Old 05-16-2017, 10:09 PM   #15
ls1ac
ls1ac's Avatar
Just an FYI the first number followed buy the W is the base weight of the oil. The second number refers to the viscosity enhancers effect. Unfortunately each manufacturer has leeway on the temperatures the enhancers open up and the lubricity they can provide. To further complicate things, the additives each manufactures uses changes the behavior of the oils. Hence the described differences in performances.
Old 05-19-2017, 09:19 PM   #16
Koa
Originally Posted by ristar View Post
Anyone have any experience with valvoline maxlife atf in these? I'm looking at it for cost reasons, the car doesn't and won't see the track, and from what I can tell it's a better option than the toyota ws. The motul multi-af is in my price range as well, but for the price difference i can get an extra drain and fill out of the valvoline. Thoughts?
usually not smart to base tranny oil for cost reasons in japanese cars.
especially when you only change the stuff so rarely.
get the motul.
Old 05-19-2017, 11:46 PM   #17
snuff58
snuff58's Avatar
Drives: 2014 Subaru BRZ Limited MTblue
I decided on Amsoil 75w90 GL4 in trans and Mobil1 75w90 LS in diff
Sent from my XT1254 using Tapatalk
snuff58 is offline   Reply With Quote
Old 05-20-2017, 08:41 AM   #18
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Allen86 View Post
What do you use for tranny
Part Numbers for Tranny & Diff Washer BRZY Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 03-24-2025 12:51 PM
MotulGear 75W90 okay for tranny and diff? midnitz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 07-18-2016 10:44 AM
Does BRZ come stock w/ magnetic drain plugs (diff/tranny)? Daedex Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 10-05-2014 09:50 PM
Should I change my diff oil and tranny oil Anthony7515 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 02-24-2014 12:30 PM
