Old 05-05-2017, 09:58 PM   #1
Taka
Taka's Avatar
Drives: FRS
One Side Lower = Normal?
Just a quick question. I got some lowering springs installed that have been on the car for about 1 month now.
One thing I noticed is that the Rear Driver side sits 2mm lower than the Rear Passenger Side.
Is that normal? (All my tires are inflated to the same PSI all around)
Taka is offline   Reply With Quote
Old 05-05-2017, 10:05 PM   #2
ryoma
ryoma's Avatar
make sure the spring is sitting correctly on the spring perch. there's an indentation on the perch where the end of the coil should be. (at least for the front, I don't remember on the rear)
The Following User Says Thank You to ryoma For This Useful Post:
Taka (05-05-2017)
Old 05-05-2017, 10:50 PM   #3
Taka
Taka's Avatar
Drives: FRS
I'll have a look at it tomorrow. Thanks bud!
Old 05-06-2017, 12:28 AM   #4
There is on the rear as well. This seems to be a relatively common issue when spring are installed.
Old 05-06-2017, 10:38 AM   #5
Gforce
Drives: 2013 Subaru BRZ
How did you measure such a tiny amount?
There is zero probability that ride height for all four springs will be the same within 2 mm.
Factory fresh stock springs aren't usually within 5 mm.
You will realize that as soon as you get into the car the left side springs will get "shorter"?
Gforce is offline   Reply With Quote
Old 05-06-2017, 11:35 AM   #6
cjd
cjd's Avatar
Drives: 2017 BRZ
Drive the other 3 corners up onto 2mm platforms and it'll even out... roughly.
Unless you KNOW you're on a surface that is both perfectly level and flat, it's entirely likely that your measurements aren't all that accurate. In my garage, which sure feels like a flat smooth surface, the platforms are at ~-3mm, -26mm, -29mm... and that's just centerline differences.
Check the spring mounting, but I'd bet that it's the surface as much as it is anything else.
Also... after balancing, I definitely do not have exactly the same ride height all around... but that's to be expected. So it's not a bad thing inherently, no matter how you look at it.
C
Old 05-06-2017, 11:47 AM   #7
Taka
Taka's Avatar
Drives: FRS
Thanks for the advice and comments.
I've also contacted a shop I go to and they told me it's normal on springs to have a difference between 2-3mm.
I'll have them check it out also just for reassurance when I visit them for some things next week.
I'll also have a look at it myself today.
Thanks again everyone!
Old 05-06-2017, 03:38 PM   #8
Gunman
Drives: 2019 Mazda Miata RF
2mm is well within tolerance.
Old 05-06-2017, 06:17 PM   #9
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
It is possible that weight on the inside could be leaning to one corner. In my Integra, if anyone sat on the car or put anything more than 50lb in the car, you could see the car lower on whatever corner is closest. I had soft springrates at the time, but still something to consider if you have some luggage in there.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 05-06-2017, 06:19 PM   #10
Racecomp Engineering
Normal. And normal that the driver's side is the lower side.
- Andrew
Gforce (05-06-2017), mr_squirrel (05-07-2017)
WTB: Front Lower Control Arm DRIVER Side DaveUsagi Want-To-Buy Requests 1 09-19-2016 06:34 PM
scrapped lower side panel =( brandonblt2 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 15 11-07-2014 04:31 PM
WTB: FRONT LOWER CONTROL ARM (PASSENGER SIDE) Filipino Royale Brakes, Suspension, Chassis 0 04-20-2013 07:38 PM
five axis with addition side lower lip kit Mikegraves777 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 03-10-2013 11:51 AM
side skirts area is bumpy. normal? dnL Scion FR-S / Toyota 86 GT86 General Forum 13 09-13-2012 05:54 PM
