go_a_way1
Old 07-08-2017, 06:01 AM   #3501
Waffle86
Waffle86's Avatar
Drives: 2013 SWP BRZ Limited
Looking for a square setup with natural camber and preferably no fender work...I am torn...
Will 17x9 +35 245/40/17 or 18x9.5 +38 245/40/18 fit with OEM damper with Eibach Sportlines or am I in for coils as well?
I am not a fan of the stretched tire look most people get in the front and am trying to gauge if I am better off dropping down to 17s for a meatier look or if I could get away with a taller sidewall on 18s as I know it is tough to go wider than 245 in the front even with coils. Yes, I am aware 245/40/18 would throw off my speedo...
Waffle86 is offline   Reply With Quote
Old 07-13-2017, 01:28 PM   #3502
whitelightninn
Drives: 2013 Subaru BRZ
Hey guys! I'm in the market for some 17x9 +27 wheels with a 5x114.3 lug pattern. I plan on pairing them with +15mm conversion spacers. Is this the right size spacers to use to achieve a flush look?
About my car:
Stock body BRZ
Fortune Auto coil
17x9 +35 RPF1s right now so i have some idea of setting up wheels..lol
whitelightninn is offline   Reply With Quote
Old 07-13-2017, 09:14 PM   #3503
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
About my car:
Stock body BRZ
Fortune Auto coil
not even close. Also, just get the proper bolt pattern to begin with. I'm guessing you are getting wheels for free/cheap, which is why you're trying to make this work? Pass them up.
Old 07-13-2017, 09:37 PM   #3504
15limited
15limited's Avatar
The 17s will fit.
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following User Says Thank You to 15limited For This Useful Post:
Waffle86 (07-14-2017)
Old 07-14-2017, 04:36 AM   #3505
Waffle86
Waffle86's Avatar
Originally Posted by jshadeck View Post
Fit should be fine, but a 9.5" wide front wheel w springs (not coilovers) will poke outside the fenders. It doesnt bother everyone but its there. Also, with springs and a 9.5 +40 you wont be able to camber much at all, or the wheel will hit the spring perch, so u cant camber to tuck the tire to eliminate some of the poke
Attachment 111412
I feel like I've searched this entire thread but still would like confirmation on my understanding before I can commit to a direction on wheels & suspension...
Assuming a square setup:
1) 18x9.5 +38 on 245/40/18 w/ eibach sportlines will fit w/out rubbing. No room for camber adjustment due to stock perch. No camber bolts needed to remove natural camber from lowering. Coilovers required to fix poke.
2) 18x8.5 +35 on 235/40/18 w/ eibach sportlines will fit w/out rubbing. Camber bolts optional.
3) 17x9 +42 on 245/40/17 w/ eibach sportlines will fit w/out rubbing. Very little room for camber adjustment due to stock perch.
4) 17x9 +35 on 245/40/17 w/ eibach sportlines will fit w/out rubbing. Camber bolts required to fix poke.
5) Coilovers magically make everything listed above fit.
Please correct me if I'm wrong about any of this - I've read a lot of conflicting information across multiple threads to get to this point
Old 07-15-2017, 04:49 AM   #3506
ryann.mendoza
Drives: 2017 Subaru BRZ limited PP
Would nt03 18x9.5 +40 fit on a 2017 brz with factory brembo brakes?
ryann.mendoza is offline   Reply With Quote
Old 07-15-2017, 09:29 AM   #3507
Azzudien
Drives: 2017 Series Yellow BRZ
No
Azzudien is offline   Reply With Quote
Old 07-15-2017, 10:56 AM   #3508
ryann.mendoza
Ok. Thank you for the info.
What wheels and size would fit with factory brembo brakes?
I apologize in advance as I'm new to the brz/86 world coming from a 2013 wrx hatchback
Old 07-16-2017, 12:20 PM   #3509
NINE
Drives: 2015 BRZ
Need some advice on running TE37SL 18x9.5 +40 on what tire size I should go with. I am picking up some KW V3's coils as well.
I was set on MICHELIN PILOT SUPER SPORT 255/35ZR18 but am wondering if I would be better off with 245's instead? I don't want to roll my fenders at this point but want to avoid rubbing.
Any advice would be great! Thanks
Daily: 2008 IS250 (Stock)
Toy: 2015 BRZ (KW V3, TE37sl) More to come.
Past: 2008 BMW M3, 1976 Datsun 280z, 1998 240sx, 1990 180sx, 2005 RSX-S, 2003 IS300, 2001 Civic.
NINE is offline   Reply With Quote
Old 07-17-2017, 01:41 PM   #3510
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
I have RPF1s at 17x7 with, I believe, 38 offset. I'd like to get some spacers to make them more flush. Any recommendations? Thanks.
MJones_RB is offline   Reply With Quote
Old 07-17-2017, 02:44 PM   #3511
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
About my car:
Stock body BRZ
Fortune Auto coil
you're going to poke outwards almost an inch further than your current 9in +35 setup... agree w/ @continuecrushing -- pass on these...
asdf is offline   Reply With Quote
The Following User Says Thank You to asdf For This Useful Post:
continuecrushing (07-17-2017)
Old 07-18-2017, 02:31 AM   #3512
whitelightninn
I'm passing on those. I'll admit I was way off. Discovered the frsproject tire calculator and have decided that ordering a set to my exact specs is the better option. It's a lot of money but I know I could resell them to another 86 or subie guy in my area.
I'm picturing Work VS-KF in 5x100 18x9.5 +30 on a 245/40/18
Locating a 5x100 set is proving to be extremely challenging. 18s in 5x100 that I've found are all shit and would need to be rebuilt anyways. Instead I'm going with Devilswerk wheels. They gave me the best quote with shipping.
What offset could I run to maximize the lips of the wheel? +27,+30, or +35?
What size tire is best for a lower profile look with minimal stretch on a 9.5 wheel? 245/40 or 235/40?
**Edit: Or would a 18x8 an aggressive offset like +15 be a better route? That would allow me to fun skinnier tires and enjoy stock power levels
I've seen plenty of threads with people running other 18x9.5 +38 or +45 wheels but not many VS-KFs on stock body 86s. Won't consider 225s on a 9.5 either. Too risky
About my car:
WRB BRZ
Fortune Auto v5s
Camber Bolts
This will allow me to tilt in the fronts. I'm expecting no more than -3.5 camber max to get this to all work. I'll order rear LCAs if I'm not happy without how the rear sit.
Prepared to receive some hate for the hotboy wheels/instagram build :/
Old 07-18-2017, 11:47 AM   #3513
dylandrivesacar
Drives: 2014 Scion FR-S
Would 18x9.5 +45 in the rear and 18x8.5 +45 in the front cause any rubbing issues?
dylandrivesacar is offline   Reply With Quote
Old 07-18-2017, 07:44 PM   #3514
15limited
15limited's Avatar
Is your vehicle lowered. If so, how much. Any added camber? Your tire size is also important to determine clearance.
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
