#309 |
Drives: 2017 WR BLUE BRZ
What are you going to replace it with?
#310 |
I got a dry carbon roof since it'll be easier to weld the cage in with the roof out.
| The Following User Says Thank You to Apex-Apex For This Useful Post: | ILLSMOQ (04-02-2017) |
#311 |
Just got the Dry Carbon roof from MPH Fabrication. It weighs only 3lbs!
| The Following 3 Users Say Thank You to Apex-Apex For This Useful Post: |
#312 |
Drives: Schwin
#313 |
Unfortunately this is the roof. I've been trying to shave as much as weight without having the move the radiator to the rear. So far, the front bash bar as shaved some weight, relocating the battery and dropping the 2jz as low and far back by using dry sump. The stock aluminum hood is really light and my seibon hood was probably the same weight, if not heavier.
#314 |
However, compared to stock roof, you shave 10lbs from the highest point of the car.
#315 |
Pretty bad ass roof right there!
| The Following User Says Thank You to ILLSMOQ For This Useful Post: | Apex-Apex (04-15-2017) |
#316 |
Drives: Schwin
I read hood.
I might have a drinking problem... |
| The Following User Says Thank You to huh For This Useful Post: | Apex-Apex (04-15-2017) |
#317 |
Thanks! It's super light!
I feel like I'm about to with this build.
#318 |
Decided to get some SPL Solid Subframe Bushings to replace the factory one. Hopefully this and solid diff bushings from Salasko Racing will save my diff!
#319 |
Now w/ over 400 womprats!
Drives: BRZ LZR
Goddang, this thread is just amazing! Keep up the parts porn!
![]() Random question: Any particular reason you're running the non-VVTi 12-tooth trigger wheel vs the standard VVTi 36-2 trigger wheel?
- The Ancient BRZ Sacrament by Zaku |
| The Following User Says Thank You to Guff For This Useful Post: | Apex-Apex (04-18-2017) |
#320 | |
| The Following User Says Thank You to Apex-Apex For This Useful Post: | Guff (04-18-2017) |
#321 | |
Drives: BRZ LZR
| The Following User Says Thank You to Guff For This Useful Post: | Apex-Apex (04-20-2017) |
#322 |
Hope to see more from your build! It's always interesting seeing everyone's perspective when they build things.
| The Following User Says Thank You to Apex-Apex For This Useful Post: | Guff (04-20-2017) |
| Toyota GRMN 86 Concept is a Race Inspired FR-S for the Street | vh_supra26 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 05-07-2016 01:49 PM |
| Alucard's BRZ Build | alucard7755 | Member's Car Journals | 8 | 03-08-2016 03:18 PM |
| MINOCIN's FR-S Build, not because racecar, not because street car... just, because. | MINOCIN | Member's Car Journals | 27 | 11-09-2015 12:02 AM |
| Street/Rally Build | z3ro | Member's Car Journals | 3 | 06-07-2014 07:21 AM |
| C-Street BRZ 192 Build Info | Sccabrz192 | Tracking / Autocross / HPDE / Drifting | 20 | 04-26-2014 11:12 AM |
