Old 12-05-2016, 02:48 PM   #1
Molina30
Drives: Stock White Scion FRS
Is a tune needed for a new exhaust?!
Hey, I'm looking at installing a Invidia n1 catback exhaust and Invidia catless frontpipe and wasn't sure if I have to tune my FR-S for it? Also if I don't need a tune, would it be recommended that I get a tune anyways? Thanks!
Molina30 is offline   Reply With Quote
Old 12-05-2016, 02:52 PM   #2
thecarfilmer
IG: @nickwiththefrs
thecarfilmer's Avatar
Drives: 2016 Scion FR-S Halo
You dont have to. I didnt at first but I did try doing the OFT stage 1 tune (n1 catback, catless fp and drop in filter). Felt a small difference, only did it cause I got a header and wanted to try stage 1 before I installed it.
thecarfilmer is offline   Reply With Quote
Old 12-05-2016, 03:19 PM   #3
wbradley
Sarcastic SOB
wbradley's Avatar
No. If you install headers a tune might extract another 15 peak hp. OFT with headers cheapest way to tune without a lot of risk.
Old 12-05-2016, 03:41 PM   #4
WELCOME to ye ol forum, Molina30 ........
I don't think you would need a tune after those mods.
And ....... I wouldn't recommend that you get a tune,...... anyways......
Old 12-05-2016, 04:05 PM   #5
Lantana frs
Drives: 13 frs red
Did you have a tune that gave you issues?
Lantana frs is offline   Reply With Quote
Old 12-05-2016, 04:34 PM   #6
Well, no ...... I just believe that when messing with the exhaust, shy of replacing the header with an aftermarket header, that a tune isn't necessary for averaging driving. In addition, it's a great way to mess with warranty work.
Oh, my use of the word "anyways" was in reference to the OP's use of the word "anyways" ...... as I took to mean ...... just for the heck of it.
humfrz - jest ain't no fun ......
Old 12-05-2016, 05:46 PM   #7
Lantana frs
Drives: 13 frs red
I get it. It just sounded like u might have had a bad tune at one point. There were some bad ones early on.
Old 12-05-2016, 06:21 PM   #8
ryoma
ryoma's Avatar
there's no need to get a tune for just replacing the front pipe and cat back, however, I would recommend buying an OFT (you can find a used one for around $400) and doing a "stage 1" tune for better drive-ability. you probably won't have much of a horsepower increase from the tune, but the car will run better. once you decide you want an aftermarket header (which you probably will later on) then you can get the "stage 2" tune from OFT without spending extra cash and that tune will actually add some extra HP. in regards to warranty work, you can always flash the car back to stock with the OFT as well.
Old 12-05-2016, 07:09 PM   #9
Well, I did have a bad tune once, back-in-the-day, that I did myself.
I was replacing the spark plug wires on my old Chevrolet and didn't pay attention to which wire went to which hole in the distributor cap.
Then I had a misconception about the firing order.
Talk about ..... backfire! .......
Old 12-05-2016, 08:31 PM   #10
Mr.Impreza
Mr.Fujitsubo
Mr.Impreza's Avatar
Drives: 2018 STI
A tune is not necessary for a catback & front pipe, but if you go with the OFT Tune option it will be a great device to compliment your car and mods.
Read my review for more information on the OFT.
http://www.ft86club.com/forums/showt...23#post2771023
2015 Toyota 86 ~ The Sold Car ~ Build Journal
OFT Stage 1 Tune Review
Mr.Impreza is offline   Reply With Quote
Unichip tune software needed almeshtaq Software Tuning 0 06-24-2016 02:58 AM
OFT300 (Vortech/OFT) help needed (tune issue) sirsol66 Software Tuning 7 12-09-2015 01:17 PM
high octane fuel + FI, tune not needed? BRZPDX Forced Induction 6 09-30-2014 01:41 AM
If just want to add front pipe and overpipe, tune needed to avoid cel? OICU812 Engine, Exhaust, Transmission 3 07-26-2013 10:43 AM
Exhaust help needed Jordan6908 Engine, Exhaust, Transmission 1 06-26-2012 12:41 PM
