Old 04-10-2017, 04:11 PM   #15
steve99
Drives: FT86
Originally Posted by Kris86 View Post
Yup! Same thing we all are thinking :-S
No codes makes it so much harder
If the ecutek logging for that cam and your ROM id is incorrect it could explain it.
but doesn't explain why engine runs like crap.
Kris86 (04-10-2017)
Old 04-10-2017, 05:51 PM   #16
Kodename47
Kodename47's Avatar
Drives: UK GT86
You should be able to log AVCS commanded, however at idle it should be 0 degrees.
Did the cams get timed correctly when it was put back together? That's the obvious issue and may need checking. If it's not that then I'd guess something is preventing oil flow to the solenoid to give it control. The fact the engine has been apart and is running poorly suggests it's going to be mechanical.
.: Stealth 86 :.
Kodename 47 DJ:
The Following 2 Users Say Thank You to Kodename47 For This Useful Post:
Kris86 (04-10-2017), Tokay444 (04-10-2017)
Old 04-10-2017, 06:46 PM   #17
Kris86
Kris86's Avatar
Drives: RHD Gt86
Thank you very much for your honest opinion. My mechanic has thought also it could be internal.
My mechanic took off the front cover and back checked the timing and said it is correct.
I will be speaking with my mechanic about looking into taking the engine back out and atleast check the internals and also make sure no oil ports are being blocked
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission
Kris86 is offline   Reply With Quote
Old 04-10-2017, 06:49 PM   #18
Kris86
Kris86's Avatar
Drives: RHD Gt86
Would be tuner be able to pick this up through the log I sent him?
Old 04-10-2017, 07:04 PM   #19
Ragin Gti
Drives: '15 Subaru BRZ
I'd bet the chain is on wrong. It's also possible to install the cam sprockets incorrectly. They have a nipple on the back side to locate them properly but if you just run the bolts in anyway they bolt on.
Ragin Gti is offline   Reply With Quote
The Following User Says Thank You to Ragin Gti For This Useful Post:
Kris86 (04-10-2017)
Old 04-10-2017, 07:46 PM   #20
Kris86
Kris86's Avatar
Drives: RHD Gt86
Calling my mechanic right now to mention this
Old 04-10-2017, 10:25 PM   #21
steve99
Drives: FT86
As kodename47 said it's most likely mechanical issue. It's often difficult to detect from logs if it's mechanical issue. Best way would be to log a car with same calibration I'd ecu and confirm it logs ok
Old 04-11-2017, 04:43 AM   #22
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you're logging using the supplied tune that is flashed to the car, this isn't the issue. As Steve said, it wouldn't tie in with the poor running anyway.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-11-2017, 02:18 PM   #23
Kris86
Kris86's Avatar
Drives: RHD Gt86
but what all mechanically could be related to this?
I have already got and replaced the cam sprocket :-S
Old 04-11-2017, 02:19 PM   #24
Kris86
Kris86's Avatar
Drives: RHD Gt86
any ideas as to what all mechanically I can look for?
Old 04-11-2017, 02:20 PM   #25
Kris86
Kris86's Avatar
Drives: RHD Gt86
all were installed correctly according to the Service Manual
anything else I can have a look at?
Old 04-11-2017, 02:24 PM   #26
Kris86
Kris86's Avatar
Drives: RHD Gt86
is it true that the cam sprockets advance timing with increased oil pressure?
so does this mean I dont have a oil pressure issue u think? or can lack of oil still cause this
Old 04-11-2017, 04:23 PM   #27
Kodename47
Kodename47's Avatar
Drives: UK GT86
Having a quick look at this: https://web.archive.org/web/20110820...hatsInside.htm
Oil control valve: The control unit then actuates changes through an oil control valve positioned at each intake camshaft sprocket. The oil control valve uses oil pressure from the engine to advance and retard the intake camshafts via the AVCS actuator.
Actuator: Mounted in the chain- or belt-driven drive sprocket, the actuator is fitted directly to the camshaft. Chambers in the actuator allow oil pressure to advance or retard it within the timing-belt sprocket. The oil fills the chambers and pushes against three lobes to turn the actuator and the camshaft on its axis.
Having not looked into the system in detail I can't comment more, but there are only a few components that control the system. Is this the original cam systems? I'm sure I've read that some issues have occurred using older/newer components to the original ECU.
.: Stealth 86 :.
Kodename 47 DJ:
Old 04-11-2017, 06:59 PM   #28
Kris86
Kris86's Avatar
Drives: RHD Gt86
I'm going to have a read on this myself
Yes these are the same stock cams and cam sprockets that came on the motor that were reused, up until this past weekend when I got another sprocket from the U.S and changed it to see if anything changes, got the very same result
AVCS - Intake and Exhaust Timing Kodename47 Software Tuning 274 02-28-2021 12:39 PM
AVCS Explained Rennmeister Engine, Exhaust, Transmission 3 03-15-2016 04:12 AM
AVCS tuning Turdinator Software Tuning 9 11-24-2015 02:31 PM
P000A AVCS check engline light? cookiesowns Issues | Warranty | Recalls / TSB 4 10-24-2015 02:48 AM
AVCS failures? hmong337 Forced Induction 26 02-12-2015 04:01 PM
