Old 03-06-2017, 01:18 PM   #15
JoeC
Drives: Subaru BRZ Limited
wow. 1000hp on a platform designed for 200... that's pretty wild. So I see you're upgrading the clutch but do you also upgrade everything else between clutch and the wheels (drive shaft, diff, axles, etc...)?
JoeC is offline   Reply With Quote
Old 03-06-2017, 03:35 PM   #16
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
so pumped for this!
xkalelx is offline   Reply With Quote
Old 03-06-2017, 09:03 PM   #17
-Phil
Drives: Rb25 neo brz
The Diff/axles are already upgraded (DSS 5.9) , Diff will be coming from mark Spencer. Driveshaft will be built by axle exchange. the transmission takes a bit of abuse. The larger Neo version of the transmission see's 600-750 regularly.
-Phil is offline   Reply With Quote
Old 03-06-2017, 09:04 PM   #18
-Phil
Originally Posted by Teseo View Post
14k for for almost 1k horsepower is a bang for the buck on my book. My worries are, the engine mounts and transmission tunnel. Was hard to sort it out?
Trans tunnel is the standard stuff, cut out the bracing and fit in the new mounting setup.
The Following User Says Thank You to -Phil For This Useful Post:
Teseo (03-06-2017)
Old 03-07-2017, 01:52 PM   #19
GTHachiRoku
Big in Japan
GTHachiRoku's Avatar
Drives: turBRZ
Stuff like this keeps me from going FI on the FA20. Can't wait to see the results!
GTHachiRoku is offline   Reply With Quote
The Following User Says Thank You to GTHachiRoku For This Useful Post:
D_Thissen (03-07-2017)
Old 03-07-2017, 03:47 PM   #20
Calum
That Guy
Drives: 2013 asphalt FRS MT
How much of the stock functionality, ac, cruise control, power steering, gauges... are you expecting to maintain or do you think could be maintained with the Haltech?
Old 03-07-2017, 04:24 PM   #21
rob 2fast4u
rob 2fast4u's Avatar
Drives: 2JZ BRZ
^ I'd like to know as well, I have a PS2000 and would like to swap in a 2jz but retain some features like power steering, coolant, and RPM...
rob 2fast4u is offline   Reply With Quote
Old 03-07-2017, 06:08 PM   #22
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
There's a 1J car in South FL running on an Elite 2500 with everything working.
PS won't do it. Doesn't have the configurability with the CAN. You'll need an Elite... And someone knowledgeable with CAN systems.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
Calum (03-08-2017)
Old 03-08-2017, 08:07 AM   #23
Calum
That Guy
I wonder is @MRS-Colin would be willing to sell his research so people could setup Motec's and HalTech et. al. to have stock functionality without having to repeat the hard part?
*Just spit balling, I have no idea how effective that would be for either party.
The Following 2 Users Say Thank You to Calum For This Useful Post:
-Phil (03-08-2017), CxG (05-16-2017)
Old 03-08-2017, 11:27 AM   #24
cf6mech
Drives: FRS Silver LS1 swapped.
Think Collin was expecting someone else to do exactly what your saying.
cf6mech is offline   Reply With Quote
The Following 2 Users Say Thank You to cf6mech For This Useful Post:
Old 03-08-2017, 01:03 PM   #25
MRS-Colin
Drives: 2001 Impreza 2.5 RS
If I have the CAN documentation from any ECU I can make it work with a BRZ/FR-S with my module. No reprogramming of the ECU needed.
Colin Beck
MRS-Colin is offline   Reply With Quote
The Following 2 Users Say Thank You to MRS-Colin For This Useful Post:
Calum (03-08-2017), CxG (05-16-2017)
Old 03-09-2017, 12:27 PM   #26
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
That's not entirely true, not everything works on that car.
No CC, A/C works sporadically, no ABS, no traction control, I believe fuel gauge is on safe mode (full, middle, empty).
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Spartarus (03-09-2017)
Old 03-09-2017, 12:47 PM   #27
nickg
Drives: 2014 Whiteout FR-S Manual
Originally Posted by Jmk91 View Post
Will you guys be offering this in different power levels for different price ranges? Thought you ask because 1k hp is honestly to much for alot of us to handle or at least me, I'll admit it.
Just opt for a smaller turbo.
nickg is offline   Reply With Quote
The Following User Says Thank You to nickg For This Useful Post:
Calum (03-09-2017)
Old 03-09-2017, 01:15 PM   #28
MRS-Colin
*(full, almost dry, never seen because you are stuck on the side of the road)
Right Rick?
Colin Beck
The Following User Says Thank You to MRS-Colin For This Useful Post:
cf6mech (03-10-2017)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
LED swap Skorov AUSTRALIA 28 09-23-2014 10:46 PM
Ej Swap koyv90 Engine Swaps 50 11-14-2013 08:59 PM
