Old 06-29-2012, 10:40 PM   #43
velocity
Drives: rx8
Originally Posted by 07stealth350z View Post
Doubt it's aero limited.
Really??
You're going to say this after seeing the 2 vids in this thread??
Really?
velocity is offline   Reply With Quote
Old 06-30-2012, 12:45 AM   #44
SnapOv3st3r
Drives: 400whp Scion tC
Originally Posted by Enilder View Post
Probably not. We should start calling it "ECU limited" for those who can't comprehend.
That would be electronic means still. Which is not the case. Via the video, the car is at the top of its rpm band, it is tapped out and there are no more rpms to go to push it further into the 170mph range. Unless you consider the ECU being programmed to not rev higher, then one can say its electronically limited. But that's not the type of limit people are referring to when they say 138mph. This is an example of a real electronic limitation.
Example. The tC first gen, will hit 127mph and is electronically limited (ECU actually closes the throttle body). If you look at the tach when this happens it is at 5k rpms. The car tachs out at 6250 rpms.
When you remove that limit from the ECU and run the car out to the top rpm, in the top gear, then it will run on up to 147-150mph roughly.
The next step beyond that, and where the Twins are so called electronically limited, would be to actually increase the actual Redline of the vehicle. Doing so will allow even higher speeds to be obtained above that 170mph.
SnapOv3st3r is offline   Reply With Quote
Old 06-30-2012, 03:28 AM   #45
07stealth350z
Nissan Fan
07stealth350z's Avatar
Drives: Sector 9 Longboard
Originally Posted by velocity View Post
Really??
Really?
Really? Your going to assume I viewed videos. Really? How do you know I saw the vids in the thread? I didn't watch any, Im posting from my phone. Im on vacation right now, I dont have access to a computer. Lol. I simply saw the comment regarding aero limitations and gave my 2 cents. Not everybody is going to read/view every video on every post.
07stealth350z is offline   Reply With Quote
Old 06-30-2012, 03:37 AM   #46
07stealth350z
Nissan Fan
Originally Posted by Chauntalei View Post
Eh, when you consider the fact that the tires are $200+ each, I expect that kind of performance out of them.
I suppose. I just wouldn't expect any prius from any region to be achieving those speeds, regardless the price of the tires. I don't know much about these tires which is why I seem to be a bit more curious of their abilities. Nice to see that they can hold up! $200+ seems pricey for a 215 wide tire in 17in. Right around the same wheelhouse for a KDW2 in 275x19 for my 350 give or take some change. I assume they need to be shipped from Japan if someone were to get another set?
Old 06-30-2012, 04:27 AM   #47
Chauntalei
Drives: Non-BRZ
Nah, you can order them from tirerrack.com and have them shipped to your local shop for installation.
http://www.tirerack.com/tires/tires....7PHP&tab=Sizes
Chauntalei is offline   Reply With Quote
Old 06-30-2012, 06:49 AM   #48
speedracer38
speedracer38's Avatar
Drives: 2015 CWP Subaru BRZ Series.Blue
My car is bone stock (Limited / 6 speed) and I got better results this time....video coming soon.
*Please do not use my picture or post it anywhere else without my permission!
speedracer38 is offline   Reply With Quote
The Following User Says Thank You to speedracer38 For This Useful Post:
ChrisH (07-04-2012)
Old 06-30-2012, 08:49 AM   #49
Enilder
Drives: Porsche
I wasn't saying that it was ECU limited (as you said, it's the electronically limited) but rather aerodynamically limited. I wasn't really paying attention to RPM and how far these people actually pushed. There are so many factors play here that can affect the top speed in the open road. It is simply much easier to achieve the "true" top speed of the vehicle on a dyno due to lack of resistances.
Enilder is offline   Reply With Quote
Old 06-30-2012, 10:07 AM   #50
Elgancho
Drives: SWP BRZ Limited MT
how steep was the hill you were going down?
Elgancho is offline   Reply With Quote
Old 06-30-2012, 11:10 AM   #51
speedracer38
I only have video of the speedo because I didn't want to show my location but I guess it doesn't matter I'll make another video with exterior view as well next time.
Old 06-30-2012, 02:33 PM   #52
Elgancho
I was just messing with you.
Old 06-30-2012, 03:51 PM   #53
rapt
Drives: Silver Limited BRZ
Christ man! be careful out there
rapt is offline   Reply With Quote
Old 06-30-2012, 05:11 PM   #54
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Not that I am condoning these high speed runs but how stable does the car feel at those type of speeds? Does the front or rear start to get light? I have heard (read) a couple of people complain about steering feel and stability at highway speeds. You are doubling that plus some so therefore my question.
So many modders have more cents than sense!
Rampage is offline   Reply With Quote
Old 06-30-2012, 09:08 PM   #55
speedracer38
At higher speeds any car will feel a bit different with the dynamics with steering and stability but the BRZ felt solid nothing that made me worry.
Old 06-30-2012, 09:50 PM   #56
speedracer38
Thanks for your concern!! I have driven a LOT of high performance cars all the way up to the mighty Ferrari Enzo and Bugatti Veyron and I am always extremely cautious when I push any car to the limit. I always respect my ability and know when I am approaching my limit or comfort level for that matter and never push myself beyond that point.
I am taking the car to the track soon to explore what this thing is really capable of I just need some better tires because the stock tires SUCK
Speed Hunters Toyota 86-X Shin Scion FR-S / Toyota 86 GT86 General Forum 35 07-29-2012 05:49 AM
speed eindio Scion FR-S / Toyota 86 GT86 General Forum 4 06-27-2012 10:59 AM
Depth of speed DIG1992 Other Vehicles & General Automotive Discussions 6 05-22-2012 01:13 PM
Speed TV FR-S review Sport-Tech Scion FR-S / Toyota 86 GT86 General Forum 10 05-09-2012 11:41 AM
Need For Speed Shift 2 Dragonitti Other Vehicles & General Automotive Discussions 12 04-09-2011 10:49 PM
