Old 11-29-2016, 06:32 PM   #15
Originally Posted by WWFT86 View Post
Appreciate all the i put thou... As my luck would have it... the car won't even start now and no brake light when brake pedal depressed... good thing this thing came with roadside assistance. ..
Well something else is up then since sensors would not kill your battery.
Old 11-29-2016, 09:31 PM   #16
WWFT86
Drives: 2017 BRZ Limited
Battery was not dead at all. Car could get to accessories mode but wouldn't start / crank over.
WWFT86 is offline   Reply With Quote
Old 11-29-2016, 10:05 PM   #17
Needs an obd2 reader and/or techstream to pull codes & run some diagnostics.
Old 11-29-2016, 10:09 PM   #18
That is a low battery. That is why batteries are rated by cranking amps not accessory amps.
Old 11-29-2016, 10:17 PM   #19
WWFT86
That crossed my mind as well but it wasn'tthe battery as the CAA guy came with a portable battery jumper unit and it still wouldn't crank over. It's something telling the ignition not to start...
CAA guy said the underbody spray probably got to the sensor like you first suggested...
The Following User Says Thank You to WWFT86 For This Useful Post:
Tcoat (11-29-2016)
Old 11-29-2016, 10:20 PM   #20
Still shouldn't prevent the car from starting. Obviously something else is up. Presume you were getting to the dealer.
Old 11-29-2016, 10:22 PM   #21
WWFT86
Yup took two CAA trucks to get it out of multi-story garage and then a flatbed to get it over to dealer. By that time service dept. closed so will find out tmrw what's going on.
Tcoat (11-29-2016)
Old 11-30-2016, 09:46 PM   #22
WWFT86
So the dealer told me it's nothing to do with the underbody rustproofing, but a sensor behind the break pedal.
Fully covered by warranty with no cost to me but takes them a full day to source the part.
Oh well.. guess things aren't always what them seem...
Tcoat (11-30-2016)
Old 11-30-2016, 11:05 PM   #23
The only thing I know of that is there is the brake light switch and that should not throw a brake system warning and certainly would not stop the car from starting. Unless there is another sensor I am not aware of. Anybody? Something doesn't add up.
Edit:
Thought so. No sensors.
Old 11-30-2016, 11:18 PM   #24
Yeah. I smells me some bullshit.
Old 12-01-2016, 12:37 AM   #25
Imrac
Drives: 13 SWP BRZ Prem
Edit:
He probably has an Automatic, Brake pedal must be pressed for the engine to start.
Also take a look at this thread:
http://www.ft86club.com/forums/showthread.php?t=67825
In my case the switch was not activating the brake light when I pressed the brake lightly, so the ECU looks at master cylinder pressure and says why is there pressure and no brake light and throws a code.
Kinda smart... Look at the master cylinder pressure, see the increase in pressure, realize the brakes switch is not closed (Or open, or what ever the position should be).
JDL UEL Headers, Nameless Res&Cat Over&Front, Invidia Q300 Catback, AVO Dry Panel Filter, Custom ECUTek Tune by DriftOffice
191WHP/151 ft-lb on 92
Imrac is offline   Reply With Quote
The Following 2 Users Say Thank You to Imrac For This Useful Post:
Ultramaroon (12-01-2016), WWFT86 (12-03-2016)
Old 12-01-2016, 12:48 AM   #26
sonofabitch!
Old 12-01-2016, 06:47 AM   #27
Thank you Sir! I was truly baffled. For some reason I had it n my head that it was a MT.
Old 12-01-2016, 10:31 AM   #28
wbradley
Sarcastic SOB
wbradley's Avatar
Would have had the same issue on a manual if the switch behind the clutch pedal failed. duh
Brake interlock was my suspicion.
The Following User Says Thank You to wbradley For This Useful Post:
Tcoat (12-01-2016)
Help needed. Indicators and headlight not turning on Suffa Electronics | Audio | NAV | Infotainment 0 10-05-2014 05:38 AM
In Need Of Ideas!! bh7990 Scion FR-S / Toyota 86 GT86 General Forum 28 05-19-2014 01:14 PM
Replace front DRL/indicators on GT/FRS 2SeeKU Cosmetic Modification (Interior/Exterior/Lighting) 11 11-29-2013 10:38 PM
Single tap indicators sav AFRICA 6 05-28-2013 02:24 PM
Side Mirror Indicators DriftEightSix Cosmetic Modification (Interior/Exterior/Lighting) 2 03-24-2013 01:37 AM
