Old 08-30-2016, 08:32 PM   #1
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
Which upgraded tires for the BRZ?
Well, I've never started a thread before, but I'm looking for comments and opinions from all youse guys on my question and I hope this is the right way to solicit them.
I have been a tire upgrader my whole life, buying slightly wider and taller rubber for each car I've owned. Now it's my daily driver BRZ whose OE rubber is wearing down to the point that I would be nervous facing the rainy/snowy season without new shoes on him to be sure he goes where I point him. While many of you scoff at the Primacies as "Prius tires," I'm certain the designers have chosen the 215/45 as the size that maximizes traction, handling, economy, etc.
Nonetheless, I have found in the past that moving from 195 to 225, for example, has a very nice effect on ride and other qualities, as long as they fit, and I've become adept at calculating in my head the difference between speedo and actual speed (we call that "bistro math" around here). I have enjoyed the Conti Extreme Contact DWS recently on my previous car, am looking for a Performance All Season tire, and would consider even the 245/40 some of you have used -- do you need spacers for that size, or what.
So, I'm sure there's lots of wisdom out there. Please fire away.
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
Old 08-30-2016, 08:55 PM   #2
swarb
225/45 for good upsize that fits stock 7" width. 235/40 is a little too much width.
Tirerack.com for reviews, compare to the dws you had before. Read the width ranges for the wheel size.
No spacers needed.
The Following 2 Users Say Thank You to swarb For This Useful Post:
jarnojvv (08-31-2016), pfaffendorn (08-31-2016)
Old 08-30-2016, 09:03 PM   #3
Silver Cervy
*Some really cool title*
Silver Cervy's Avatar
First of all, look here: http://www.ft86club.com/forums/showthread.php?t=25177
You won't need spacers for 245's, but putting very wide tires on a car with as little power as the BRZ will just slow the car down.
Personally, I will be upgrading to 17x8 wheels and 225/40 PSS's. You want your tire to be stretched across the wheel and not be loose, but you also don't want it to be too tight or your ride quality will be harsh.
Silver Cervy is offline   Reply With Quote
The Following User Says Thank You to Silver Cervy For This Useful Post:
Old 08-30-2016, 09:15 PM   #4
bhmax
Drives: 13 BRZ, 17 Focus RS
Planning on staying with stock wheels? Most would say not to go wider than 225 for them. I'm actually on 205/45. I had DWS and Bridgestone RE970AS on another car. Enjoyed the Bstones much more in the corners due to I'm guessing stiffer sidewalls.
bhmax is offline   Reply With Quote
The Following User Says Thank You to bhmax For This Useful Post:
Old 08-30-2016, 10:20 PM   #5
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
First off, the "designers" chosing this tire is all corperate bs. It's all about who can provide enough tires for the lowest price. So get that idea out of your head forever.
a 245 tire on the stock wheels is too much. 225/45 would be your best beat for comfort and grip.
The Following User Says Thank You to Mr.ac For This Useful Post:
Old 08-30-2016, 10:22 PM   #6
n8dog11914
n8dog11914's Avatar
Drives: 2013 WRB Subaru BRZ 6MT
If you are looking for a nice Performance All-Season tire, take a hard look at the Conti ExtremeContact DWS06. The '06' is the new version which has much stiffer sidewalls but still maintains the good snow and wet traction that the DWS had. My wife has them on her car and loves them.
n8dog11914 is offline   Reply With Quote
The Following User Says Thank You to n8dog11914 For This Useful Post:
Old 08-30-2016, 10:27 PM   #7
AHHHH another conspiracy theorist. You are wrong. So very very wrong.
ALL parts of a car are speced very carefully to work together as a whole. Up to and including the stock tires. Price is only one small factor in the decision on what parts to use.
Hell the design team even explains why they went with the tires they did in the development story.
jarnojvv (08-31-2016), jawn (08-31-2016), pfaffendorn (08-31-2016), why? (09-01-2016)
Old 08-30-2016, 10:44 PM   #8
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Ha! Like wise sir.
If that was true about tires the factory would allow you to chose your own tires. But it's really not the case at all. Mitchelin won the contract to provid tires to Toyota because their price was a good one.
Maybe in the future Hankook tires will be OEM for the twins.
By the way Hankook tires won bids to be OEM tires for certain Merceds Benz, BMW, Ford and even Toyota. Wrap your head around that.
Old 08-31-2016, 12:43 AM   #9
lupindub
Drives: Scion FR-S
Ha! Like wise sir.
By the way Hankook tires won bids to be OEM tires for curtain Merceds Benz, BMW, Ford and even Toyota. Wrap your head around that.
Don't forget some of the twins got BridgeStone's as there OEM tires.
lupindub is offline   Reply With Quote
The Following User Says Thank You to lupindub For This Useful Post:
Old 08-31-2016, 02:02 AM   #10
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Yep, pretty much who ever wins the contract for that production year.
Old 08-31-2016, 02:34 AM   #11
jarnojvv
jarnojvv's Avatar
Drives: 86|Fortuner|FJ|Mustang|SwiftSport
No spacers needed.
+1
I have stock rims, changed from the std Primacy to Pilot Sport 3 in 225/45, great tyre, increased grip, BUT less steering feel is noticeable.
-JvV-
jarnojvv is offline   Reply With Quote
The Following User Says Thank You to jarnojvv For This Useful Post:
Old 08-31-2016, 02:40 AM   #12
jarnojvv
jarnojvv's Avatar
Nope, climate based.
Also the OEM tire for the 16inch rims on some models were Yokohama.
-JvV-
Old 08-31-2016, 03:16 AM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
jarnojvv: Pilot Sport 3 is completely different to PSS many mention. I heard that PS4 might be closer to PSS performance, but PS3 IIRC is of completely different rubber compound (wasn't it from exhalto line?) sharing similar model name just due marketing reasons. It may still have more grip then stock primacies due those being low rolling resistance eco tires, but i wouldn't expect wonders from PS3.
Old 08-31-2016, 03:21 AM   #14
jarnojvv
jarnojvv's Avatar
Sure, but this was pre ps4, and pss doesn't come in std rim size. Grippiest tires available locally were conti5 or ps3...
FYI
http://www.tyrereviews.co.uk/Article...ss-Release.htm
-JvV-
Upgraded Tires Happened Sooner Than Expected wakawaka Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 02-29-2016 05:58 AM
Some thoughts after upgraded tires Drakelee117 BRZ First-Gen (2012+) — General Topics 24 02-11-2015 03:21 AM
Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires themajesticone Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 08-04-2014 03:49 PM
Track Test: Edmunds 2013 Scion FR-S with Upgraded Wheels and Tires Pulls 1.0g! poormans_LFA Scion FR-S / Toyota 86 GT86 General Forum 38 09-08-2012 01:46 AM
Retaining driving dynamic with upgraded tires? - frs nixeighty6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 12-22-2011 02:44 AM
