Old 08-26-2016, 12:01 AM   #15
The car is light enough to get a feel for exactly when the clutch begins to grab by staging it on a flat surface with the engine off, putting it in gear, and pushing it backward with your left foot while feeling for the grab with your right.
Old 08-26-2016, 12:55 AM   #16
benlaz88
Drives: 2013 Asphalt FRS
Ok so i realize after driving for a while today after the adjustment, the shifting is much easier to get in gear from stop but it still have gear block the first try. However it im able to get in second try with no problem. I dont know if i didnt adjusted high enough but i will adjust again tomorrow and see.
Sent from my SM-G935V using Tapatalk
benlaz88 is offline   Reply With Quote
Old 08-26-2016, 01:23 AM   #17
Maybe easy for you to do, at your size and weight .........
Old 08-26-2016, 01:26 AM   #18
Yeah, I guess you might have a point. I'll see if Mrs. Ultra can do it. Can you?
Old 08-26-2016, 01:48 AM   #19
Heck, I don't reckon I could .........
To get my recycle bin out of my garage, I have to roll the car up about a foot .... yep, level garage, get er rockin a couple times and P-U-S-H with all my might and I can barely move it about 12 inches.
humfrz - old 190 pound weakling ..........
Old 08-26-2016, 02:03 AM   #20
Oh, ok. I'll update my proposed methodology. Find a gentle downhill slope...
Old 08-26-2016, 02:54 AM   #21
Us mere mortals thank you .......
Old 08-26-2016, 03:21 AM   #22
lol
G'night, sir.
humfrz (08-26-2016)
Old 08-26-2016, 09:56 AM   #23
Or...
Sit in car.
Depress clutch.
Start car.
Put in first gear.
Release clutch until car starts to move.
Grab point found.
Ultramaroon (08-26-2016)
Old 08-26-2016, 10:32 AM   #24
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
Did you BLEED the system?
Before all this other crap, this sounds like a classic case of air in the hydraulics.
If the shift fork was bent, sitting there for a few extra seconds with the pedal depressed wouldnt fix it.
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
Old 08-26-2016, 12:22 PM   #25
benlaz88
Yes i did bleed the system. I will try to bleed the system again and see.
Old 08-26-2016, 01:52 PM   #26
Or...
Sit in car.
Depress clutch.
Start car.
Put in first gear.
Grab point found.
I made the point more in an effort to demystify the clutch. I think if you try it you may find that because the mechanical advantage is reversed, it becomes more obvious.
Tcoat (08-26-2016)
Old 08-26-2016, 09:22 PM   #27
benlaz88
Correct me if im wrong on the bleeding. Depress the cluth pedal and hold it. Than open the bleed value to let the fluid out. Than close the valve. Than lift back the pedal up and repeat.
Old 08-26-2016, 09:39 PM   #28
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Something isnt right. Drop your trans and inspect
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Loud Hum/Grinding Noise + Vibration in 5-15mph gear range, in gear and rolling neutrl jakebrz Issues | Warranty | Recalls / TSB 14 06-06-2016 07:28 PM
Anyone experiencing 2nd gear problem? seominjung BRZ First-Gen (2012+) — General Topics 37 08-15-2015 01:32 AM
2nd Gear Syncro Problem nashsnazzy Issues | Warranty | Recalls / TSB 22 07-14-2014 10:20 AM
After Market Problem Signals Fuse Popped- Car Wont Go into Gear ScionFR-S Issues | Warranty | Recalls / TSB 14 11-20-2012 03:34 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
