Drives: 2017 Ice Silver BRZ Limited
Does DD Tail as Turn work on 2017?
I'm thinking about the ACE Laguna 90 exhaust for my 2017 BRZ and I want to make sure I still have backup lights. Thx!
Will |
#2 |
Drives: UK GT86
Not sure if serious but the MY17 has LED lights, you can't put a white light in them for the reverse.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | Williampreza (06-05-2017) |
#3 |
Yes. I'm aware of the led's. That's why I'm asking. Basically, if I delete my reverse light, is there a way that I can use this mod to have a reverse light in a different place, except that I wouldn't need to add any LED's.
The reason I ask is that I've seen several posts from people who did this with their pre-17 twins after switching to this exhaust and losing the reverse light. Does that make sense, or am I misunderstanding the way this device works? (given that they are not using the mod for it's explicit purpose, but rather taking advantage of a side effect) |
#4 | |
#5 |
Drives: UK GT86
What they do in the original tail lights is swap the indicator bulb with a white bulb:
![]() You'll either have to replace all the amber LEDs with white ones, or not have a reverse light.
.: Stealth 86 :.
#6 |
Okay thanks! Guess that's a no for my application.
#7 |
The Tail-as-Turn™ will not be compatible with the 2017 model because of the tail light design differences.
The Diode Dynamics SmartTap™ module works on the 2017 Toyota 86 though! ![]() ![]() ![]() Nick C.
| The Following User Says Thank You to Diode Dynamics For This Useful Post: | Williampreza (06-05-2017) |
#8 |
Drives: 2014 FR-S
![]() You could do a small LED strip with enclosure behind the stainless mesh. Something like this. Just out of site till the lights are on. Thats just an idea but something along those lines.
| The Following User Says Thank You to KnightRyderx2 For This Useful Post: | Williampreza (06-05-2017) |
#9 |
I thought they replaced the amber bulbs with dual "filament" LED's that are white when solid and flash amber (just like the replacement marker bulbs for the front), then add to the wiring harness so the solid white is triggered by the reverse light circuit?
#10 |
I think that's what I'll have to do. Maybe find two small rectangular enclosures that can accommodate the existing bulbs and then splice in the connectors.
#11 | |
Drives: UK GT86
[ame="https://www.youtube.com/watch?v=kuZz7Kih0Ck"]Tail as Turn™ + Backup LED Module for Scion FR-S, Subaru BRZ - YouTube[/ame]
.: Stealth 86 :.
Abbey Motorsport/K47 Tuned Sprintex 210 Supercharger Kodename 47 DJ: Soundcloud / Instagram / Facebook Last edited by Kodename47; 06-14-2017 at 12:17 PM. |
| The Following User Says Thank You to Kodename47 For This Useful Post: | wparsons (06-05-2017) |
#12 |
Ah, I was thinking of a different take on it using the switchback bulbs.
#13 |
Drives: 2014 FR-S
Out the box it moves your turn to the red circle LEDs. Since you now have the blank space where the blinker was you can move the reverse there, and replace the yellow bulb with a white bulb. You can go a step further and do a switchback blinker/reverse; but that is kinda pointless considering.
| The Following User Says Thank You to KnightRyderx2 For This Useful Post: | wparsons (06-06-2017) |
| Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! | Diode Dynamics | Exterior Parts - Lighting | 192 | 10-04-2017 12:51 PM |
| Would this work to turn off the p0420? | guybo | Engine, Exhaust, Transmission | 15 | 08-22-2017 10:51 AM |
| Converting 2017 BRZ fog lights to FRS turn signals? | James The Giant | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 04-12-2017 09:19 AM |
| Turn as tail timing not matching with the front turn signals | NahumCC | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 01-03-2016 11:40 PM |
| Help! Headlights/turn signals don't work and I can't get my car out of park | Cajun | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 01-11-2013 12:02 PM |
