Old 10-28-2015, 12:42 AM   #1
FRSssh
Drives: Asphalt grey
Wheel size needed
I'm wanting to get the 5 spoke wheel by Enkei Kojin, what size would I need to fit my Stock hieght Scion FRS? Please help!
FRSssh is offline   Reply With Quote
Old 10-28-2015, 01:00 AM   #2
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Any of them, as long as they're 5x100. I believe they're available between +35 and +45 offset, so really any of them will fit. The 17x9 and 18x9.5 with a +45 offset may rub in the front if you go with super meaty tires (like 255+ width).
The important question here is which tires do you plan on running? If you want to re-use the stock tires, you can run the 17x8 in whatever offset's available.
jawn is offline   Reply With Quote
tire size advice needed marcom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 09-08-2015 03:45 PM
Nut size needed for overpipe to exhaust manifold raven1231 Engine, Exhaust, Transmission 0 06-11-2015 12:37 PM
Tire/wheel size help needed gdrider77 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-28-2014 07:39 PM
DIY: Hellaflush with any wheel size, width, offet (no tools needed) ZionsWrath Off-Topic Lounge [WARNING: NO POLITICS] 24 09-01-2014 05:54 PM
wheel info needed loogs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-04-2013 05:47 PM
