#15 |
Drives: 2020 BRZ PP
So glad they left it off. Wonder if I can just leave it unplugged when I go to coilovers with aftermarket lower control arms.
#16 |
| The Following User Says Thank You to Tcoat For This Useful Post: | Yoshoobaroo (06-08-2018) |
#17 |
Senior gif poster
Drives: 2013 Asphalt FRS
Man on the streets of SF around 19th in the morning it would have been handy. But then I would have never learned the art of the quick foot start or the subtlety of the ebrake start. Some hills are so steep you can't not be scared, it's apart of the fun of manual transmission.
I never had a car with hill assist, how far will it let you roll back on a really steep hill? |
#18 | |
![]() humfrz |
#19 | |
#20 |
Drives: Neptune GR86
It doesn't hold it indefinitely.
#22 |
Benched 86lb
Drives: Ultramarine FR-S
#23 | |
Drives: 2017 brz
Sent from my SM-T810 using Tapatalk |
#24 |
Rice Monkey
Drives: 2017 Subaru BRZ Sport-Tech WRB
The hill assist on the 2017's hold you for ~3 seconds if you are facing an uphill in 1st gear, or facing downhill in reverse gear, it doesn't let you roll back at all. On very slight inclines it won't hold you and you will roll back slightly as normal. Once you can feel the clutch grab, the hill assist does disengage itself, but if you don't give it enough gas it will hold the brake enough to/almost stall the car.
#25 | |
Drives: 2017 brz
#26 | |
Drives: 2017 Toyota 86
Edit: I do see that someone already supplied the "cheat codes".
#27 |
Drives: 2017 WRBP BRZ MT
Is the hill assist light always on once activated? Mine is always lit.
#28 |
pessimistic skeptic
No hill start, no hand brake. If you can't balance your car with the clutch and avoid stall, you just don't know how to drive manual. That is it.
| Anyone planning HAC (Hill Assist) retrofit? | Zardoman | Engine, Exhaust, Transmission | 28 | 06-06-2017 11:52 PM |
| Question regarding Hill-start assist control | rkaywhodat | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 09-30-2016 05:47 AM |
| Tuner Battlegrounds 2015 - Need an assist! | protpibe | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 07-08-2015 05:51 PM |
| Cusco Jack Assist Ramp Set | Evasive Motorsports | Mechanical Maintenance and Tools | 0 | 04-17-2015 01:40 PM |
| Car randomly doesn't start on slight hill | Craig | Issues | Warranty | Recalls / TSB | 7 | 02-01-2013 01:48 PM |
