Old 05-08-2017, 12:22 AM   #1
frsrandom
Drives: Scion FRS ' 13
Engine Vibrating Noise around 3.5k RPM (issue?)
Hi all!
I have a 2013 FRS (weekend car) with about 14k miles and have recently made aware of a particular vibration / engine noise (possible closer to the passenger side) when I accel / keep around 3500 - 4000 RPM. I am planning on stopping by the dealership before my power train warranty ends this year but was wondering if this is usual? the sound is most notable during 2nd gear 3500-4000 range. The noise resembles knocking? but almost non existant in any other gear. Sound is coming definitely in the engine bay (not transmission). Is this just the sound from vvt? im worried. thank you! Any advise would be greatly appreciated! Car is Stock.
Sounds similar to this?
[ame="https://www.youtube.com/watch?v=gcvI-anyCX4"]Frs engine problem - YouTube[/ame]
Not my car.
frsrandom is offline   Reply With Quote
Old 05-08-2017, 04:54 AM   #2
hmmmm....... well, your car sounds about like mine.....
Is this sound that you hear just started ... ??
You say that your exhaust is stock .... ??
You might check to see if anything is lose (heat shields, under panels, anything else that could rattle with engine vibration).
Old 05-08-2017, 08:00 AM   #3
BRZnut
Drives: BRZ DGM Limited
I hear it...sort of like a low pitch gurgle sound. Sounds almost like it could be a normal sound but something about it does not see right. Heard a lot of sounds with my BRZ but not quite that one. No idea what it is.
Old 05-08-2017, 08:54 AM   #4
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Ya that doesn't sound right at all....too much vibration, send it to dealer asap since you only have 14k mile.
Old 05-08-2017, 09:04 AM   #5
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Out of curiosity... does the sound go away once it's fully warmed up? (driven for about 15-20 minutes)
DaBoBo21 is offline   Reply With Quote
Old 05-08-2017, 11:45 AM   #6
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
If you still have the sound generator installed, that may explain why it sounds like it is coming from the passenger side.
-With the clutch in but rolling and 3500 RPM, does it make the noise?
-At a stop and 3500 RPM does it make the sound?
-If you are decelerating and the revs pass through 3500 RPM do you get the noise or is it only while accelerating?
It sounds to me like a sympathetic vibration. something is loose
guybo is offline   Reply With Quote
Old 05-09-2017, 06:22 AM   #7
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
He got a D on his display, I believe its a automatic.
I got a sound of small spring moving when accelerating before, not sure if is related.
FR-Sky is offline   Reply With Quote
Old 05-11-2017, 08:11 AM   #8
rkaywhodat
Drives: 2017 Toyota 86 Halo
Not sure if it's just the recording, but it sounds very strange compared to my 2017 automatic.
Sent from my Nexus 6P using Tapatalk
rkaywhodat is offline   Reply With Quote
Old 01-22-2018, 09:59 AM   #9
howareyoukk
Drives: Gts86
Originally Posted by frsrandom View Post
Hi all!
Not my car.
hi I got the same problem and mine is an automatic as well. have u got your issue sorted ? thanks.
howareyoukk is offline   Reply With Quote
Old 01-23-2018, 12:58 AM   #10
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
This is actually a normal sound. This is from the sound tube. If you use the 12V outlet cover and cover the sound tube hole in the passenger footwell, the sound goes away.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
howareyoukk (01-24-2018)
Old 01-23-2018, 02:05 AM   #11
howareyoukk
Drives: Gts86
will try it later on the way home after work thanks for the advice! I assume it works on yours? I read it somewhere where they attribute it to engine pining. thanks!
Old 01-23-2018, 03:10 AM   #12
howareyoukk
Drives: Gts86
yo sh*t man you are my hero ! so I went to plug the tube up with the cap found in the compartment on the passenger side and then took it for a ride and the rattles were gone and there were only pure engine sound left! would you mind telling me the theory behind it or was it even a mechanical problem to begin with? I would also assume the tube was connected to the engine so basically I was hearing sounds generated by the engine but what sound was I previously hearing though? intake noise? induction? thanks heaps!
Old 01-24-2018, 07:58 PM   #13
N1rve
N1rve's Avatar
You were hearing an intake nose, but it's piped through so it causes some distortion.
You can thank me by thanking my post
N1rve
Tcoat (01-24-2018)
Old 01-24-2018, 08:06 PM   #14
FT86 Idle Noise/Issue ? Injectors? Rezi Issues | Warranty | Recalls / TSB 1 01-20-2017 11:18 AM
Project Mu 800HC+noise issue after heating up during DD jflogerzi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 16 09-02-2014 03:36 PM
Window Regulator Mounting Bolts - Noise Issue & Part Revision? PollosHermanos Issues | Warranty | Recalls / TSB 1 03-06-2014 11:39 AM
Another Engine noise Vegas86 Issues | Warranty | Recalls / TSB 4 10-09-2013 01:30 PM
No Issue/Noise on BRZ European Models? Trap63 Issues | Warranty | Recalls / TSB 15 09-04-2013 04:29 PM
