota is looking into the ECU now and if that fails to find the answer, a Fuel System Technician from Toyota gets to visit small town Texas to try and figure out the cause.
I hope my car's troubles can lead to a much less painful fix for everyone else's rides. Stay Tuned!
Timmy_Jones (08-14-2017), Ultramaroon (07-19-2017)
Old 07-19-2017, 08:55 PM   #34
Thanks for the update.
Oh, what a time of it you're having ......
Are they sure it's not THE gas pump, down there in Brownwood ......
Old 07-20-2017, 08:58 PM   #35
gravitylover
Wow, quite the conundrum you've got going there. Usually you'd think that replacing the entire system would solve it wouldn't you. Strange that it could be a computer issue. Really makes me wish pre-computer era cars were as safe as modern cars. I'd gladly go back to finicky carburetors...
Old 07-21-2017, 07:02 AM   #36
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The first thing they should have done is test the purge valve and test and see if a computer module was the issue. The garage threw parts at the problem hoping it'd fix it. That's a piss poor way to try and fix something AND an expensive way to do it. They replaced a bunch of perfectly good working parts and never found the issue.
This is the fault and problem of the garage you went to. You told them to fix the issue, nit throw parts at it.
guybo is offline   Reply With Quote
Old 08-02-2017, 10:09 AM   #37
5hairpins
5hairpins's Avatar
Final Update: I got the car back yesterday and the gas filling problem is fixed.
From the 1st Work Order:
Found that Chr. Cannister was full of Debris and Fuel. R&R Charcoal Cannister Assembly, tested Evap System all Monitors passed.
1 SU003-01027 Canister US
From the 2nd Work Order:
Found Charcoal Cannister leak detection pump module has fuel contamination due to failed fuel level cut off valve with tank assy. Replaced all affected components.
2 SU003-07284 Gasket Fuel Pump
1 44940 Tank Fuel Assy
1 SU003-01077 Pipe Filler CP US
1 SU003-01108 Valve Assy ELCM
1 SU003-01093 Hose Filler
The new fuel port is very different than original, not sure why. I am glad to have my car back but it was not a pleasant 8 weeks (June 6th to July 31) waiting for Toyota service to figure out what was wrong. During that 8 weeks the Service Manager I started with left and a new Manager was hired. I don't know that my experience will help anyone since I don't feel I was given a very good explanation on what was originally wrong. As Guybo said in the last post, they just threw parts at it until it was fixed.
Good luck to everyone else out there having issues with filling the car with gas. If you have questions, I will do my best to answer.
Last edited by 5hairpins; 08-02-2017 at 10:21 AM. Reason: Add info from first Work Order
The Following 8 Users Say Thank You to 5hairpins For This Useful Post:
chate (08-09-2017), ft86me (08-02-2017), Icecreamtruk (08-02-2017), Silver Supra (08-02-2017), Sportsguy83 (08-03-2017), Tcoat (08-09-2017), Timmy_Jones (08-14-2017), Ultramaroon (08-09-2017)
Old 08-09-2017, 03:25 PM   #38
chate
chate's Avatar
What was the total cost for repair, if you don't mind sharing, and was anything covered by toyota?
2015 Nissan GTR
Old 08-09-2017, 10:32 PM   #39
guybo
Huge E85 fan!
guybo's Avatar
I'm glad it's finally fixed, but that garage did poor work. Yeah it's fixed but it took too long and they took a very circuitous route.
Did you have to pay for a rental?
Old 08-14-2017, 10:29 AM   #40
5hairpins
5hairpins's Avatar
The two bills totaled to around $2000 and nothing was covered by Toyota. There was work not billed, that was the amount for the repairs up to the first gas tank.
I got a loaner starting when I returned the car after the first failed repair, I did not have to pay anything for the loaner.
Old 08-14-2017, 01:51 PM   #41
guybo
Huge E85 fan!
guybo's Avatar
That may have actually made up for the extra charges. That rental would have been a lot.
You happy to be back int he saddle?
Old 08-15-2017, 05:24 PM   #42
5hairpins
5hairpins's Avatar
Most definitely. The month prior, I had the car in for body work (fixing things I broke, not accident related) so I really was without the car since the spring.
There is a lake road right near my new place that is 55 MPH with two sets of lower speed turns, rated for 30 and 40 MPH respectively, and leads to town. Nothing like that in Dallas without an hour drive first and I can take it any time I head to town. Needless to say, it has been tons of fun.
The Following User Says Thank You to 5hairpins For This Useful Post:
guybo (08-15-2017)
Slight hesitation after filling 'er up stranger things Issues | Warranty | Recalls / TSB 5 05-21-2017 09:09 PM
Filling out the low-end buzznasa Electronics | Audio | NAV | Infotainment 20 03-31-2014 02:21 AM
Fuel overflowing when filling... TRBO2NR Scion FR-S / Toyota 86 GT86 General Forum 26 09-13-2013 10:56 PM
Filling holes in front grill? Fast_Freddy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-20-2013 12:44 PM
I was planning on just filling out paperwork... Longhorn248 BRZ First-Gen (2012+) — General Topics 34 06-05-2012 08:31 PM
