Old 05-11-2017, 02:49 AM   #1
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
Car alarm comes on when reconnecting battery
Other day my car had no power. Wasn't sure what was wrong so I checked all my fuses to make sure they were still good. Eventually I just changed the battery and that worked, but now the alarm comes on every time I connect it and I cant start the car. The keyfob doesn't do anything and I even tried changing the battery in that too. I am certain I put the fuses back properly (cross-referenced multiple times with cover's diagram) but its not working.
Does anyone have any knowledge or experience with this type of problem?
Also, if anyone has a 2014 model could you please post an img of both your fuse boxes (engine and interior)? I was looking up fuse boxes but it seems like not all model years look the same.
Phantom Super Charged - 2014 BRZ
rhythmM is offline   Reply With Quote
Old 05-11-2017, 03:49 AM   #2
I suggest you pull the fuse for the car alarm.
Hook up the battery and start the car.
Replace the pulled fuse.
Of course, I'm one who used to just unplug then plug in my computer when it acted up....
There should be a picture of the fuse boxes in your owners manual.
rhythmM (05-11-2017), spike021 (05-11-2017)
Old 05-11-2017, 11:55 AM   #3
rhythmM
rhythmM's Avatar
I figured it out. Had one fuse on the wrong spot... Thanks for the advice
The Following 2 Users Say Thank You to rhythmM For This Useful Post:
humfrz (05-11-2017), Tcoat (05-11-2017)
Old 05-11-2017, 12:43 PM   #4
For anybody else reading this thread.
'No power' trouble shooting order of operations:
1) Check battery power level
2) If battery full - Check cable connections and posts
3) If cables good - Check fuses
4) If fuses good - Call towtruck
Do not deviate from this order for any reason.
humfrz (05-11-2017), Icecreamtruk (05-11-2017), rhythmM (05-11-2017)
Old 05-11-2017, 01:10 PM   #5
No power trouble shooting order of operations:
Where does .......jump on the forum and make a post ......come in .....??
Icecreamtruk (05-11-2017), Tcoat (05-11-2017)
Old 05-11-2017, 01:17 PM   #6
Usually if the trouble shooting is done backwards.
humfrz (05-11-2017)
Old 05-11-2017, 04:01 PM   #7
rhythmM
rhythmM's Avatar
Me lol.
I checked fuse first, THEN the battery
The Following User Says Thank You to rhythmM For This Useful Post:
Tcoat (05-11-2017)
Old 05-11-2017, 04:05 PM   #8
Originally Posted by rhythmM View Post
Me lol.
You are not alone. Well over half the "my car won't start" threads on here start with people checking fuses or even starters or alternators and then working their way back to the battery. Probably 95% of the time it is the battery. It is sort of like having a TV that doesn't work and pulling it all apart before checking to see if it is plugged in.
FS: KC Machine lightweight battery mount with Shorai battery and charger toeout Engine, Exhaust, Bolt-Ons 4 04-23-2017 01:07 AM
Key fob battery died. Can I manually unlock without alarm going off? Stu L Tissimus Electronics | Audio | NAV | Infotainment 3 05-28-2016 07:06 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 01:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
