Old 03-29-2017, 03:01 AM   #29
e_lunatic
Drives: 2015 Scion FR-S
Originally Posted by MuseChaser View Post
Yeah, probably, but I can't really blame them. They're under a lot of pressure to get a lot done in a short amount of time. The overhead in a large shop is ridiculous. My last oil change at the dealership cost me $60. If I did it myself, it'd probably cost me about... $60. (6 quarts x $5 if I find a great sale, $8 or even $9 if I don't, plus $8 for a good filter, plug gasket washer, gas to drive the old oil to recycler, garage supplies, blah blah). On top of that, they're supposed to pull all the wheels, measure the pads, top off coolant and other fluids, undo the fill plugs on the diff and tranny to check the levels... if they did the entire free inspection, it'd probably take 30 minutes. In that thirty minutes, they could have done another hour (or more) of $94/hr book-rate billable work.
Not excusing it; giving a customer inaccurate inspection results helps no one, and can result in what should have been avoidable problems occuring in the near future. Just saying I understand it.
i totally know what you mean but there is definitely something to be said for doing one's job to the best of their ability. it's something that I have had disagreements with past managers and owners about the difference between doing the job fast and doing it correctly.
e_lunatic is offline   Reply With Quote
Old 03-29-2017, 04:50 PM   #30
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
My Subaru dealership didn't want to do any warranty work for me - they'd try to suggest that I'd be charged if there turned out to be no problem with the car (I took it in for the package shelf TSB, and also for the passenger heated seat, which was far slower to heat up than the driver side).
Ultimately, because my car was a lease and I didn't want to have to deal with the hassle, I just left things as-is.
Second time I had to deal with the service department, I had just knackered my wheel bearing (put a wheel off the tarmac on my first track day).
I described the problem to them, noting that it was my driver-side front wheel that had the issue (resulted in a humming sound and very slight vibration in right hand turns).
I told the tech that I had done it myself during a track session - to his credit, he offered to fix it for me under warranty anyways because I was upfront about it.
When I got the car back, the vibration was still there, so I checked the confirmation sheet: it said they had replaced my passenger side wheel hub .
When I told them about it, they said there was nothing wrong with the hub (well, duh!), and that they didn't hear any humming from the front wheel (guess how I realized that they didn't fix the correct wheel hub).
I got so fed up with them, I just opted to buy a used wheel hub assembly on eBay (whoever wrecked their FRS, thank you), and did it myself. Problem solved.
I've also mentioned on here before, but in another incident with another Subaru dealership (from London ONT), they billed me $55 for 5 minutes of work that I did not give permission for, unrelated to the issue I brought the car in for (I brought it in, suspecting a faulty battery, and they went and fiddled with my Injen intake). It took a few emails and phone calls, including threats to report them to Consumer Protection Ontario (they had broken the stated rules requiring 1) explicit permission from the customer to perform any work; and 2) clear disclosure of fees/costs before work is done), but I did get my money back (more of a principle thing - I didn't feel like letting them get away with underhanded business tactics).
In short, Subaru service departments have given me plenty of justification to bring my car to independent shops or to DIY henceforth.
daiheadjai is offline   Reply With Quote
Old 03-30-2017, 06:03 AM   #31
BRZBlack
BRZBlack's Avatar
Drives: 2013 Subaru BRZ
This exactly.
BRZBlack is offline   Reply With Quote
Spark plug change - dealership price? wparsons CANADA 47 05-08-2019 07:48 AM
most recent ECU software notout86 Issues | Warranty | Recalls / TSB 9 11-06-2014 11:15 AM
Transmission fluid change from dealership? Jolaessss Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 10-15-2014 01:52 AM
best time of day for dealership oil change BlackyRose Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 07-27-2014 01:23 AM
Do you guys have the dealership to change out your engine oil? JS + BRZ Southern California 11 01-04-2014 01:23 AM
