Old 06-27-2016, 04:22 PM   #1
mscamp02
Drives: 2013 FRS
P0198?
Just popped P0198 and the car is now feeling sluggish. I've been searching but haven't been able to find anything to helpful.
Any ideas on what needs to happen. The car is running a c38 KW kit with a complete exhaust. Normal pullies and no other real engine mods.
No other codes present and haven't ever had any codes in the past
mscamp02 is offline   Reply With Quote
Old 06-28-2016, 01:22 AM   #2
This may be informative.
http://www.autocodes.com/p0198_subaru.html
Old 06-28-2016, 02:30 AM   #3
steve99
Drives: FT86
As above its an oil temp sender fault code. oil temp sender is at front/top of motor near drive belts. Check the SC belt has not damaged sensor or wiring or the wiring has not been connected to sensor properly. else could be sensor, but more likely wiring worn/cut/shorted to earth.
Old 06-28-2016, 08:13 PM   #4
mscamp02
Drives: 2013 FRS
Thanks, I'm betting its damaged because this occurred after I snapped a belt
Old 06-28-2016, 09:40 PM   #5
It could also mean your sensor is actually working perfectly and the oil is to hot. The actual code is for hot oil after all.
Old 06-28-2016, 09:57 PM   #6
mscamp02
Drives: 2013 FRS
It's on constantly though, even after I clear it with the car cooled and I start the vehicle it's still there
Old 04-10-2017, 09:47 PM   #7
Dogster70
Dogster70's Avatar
Drives: 2013 Scion Frs Whiteout
If I were to have ran on that code witha turbo kit for a pull or two wouldnthat cause a blown head gasket? Hypothetically of course.
Dogster70 is offline   Reply With Quote
Old 04-10-2017, 10:39 PM   #8
steve99
Drives: FT86
The code usually indicates a sensor or wiring fault, description is sensor circuit high volts\signal. I don't believe its actually indicating high I'll temp
If the code is permanent is you clear it and it immediately returns with engine cold then it's a sensor wiring fault
Old 04-11-2017, 05:09 PM   #9
DirtySouth86
Drives: 2017 TOYOTA 86
Yeah if the code comes back the first time you turn the key on (without even starting engine), then it is electrical (dead sensor, wiring issue or ECM).
DirtySouth86 is offline   Reply With Quote
Car wont stay running for more than a second - P0102 & P0198 STS-V Engine, Exhaust, Transmission 13 06-23-2014 02:37 PM
p0198 code oil temp sensor malfunction circuit high kingkai23 Forced Induction 10 06-17-2014 02:22 PM
