Old 11-03-2016, 11:05 AM   #15
trigun286
trigun286's Avatar
Drives: '16 WRB Limited
Originally Posted by PandaSPUR View Post
They're lights that turn on while you're running during the day time. If handbrake is on, thats a good reason for the car to think you wont be running :P
Its like asking why brake lights dont come on when you're not braking.
Original purpose of DRLs was to enhance safety by providing a visual signal during daytime to others that your car is moving towards them.
This is also why they normally turn off when low beams come on (also because those bright LEDs may be blinding to some).
Things change with time though, not sure what default DRL settings for other cars are.
I personally wish it wasnt this way, just to make it easier to take pictures of my car with the DRL on, but oh well.
Also.. why e-brake at a stop light... still learning MT on hills?
The aesthetic of the car was a reason but it's not that serious for me. Ebrake at stop lights is because my commute to work has stupidly long red lights and I noticed the DRLs turning off from the reflection off the car in front.
I was just seeing if there was a 5-10 min adjustment. If not, whatever.
Sent from my Nexus 6P using Tapatalk
trigun286 is offline   Reply With Quote
Old 11-03-2016, 11:08 AM   #16
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Originally Posted by trigun286 View Post
I was more curious to know why it's a feature to begin with. Also, I use the ebrake at stop lights sometimes and don't like the idea of the DRLs turning off. I feel even less people will notice me near them.
You use the ebrake at stop lights? New to manuals?
Old 11-03-2016, 11:25 AM   #17
86Boyz
Drives: on the highway to hell
Sometimes I put my car in neutral at a red light to pretend I have a manual to all the other drivers around me, especially on a hill.
86Boyz is offline   Reply With Quote
Old 11-03-2016, 11:38 AM   #18
extrashaky
Drives: 2014 BRZ Limited
I was wondering if this is a normal thing for these cars and if so is there a way to turn it off?
It appears that you can change how it operates using Techstream:
So either get a cable and install Techstream on your computer, or go to the dealer and ask them to go in and change it for you.
Old 11-03-2016, 11:48 AM   #19
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Pretty sure that just disables it completely, or enables it with normal logic.
Doesn't do what the OP wants it to do.
Old 11-03-2016, 12:49 PM   #20
trigun286
trigun286's Avatar
See my previous post.
Old 11-03-2016, 01:23 PM   #21
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
there are daytime running light modules you can get if you want them to stay on with the engine. i bought one of these modules when i imported my gt-four from japan and wiring it in is pretty easy once you know which wires to tap off of.
SC10N FR-S #435 of 2500
azian_advanced is offline   Reply With Quote
Old 11-03-2016, 02:08 PM   #22
KB_BRZ
Drives: '17 CWP w/ PP
on my VW GTI I was able to switch my drl to my fogs, not sure if that is possible on the BRZ
KB_BRZ is offline   Reply With Quote
Old 11-03-2016, 02:15 PM   #23
Summerwolf
Panda Trueno
Summerwolf's Avatar
You mean the one posted while I was probably typing my response.
So you use your ebrake at "ridiculously long stoplights?" New to manuals? Or driving in general? Most people would probably keep their foot on the brake pedal.
In all reality, if you're doing this and not keeping your foot on the brake pedal your brake lights aren't on either. So even if there is a person stopped behind you you're relying on them to keep their foot on the brake to warn another person of stopped traffic. Just not a good idea all around. The morning commute to work is not the time to be a lazy driver IMO.
Old 11-03-2016, 02:50 PM   #24
trigun286
trigun286's Avatar
Ah. Didn't see the post times.
This thread can die now. Hack isn't there, cool. /thread.
Old 11-03-2016, 03:39 PM   #25
BRZoomTX
BRZoomTX's Avatar
Drives: '13 BRZ
Hah, this thread got way over-complicated.
@trigun286 - The e-brake switch under the e-brake is what controls this. When the e-brake is up, the switch is depressed. Pressing this switch down (e-brake down position) activates the DRL's, and turns off the parking brake warning light on your dash.
Pop off your e-brake boot cover (use both hands, pull firmly straight up), and locate the e-brake switch. I don't have a picture, but its pretty obvious. Unplug the switch and re-install your cover. The DRL's, and boomerangs if using the Always-On harness, will now be on at all times even with the parking brake engaged. Yes, removing switch harness is the easy "hack" you're looking for.
The only side-effect I've noticed to this is the e-brake warning light will no longer illuminate when your parking brake is up... for obvious reasons. So if you rely on your dash to remind you to put your parking brake down before moving, good luck?
'13 WRB BRZ ~470whp // Instagram // YouTube
BRZoomTX is offline   Reply With Quote
The Following 3 Users Say Thank You to BRZoomTX For This Useful Post:
funwheeldrive (11-03-2016), Summerwolf (11-03-2016), trigun286 (11-03-2016)
Old 11-03-2016, 07:46 PM   #26
geezerbrzeezer
Geezer
Drives: 2016 Subaru BRZ Sport Tech
I'd love to do this on the BRZ. I've eliminated the DRL's - the look is too cluttered - and replaced the housing with JDM.
geezerbrzeezer is offline   Reply With Quote
Old 11-03-2016, 10:58 PM   #27
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
When DRLs are on, there is no indication from the rear of your car that they are on. Makes no difference to the person behind you, they see the same, front DRL lights on or off.
>>At a traffic light, you stopped, best to always show your brake lights, so that a car behind you is aware your intention is to stay stopped.<<
I have no idea why, with DRLs on, there are no running lights on at the rear of a car. It is stupid....There are daytime situations in which cars behind you cannot see your car at all...due to fog or heavy rain...even in bright sunlight.
Personally, I would have the law state that rear running lights should show anytime the DRLs are on.
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
Tcoat (11-10-2016)
Old 11-10-2016, 12:18 PM   #28
ReaperBRZ
ReaperBRZ's Avatar
Drives: 2013 Asphalt Subaru BRZ Limited
I'm guessing you want the cool parking lights to always be on instead of the drls? If so that's easy.
ReaperBRZ is offline   Reply With Quote
Handbrake not working. MstrSHAKE Issues | Warranty | Recalls / TSB 44 01-20-2016 12:53 AM
How to keep DRL running even when the handbrake is on?? CX Cosmetic Modification (Interior/Exterior/Lighting) 25 03-08-2015 05:01 PM
WTB: BRZ handbrake cover and handbrake boot w/ red stitching 86tylerfrs Want-To-Buy Requests 4 01-20-2015 05:11 PM
How to tighten handbrake? Ocean-Grown 86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2014 01:07 PM
Difference Between $3 DRLS and $40 DRLS? FR-S Matt Cosmetic Modification (Interior/Exterior/Lighting) 14 12-31-2012 06:05 AM
