Old 07-25-2013, 12:57 PM   #1
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
If just want to add front pipe and overpipe, tune needed to avoid cel?
I'm second guessing myself.
This year isn't going to provide me all I need find wise and time wise to go with a header and ecu tek tune. However was thinking of biting some of this off by adding a high flow cat front pipe and overpipe to my existing lachute mid pipe and catback exhaust. I realize without a tube I will not reap full benefits of these added pieces however should see some small gains due to less restriction as well get a slightly deeper tone, which... Is all good.
My question is can an individual have everything changed "after" header without tube and have no cel / eng light issues or negative effects?
If I need a tune 100% to avoid CEL issues ill simply wait but looking for feedback from folks that have changed out catback, mid,front,overpipe etc.
Thanks if you can comment.
Old 07-25-2013, 01:02 PM   #2
xxscaxx
Drives: 2013 SWP BRZ
no tune needed, and you will not get a CEL. There is no o2 sensor in the front pipe, both are in the header which is why people will throw a CEL when the cat is removed from an aftermarket one.
A tune might help a bit with power but I believe there is minimal gain. You will be fine.
xxscaxx is offline   Reply With Quote
Old 07-25-2013, 02:01 PM   #3
FastLane1000
FastLane1000's Avatar
Drives: White FR-S, 6M
Tune Tune Tune! no it won't throw a CEL but your missing out big time without a tune. It doesn't take any time either. You can swap headers and program your ECU in an hour or two. Just takes money which you obviously have enough of. Build looks great!
FastLane1000 is offline   Reply With Quote
Old 07-26-2013, 09:43 AM   #4
FRSGeek
Drives: UltraMarine 6 Spd MT
For this reason is why I went with cat on my fa20club header... :/ (When it finally arrives). I wanted my O2's to be as OEM as before. I dropped the 2nd cat on the front pipe.
FRSGeek is offline   Reply With Quote
Motiv Concepts Overpipe + HFC, Overpipe + Test Pipe Specials! MotivConcepts Engine, Exhaust, Bolt-Ons 96 07-19-2013 02:03 AM
Perrin Overpipe and Catless Front Pipe Eric1855 Engine, Exhaust, Bolt-Ons 1 05-27-2013 09:52 AM
OVERPIPE+FRONT PIPE QUESTION MontrealFRS Engine, Exhaust, Transmission 10 04-27-2013 01:59 AM
Agency Power Catback/front pipe & Overpipe (Brand New!) 20FRS13 Engine, Exhaust, Bolt-Ons 13 01-22-2013 03:08 AM
Motiv Concepts Overpipe and catted front pipe NIB ABQautoxer Engine, Exhaust, Bolt-Ons 8 12-11-2012 12:21 PM
