Old 02-15-2017, 08:05 AM   #1
Flame9020
Drives: 2015 Scion FR-S
forks in shifter issue
My car just broke down again. The car has only 11k on it and this is the 2nd time the forks in the shifter have broken on me. Thankfully the car is still under warranty so it should get fixed but how can I stop this from happening? Happening once is one thing but twice when the car is under 12k miles is strange.
Flame9020 is offline   Reply With Quote
Old 02-15-2017, 08:38 AM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
The Following 2 Users Say Thank You to roddy For This Useful Post:
extrashaky (02-15-2017), Ultramaroon (02-15-2017)
Old 02-15-2017, 10:23 AM   #3
extrashaky
Drives: 2014 BRZ Limited
Do you rest your hand on the shifter while driving (when not actually shifting)? If so, stop doing that. Keep your hand off the shifter except when actually shifting.
Old 02-15-2017, 11:44 AM   #4
Have you installed a short shifter .. ??
Whether you have or not, I reckon your problem is pilot error.
I suggest you "lighten up" on your shifting technique. Firmly pull or push the shift lever into the next gear up or down. The shifter knows how to go ...... it just needs your input on where to go.
roddy (02-15-2017), Ultramaroon (02-15-2017)
Old 02-15-2017, 11:53 PM   #5
F&F are not instructional films.
FrostedFlakes (02-16-2017), humfrz (02-16-2017), Joyride86 (02-16-2017)
Old 02-16-2017, 01:23 AM   #6
radroach
Drives: car
To make sure I'm reading you right, I think the word you're looking for is gates, not forks. The shifter should move easily enough through all the gates. So what could be causing your issue?
Old 02-16-2017, 01:29 AM   #7
gramicci101
Off Topic
Stealing and fencing electronics shipments is really the only way some scruffy bunch of backwater mechanics could afford to overnight car parts from Japan, so that part is about right.
The Following User Says Thank You to gramicci101 For This Useful Post:
Ultramaroon (02-16-2017)
Old 02-16-2017, 01:47 AM   #8
No, he means shift forks. He says he broke two, which sounds pretty crazy actually.
Old 02-16-2017, 09:47 AM   #9
Joyride86
Joyride86's Avatar
Drives: 15 FR-S Firestorm MT
However they did spawn a whole generation that had a renewed interest in cars. But I agree, watching them ram the shifter in the next gear was ridiculous. Just like the movie title, Fast and Furious.
Diode Dynamics Tail as Turn, LEDs, HIDs | Yospeed Custom Plaque and Frame | Suntek Carbon Tint | Spyder Smoked Side Markers | GrimmSpeed License Plate Relocator and Hood Struts | Five:AD Spoiler | JDM Armrest | Beat-Sonic Backup Cam | Moddiction Anvil 2 | Invidia N2 |
Joyride86 is offline   Reply With Quote
Old 02-16-2017, 07:11 PM   #10
I see the same behavior in some clips people share to demonstrate issues they are having with their transmissions. They are painful to watch.
Old 02-16-2017, 07:29 PM   #11
Flame9020
To answer all of the questions:
I do not rest my hand on the shifter.
There is a short throw shifter installed however I did not install it.
The mechanic I talked to at the time said it was the forks that had broken and not the gates.
Old 02-16-2017, 07:30 PM   #12
Flame9020
Update: The car is "fixed", apparently the shift linkage was messed up but now the whole shifter feels loose and sloppy. Also I am able to rotate the entire shifter about an 8th of a full rotation. The mechanic claims this isn't an issue but I am skeptical.
Old 02-16-2017, 07:33 PM   #13
gramicci101
Off Topic
You should be skeptical; that doesn't sound right. It sounds like a bushing wasn't reinstalled somewhere.
Old 02-16-2017, 07:50 PM   #14
nos145
Cognite
nos145's Avatar
Drives: 2013 Whiteout FRS
i co-own an engineering company.
if you keep plowing through them we can reverse engineer and fabricate one in titanium for you.
nos145 is offline   Reply With Quote
shifter issue srgssgtmatt Issues | Warranty | Recalls / TSB 5 09-15-2016 03:01 PM
Short shifter clearance issue with driveshaft Gank61 Engine, Exhaust, Transmission 16 03-08-2016 07:48 AM
MTEC shifter spring install issue jamesm Engine, Exhaust, Transmission 36 12-06-2015 10:36 AM
shifter issue? abutterman Issues | Warranty | Recalls / TSB 54 02-26-2014 06:10 PM
Issue with Kartboy short shifter tisb0b Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 10-20-2013 07:15 AM
