#15 | |
Drives: 2014 brz
Car is finally cool and that was the first thing I checked (the 2 hoses under the manifold). They were still intact but I was able to slide the hose on and off with my finger tips at the nipple behind the throttle body. I'm not sure if that is enough to cause such a drastic spike in my stft but I guess it's possible. I'm going to find a creative way to put a zip tie on it later tonight. I would love to keep pointing the finger at the manifold hoses but I have been staying out of boost since I'm not tuned yet and I'm only experiencing a measurable vac leak at idle. Stft drops when to normal values when cruising. |
#16 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
During idle is when you will be under high vacuum, if you have a leak, you will see P0171 during this time. Clamp every hose you can get to and like @guybo said, do a smoke test. For comparison sake, here's my log at idle when I had a vacuum leak and was popping P0171 codes. http://www.datazap.me/u/birdtrd/log-1497578227?log=0&data=6-10-11-30
LTFT and STFT were pegging and AFR still showed lean. |
#17 | |
Drives: 2014 brz
Yeah, my stft high only during idle and is also when the code usually pops on. Typically what I noticed is when I resealed my v bands pre o2 sensor and reset the code, I did a lot of immediate driving which meant very little time idling. The day I left the car on outside my shop is when the cel popped back on. |
#18 |
Drives: 2014 brz
I did a smoke test earlier today and made no progress. Original test I would only see smoke coming out of the intake filter. Took off the filter and plugged the turbo with a glove, wrapped it tight and pumped about 1-2psi of smoke from a home made apparatus and still no luck. It seems to be able to hold pressure well and the only place whistling or having escape of noticeable air is where I plugged the turbo inlet at.
The pcv hose that was originally connected right before the throttle body did have smoke come out of it when I d/c the hose from the intake which means this hose will also see vacuum when the engine is running. Could it be that this is where unmetered air is coming from since it is pulling air right at the intake filter? Also I've noticed there was a pcv valve installed on the hose to the rear of the intake manifold on some turbo and super charge builds. could not having that pcv valve there also cause a lean condition similar to a vacuum leak? |
#20 | |
Drives: 2014 BRZ
Are you absolutely certain that your WB02 connection is intended to be the closest to the turbo discharge? In all of my years I have always seen wideband bungs in downpipes furthest downstream.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
#21 |
Drives: 2014 BRZ
And are you using the rear 02 harness to plug your wideband into? If so, you could have your tuner send you a ROM with the rear 02 disabled so that you could rule faulty wideband out.
| Lean engine codes p0171 | zackegle | Issues | Warranty | Recalls / TSB | 23 | 03-14-2022 01:17 PM |
| too lean issue? p117B p0171 engine codes | zackegle | Issues | Warranty | Recalls / TSB | 1 | 03-21-2017 09:03 PM |
| P0171, P219a after OFH2 install | phantasticity | Engine, Exhaust, Transmission | 2 | 09-10-2016 08:55 PM |
| HELP:CEL and p0171 code | ZHoward | Engine, Exhaust, Transmission | 7 | 07-02-2015 10:47 PM |
| Crawford BPB CEL P0171 | AZ_Racer_1 | Issues | Warranty | Recalls / TSB | 16 | 02-06-2015 07:37 PM |
