Old 01-29-2017, 02:56 PM   #1
ajh88
Drives: 2013 Firestorm FR-S
Car won't start after intake install
Hey guys, trying to troubleshoot a starting issue.
1. Installed new Blitz intake and removed sound piping. Plugged both sound generator holes.
2. Car started and after a few seconds shut off.
3. Realized I may have not followed directions totally and the MAF was slightly off where it should have been.
4. Repositioned MAF as it should have been. Took neg battery terminal off for a while to let ECU reset.
5. Car won't turn over. Turn key, nothing.
6. Cleaned MAF with MAF cleaner
7. Put stock intake back on.
8. Car won't turn over. Turn key, nothing.
Any ideas? The starter system looks OK. Battery looks like it has lots of power. Can't find any loose connectors. I'm at a loss.
2013 Firestorm FRS
1995 Alpine Silver Supra Turbo
Toyota Lexus Club of Pittsburgh
ajh88 is offline   Reply With Quote
Old 01-29-2017, 04:03 PM   #2
I suggest you clean the battery posts and cable connectors......maybe you have a bad connection ......
Old 01-29-2017, 04:26 PM   #3
ajh88
Replaced battery just now. No dice.
2013 Firestorm FRS
Old 01-29-2017, 04:40 PM   #4
DJCarbine
Thupercharged
DJCarbine's Avatar
No power at all, or just doesn't crank?
If no power at all, pop the fuse box open and check fuses as well as that there is power at the fuse box
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 01-29-2017, 04:41 PM   #5
PNW-BRZ
PNW-BRZ's Avatar
Drives: 2015 Limited
Check the fuses?
PNW-BRZ is offline   Reply With Quote
Old 01-29-2017, 05:07 PM   #6
ajh88
Dash lights and headlights and everything turns on. Key turning just does nothing. What exactly do I check in the fuse box?
I still feel like it's something I tweaked in the MAF harness (loose wire in there somewhere) when I was rerouting it from the stock position. Or bad MAF and my cleaning didnt work.
2013 Firestorm FRS
Old 01-29-2017, 05:37 PM   #7
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Disconnect the MAF sensor (leave the actual sensor in place, just unplug it) and see if it starts.
guybo is offline   Reply With Quote
Old 01-29-2017, 05:46 PM   #8
ajh88
Nope nothing :/ Argh.
2013 Firestorm FRS
Old 01-29-2017, 06:33 PM   #9
steve99
Drives: FT86
If you have dash lights , check the colour of the key or lock symbol in the dash it its red or yellow car wont start as security is active, the key symbol should go green if the code is being read from key fob correctly.
try your spare key.
also try removing battery terminal again and pressing brake pedal to bleed off any residual power then reconnect.
Old 01-29-2017, 06:36 PM   #10
steve99
Drives: FT86
bad maf or map sensor wont stop cranking, it should crank. it might not start but should crank
Old 01-29-2017, 06:45 PM   #11
ajh88
I dont have that symbol at all... 2013 with regular key (no push to start or keyless entry stuff).
2013 Firestorm FRS
Old 01-29-2017, 06:55 PM   #12
guybo
Huge E85 fan!
guybo's Avatar
I'm wondering if the problem isn't completely unrelated and it just happened when you put in the intake by coincidence.
AT or MT?
Check all the fuses and you need to determine if power is actually getting to the starter.
Old 01-29-2017, 06:56 PM   #13
ajh88
MT. What fuses would those be?
2013 Firestorm FRS
Old 01-29-2017, 07:01 PM   #14
guybo
Huge E85 fan!
guybo's Avatar
Check the fuse box and make sure none are blown. I don't think that's the problem but check. If I didn't read your OP and you just said that you turn the key and nothing happens but the battery is good, I'd say that the clutch safety switch is the culprit. Try to push the clutch in like you are trying to push it through the floorboards (make sure there's no carpet in the way) and turn it on then. Do you get ANY noise at all when you turn the key? A click or anything?
It'd really help and narrow things down a lot if we knew if the starter is getting any juice when you turn the key
Advanced Keys Push to Start Install in progress For the FRS. milkesfrs Cosmetic Modification (Interior/Exterior/Lighting) 117 04-25-2020 04:17 AM
DIY - EasyGo Push Start Button Install (FRS or BRZ Premium) Chaetagnath DIY (Do-It-Yourself) Guides 225 09-03-2017 06:20 PM
HELP! After Unichip install, car won't start!!! husker741 Issues | Warranty | Recalls / TSB 21 01-10-2015 11:50 PM
Shop to install Viper alarm/start? l0aded Southern California 0 05-04-2014 07:57 PM
Schematic for remote start install? empower-auto Electronics | Audio | NAV | Infotainment 3 07-31-2012 06:13 PM
