Old 11-17-2016, 12:37 PM   #99
ILLSMOQ
Drives: 2017 WR BLUE BRZ
Been looking at pulley systems and it looks like most of the companies have customizable kits that come with waterpump, alternator and a/c compressor...most are between 2-3k.
Here's one.
http://www.eddiemotorsports.com/prod...chevy-less-ps/
Also thinking about supercharging...would probably require a different set up altogether
Hopefully Vorshlag offers up something a bit less costly.
ILLSMOQ is offline   Reply With Quote
Old 11-17-2016, 01:11 PM   #100
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I believe this dirty dingo set-up will work. Most likely requiring the wiring harness to be modified though.
Driver Side Pulley Bracket
Low Mount Alternator Driver Side
Low Mount Mini-A/C Bracket
Old 11-17-2016, 02:22 PM   #101
ILLSMOQ
Looks like that would be a two belt set up...kind of like the gen III truck style.
Old 11-17-2016, 03:58 PM   #102
DustinS
DustinS's Avatar
Wasn't really paying attention to that. Seems some are one belt, some are two. The LS3 are 2 belt systems (at least the 2010-2015 Camaro are). I will be waiting to see what Vorshlag has planned before ordering waterpump/crank pulley.
Old 11-19-2016, 12:26 AM   #103
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
So I'm guessing no 4x4 mode this winter... :O
The Following User Says Thank You to Kiske For This Useful Post:
DustinS (11-19-2016)
Old 11-23-2016, 04:54 AM   #104
6-Shift
Señor Member
6-Shift's Avatar
Drives: 2013 Raven, Drifty things
Any updates @DustinS ?
T O U G E - C U L T U R E
Follow me on instagram! :@tougeculture_chris
'13 FR-S, SBD Turbo kit, Tein Flex Z coils, other stuff. Drifting and autocross.
6-Shift is offline   Reply With Quote
Old 11-23-2016, 10:40 AM   #105
DustinS
DustinS's Avatar
Not really. Just playing the waiting game.
I was told 2 weeks on the transmission, but seems as though those that have ordered have waited around 2 months to finally receive it. Hoping that was just an early ordering ordeal. It is still a special order item at this point though.
I can't order Crank/waterpump until I know what accessories/accessory mounts I can/need to run. Which is all waiting on Vorshlag (along with clutch master cylinder, engine/trans mounts, headers, driveshaft). I have a feeling the LS3 stuff I had chosen will work, but the 2010-2015 Camaro it is based on uses the truck spacing and sticks quite far out from the block (from what I can find). Which makes custom brackets a must at least for the low mount alternator to keep things as close as possible using corvette parts.
I am also waiting on MRS to feel comfortable selling the final-ish revision of their CAN translator.
Edit: I sent an email to Dirty Dingo asking about the Low mount mini a/c / alternator mounts. Making sure they fit the 2010-2015 Camaro Crank Pulley.
The Following 3 Users Say Thank You to DustinS For This Useful Post:
6-Shift (11-26-2016), ILLSMOQ (11-23-2016), wooly35 (11-23-2016)
Old 11-23-2016, 06:17 PM   #106
DustinS
DustinS's Avatar
After staring at the Vorshlag Posts and doing some searching. I do believe they are using CTS-V accessories with the LS3 Water Pump. Running a pulley on the lower CTS-V Alternator bracket using some washers/custom spacer and a custom bolt.
CTS-V Accessories from an LS Swap Miata:
(Not LS3 Water Pump, but note how the belt sits at the very back of the pulley)
Vorshlag:
Custom Spacer:
The Crank Pulley is a Cadillac Crank Pulley and the water pump is a LS3 pump.
The Following User Says Thank You to DustinS For This Useful Post:
M1K3 (11-24-2016)
Old 11-23-2016, 09:36 PM   #107
MRS-Colin
Drives: 2001 Impreza 2.5 RS
Might sound crazy but I had to order connectors from Australia because that was the only place that had the right ones in stock. Company wouldn't ship intl' so I had a buddy of mine get them and then ship them to me.
Also got some more scan tool stuff working today so I should be able to finalize the rest of the code before long.
Colin Beck
MRS-Colin is offline   Reply With Quote
The Following 5 Users Say Thank You to MRS-Colin For This Useful Post:
cf6mech (11-23-2016), DustinS (11-25-2016), ILLSMOQ (11-24-2016), M1K3 (11-24-2016), wooly35 (11-26-2016)
Old 11-24-2016, 03:11 PM   #108
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
The C7 corvette accessory drive is simpler, easier, and works much better than anything else.
The C7 LT1 water pump fits the LS blocks, and puts the water necks in a better place for the FRS.
Shown here.
Only concern is alternator height, and whether it fouls with the fuse box on the side...
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following User Says Thank You to Spartarus For This Useful Post:
Zer0 (11-24-2016)
Old 11-24-2016, 09:10 PM   #109
Zer0
Drives: 2015 frs
Good info I was wondering about a LT water pump on a ls. I was thinking that pump, and custom low mount compressor and alternator bracket. Or a LT motor instead of a LS. Haven't ordered a engine yet so I may look it to the LT if it will mount to my transmission.
Zer0 is offline   Reply With Quote
Old 11-25-2016, 01:49 AM   #110
Spartarus
...Just add nauseum
Spartarus's Avatar
No prob, happy to help.
The LT motor will bring you only disappointment.
-Spartarus
Old 11-28-2016, 10:49 AM   #111
DustinS
DustinS's Avatar
Shown here.
I think the issue there is how deep the crank pulley is. They went with the CTS-V because of how little room was available for the crank pulley.
Old 11-28-2016, 04:33 PM   #112
Zer0
Drives: 2015 frs
Your correct but if you ran a LT water pump it gives you more room on the front of the engine if you could find a single belt crank pulley that matches the spacing of the LT pump you would gain even more room.
The Following User Says Thank You to Zer0 For This Useful Post:
Spartarus (11-28-2016)
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
