Old 08-26-2016, 10:02 PM   #29
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Originally Posted by benlaz88 View Post
Correct me if im wrong on the bleeding. Depress the cluth pedal and hold it. Than open the bleed value to let the fluid out. Than close the valve. Than lift back the pedal up and repeat.
Sent from my SM-G935V using Tapatalk
Yes - this usually requires a helper
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
Old 08-26-2016, 10:29 PM   #30
benlaz88
Drives: 2013 Asphalt FRS
So i just did my bleed and still no success. I guess i will bring it back to the shop to take a look at it. Thanks for all your help everyone!
benlaz88 is offline   Reply With Quote
Old 08-30-2016, 09:29 PM   #31
benlaz88
Just got a call from my shop, i prob need to replace my trans. Nothing wrong with the clutch or the fork.🙁
Old 08-30-2016, 09:39 PM   #32
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
Visually the clutch fork will not show that it is/was bending in the transmission.
I had a customer who couldn't get the car into gear while stopped, acted like the clutch wasn't disengaging at all. He had an FX400 or 500. He replaced the OEM clutch fork with ours, called me when he was putting it in, "They look identical, the OEM unit isn't bent, the paint isn't chipped, I don't think this is going to fix it. Do you have any other ideas, etc." Ultimately he ended up trying it and it fixed his issue, clutch fully disengages again and the transmission works as it should. The fork was bending.
I can't say for sure this is the case here but just wanted to share this instance. Just because the fork looks okay, does not mean it isn't bending in the bell housing.
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following User Says Thank You to VerusEric For This Useful Post:
Drakiv (11-01-2016)
Old 08-30-2016, 09:50 PM   #33
benlaz88
Thanks,
Eric
Is there a number i can call you?
Old 08-31-2016, 03:48 PM   #34
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
No.
Open
Depress clutch
Close
Release clutch.
Or...
Sit in car.
Depress clutch.
Start car.
Put in first gear.
Release clutch until car starts to move.
Grab point found.
When I get back to town I'm going to get a video up to demonstrate my point.
Yes, that will find the grab point. But the friction zone extends well past the grab point. That's why OP can't get the trans in gear.
Mark the grab point height with something.
Put the car on a lift. Drive wheels in the air. Engine running.
Put trans in first.
Depress clutch very slowly until wheels stop turning.
See how far down past the "grab point" you have to go to stop the wheels
It will transform the way you see full-face organic clutches.
Run the same test with pucks. The difference is alarming.
Just got a call from my shop, i prob need to replace my trans. Nothing wrong with the clutch or the fork.��
No. That's not how the transmission works.
Either way, assuming OP did bleed the clutch correctly, the flex in the fork reduces the motion ratio, and the clutch remains in the friction zone. The car is stopped. The first gear synchro has to fight to stop the input shaft and countershaft, as the output shaft is stopped. The clutch is trying to fight to keep the input shaft turning at idle RPM. The clutch wins, and the trans won't go in to gear. If the car didn't have baulk ring synchros, it would just grind. But, as it does have baulk rings, it simply locks out of gear because the shaft speeds will not synchronize.
If it won't go into first at any speed, and won't go in with the engine off, then your transmission is broken, but that's not what you said earlier. We can get into what may be broken, but that's not the case.
Assuming you've told us everything, your issue is clutch drag. There aren't any other possibilities. We can talk about why if you like.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 2 Users Say Thank You to Spartarus For This Useful Post:
benlaz88 (09-01-2016), Ultramaroon (08-31-2016)
Old 08-31-2016, 04:26 PM   #35
OP, I cannot stress enough the importance of reading the above post very carefully. If any part of it is not crystal clear, ask for clarification.
Old 10-31-2016, 09:19 PM   #36
benlaz88
UPDATE: totally forgot to update you guys!
Replaced my clutch fork, the gear still block me from getting into gear. This hissing sound occur when gear is block. After able to get in 5th gear and put back into natural, hissing sound stop and I'm able put in reverse and first. Any idea what cause it. I have southbound endurance clutch. Any help will be appreciated! I dont know how to post sound clip on here.. i have also post this on the AZ86 members page with video/sound clip https://www.facebook.com/groups/1422313724716286/
Old 10-31-2016, 09:56 PM   #37
Post it on youtube. For now I'll guess that your friction disc is binding on the input shaft.
Old 10-31-2016, 11:30 PM   #38
benlaz88
Ok. here you go. [ame="https://www.youtube.com/watch?v=8D6r_Kx1588"]Frs gear block Hissing sound - YouTube[/ame]
Old 10-31-2016, 11:36 PM   #39
VerusEric
VerusEric's Avatar
Ok. here you go.
Are the wheels spinning at all or are they stationary through the whole video?
Old 10-31-2016, 11:53 PM   #40
benlaz88
they are stationary through the whole video
Old 11-01-2016, 12:12 AM   #41
Ok. here you go.
Your clutch isn't fully disengaging. That's the sound of you stalling the friction disc.
I bet if you put it in first and then start the engine, it will creep.
Don't drive it at all until you get that clutch fixed.
edit: Eric, what do you think?
Old 11-01-2016, 01:07 AM   #42
VerusEric
VerusEric's Avatar
I think the bolded statement is a good test to prove the theory.
I want to clarify OP's statements as they're a bit confusing currently. Benlaz88, could you please clarify if the below statements are all true?
1) The noise exists with the car out of gear, clutch depressed?
2) What happens with car out of gear, clutch not depressed?
3) The noise goes away when the car goes into gear, clutch depressed?
That is not a good sound and something I can honestly say I have not heard before.
Thanks,
Eric
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 07:28 PM
Anyone experiencing 2nd gear problem? seominjung BRZ First-Gen (2012+) — General Topics 37 08-15-2015 01:32 AM
2nd Gear Syncro Problem nashsnazzy Issues | Warranty | Recalls / TSB 22 07-14-2014 10:20 AM
After Market Problem Signals Fuse Popped- Car Wont Go into Gear ScionFR-S Issues | Warranty | Recalls / TSB 14 11-20-2012 03:34 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
