Old 08-28-2016, 04:43 PM   #1
VinJah
Drives: Blue Scion FR-S
Best Wheel Size?
What is the best wheel size for the FR-S that will NOT cause rubbing?
VinJah is offline   Reply With Quote
Old 08-28-2016, 04:45 PM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
15x10
-Josh
Old 08-28-2016, 04:46 PM   #3
Yoshoobaroo
TRACKBREAD
Just kidding, but that's a very vague question. Best for what? Track days? Drag racing? Showing off? Hard parking?
-Josh
Old 08-28-2016, 05:09 PM   #4
VinJah
-Josh
whats the biggest size i can have, its a daily but im going to put a turbo in eventually and want it to be able to handle it
Old 08-28-2016, 05:13 PM   #5
Yoshoobaroo
TRACKBREAD
Honestly depending on the tire compound, stock tire size can handle a turbo just fine.
That said, people are running 255s on this car with minimal problems, do some digging in the forum, you'll find plenty of options!
-Josh
Old 08-28-2016, 05:23 PM   #6
headlikeahole
headlikeahole's Avatar
Drives: Ultramarine toyobaru
Stock specs are the best for everyday driving and hooning. Throw some spacers on if you want more flush.
headlikeahole is offline   Reply With Quote
Old 08-29-2016, 02:00 AM   #7
Hostile_Kittens
Hostile_Kittens's Avatar
Drives: 2015 Subaru BRZ
What are your horsepower goals for your turbo? At 250hp you can get away with sticky 225s on the stock wheels; at 500hp+ you're gonna be looking into 18x10's.
Easiest answer is go buy some 17x9s in 42 to 35 offset. They'll fit 245-255 width tires and be good for both NA an FI.
Hostile_Kittens is offline   Reply With Quote
The Following 2 Users Say Thank You to Hostile_Kittens For This Useful Post:
DarkSunrise (08-29-2016), JazzleSAURUS (08-29-2016)
Old 08-29-2016, 07:10 AM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, spacesaver donut wheels are shure to not rub on FR-S. If they clear calipers that is
Old 08-29-2016, 10:19 AM   #9
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
17x8 or so with some 235's now in something like an S-04 or PSS will be a huge improvement now, and with FI, and will hold up decently for boost, and if you decide you want more you can step up to stickier rubber.
JazzleSAURUS is offline   Reply With Quote
Old 08-29-2016, 11:17 AM   #10
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
IMO the best size wheels for stock-ish power levels is 17x8. That holds a 225 tire really well, but you can still run 245 if you need to.
smg1138 is offline   Reply With Quote
Old 08-29-2016, 11:54 AM   #11
Yoshoobaroo
TRACKBREAD
I think so too. You can fit the stock 215s no problem, and you can go up to a 245 RS3/Rival S if you need monster grip
-Josh
Old 08-29-2016, 12:51 PM   #12
DarkSunrise
DarkSunrise's Avatar
Agree with this. If you're adding a turbo, just go straight to a 9" wheel.
2022 BRZ Build
2013 FR-S Build
Wheel Spacer Size?? tonytduc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 52 11-03-2018 04:36 AM
Wheel size needed FRSssh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-28-2015 02:00 AM
Wheel/Tire size help!!! jordanlee2393 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-07-2015 07:11 PM
FI and wheel size. Adeets Forced Induction 41 05-24-2013 01:23 AM
Wheel Size vs. Balance jellygorilla Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-11-2012 02:23 PM
