Engine Vibrating Noise around 3.5k RPM (issue?)
Hi all!
I have a 2013 FRS (weekend car) with about 14k miles and have recently made aware of a particular vibration / engine noise (possible closer to the passenger side) when I accel / keep around 3500 - 4000 RPM. I am planning on stopping by the dealership before my power train warranty ends this year but was wondering if this is usual? the sound is most notable during 2nd gear 3500-4000 range. The noise resembles knocking? but almost non existant in any other gear. Sound is coming definitely in the engine bay (not transmission). Is this just the sound from vvt? im worried. thank you! Any advise would be greatly appreciated! Car is Stock.:(:( Sounds similar to this? [ame="https://www.youtube.com/watch?v=gcvI-anyCX4"]Frs engine problem - YouTube[/ame] Not my car. |
hmmmm....... well, your car sounds about like mine.....:iono:
Is this sound that you hear just started ... ?? You say that your exhaust is stock .... ?? You might check to see if anything is lose (heat shields, under panels, anything else that could rattle with engine vibration). humfrz |
I hear it...sort of like a low pitch gurgle sound. Sounds almost like it could be a normal sound but something about it does not see right. Heard a lot of sounds with my BRZ but not quite that one. No idea what it is.
Ya that doesn't sound right at all....too much vibration, send it to dealer asap since you only have 14k mile.
Out of curiosity... does the sound go away once it's fully warmed up? (driven for about 15-20 minutes)
If you still have the sound generator installed, that may explain why it sounds like it is coming from the passenger side.
-With the clutch in but rolling and 3500 RPM, does it make the noise? -At a stop and 3500 RPM does it make the sound? -If you are decelerating and the revs pass through 3500 RPM do you get the noise or is it only while accelerating? It sounds to me like a sympathetic vibration. something is loose |
I got a sound of small spring moving when accelerating before, not sure if is related. |
Not sure if it's just the recording, but it sounds very strange compared to my 2017 automatic.
Sent from my Nexus 6P using Tapatalk |
hi I got the same problem and mine is an automatic as well. have u got your issue sorted ? thanks. |
You can thank me by thanking my post :) :thanks: |
| All times are GMT -4. The time now is 06:34 PM. |
User Alert System provided by
