Old 07-27-2016, 03:34 PM   #1
Shady195
Drives: '13 10 Series FRS #1203
ACT Clutch Adjustment Problem
Hey everyone, first off let me say I'm not new to replacing clutches, nor am I a stranger to more aggressive setups.
I installed my ACT SB8 Setup, full face disc setup, HD Pressure plate with prolite flywheel, got everything adjust to where I want but after a few days it seems off again.
My biggest issue, and well not an issue but more of a "desire" is for the pickup point of the clutch to be a little bit off of the floor, somewhat like stock.
Originally when I adjust the pedal it felt like I had that, there seemed to be a good half inch of travel before i could feel the clutch bite. However today it feels like its nearly right off the floor. Clutch fork is in the same place I had it, nearly screwed all the way out, clutch switch is also adjusted, but i dont think that would really affect my engagement coming off the clutch, just getting onto it.
Clutch feels fine otherwise, but I do daily my car and if I can make my life a little easier I'd love to.
If anyone has any tips/insight to this I'd appreciate it. While I don't generally hold my clutch in when stooped, when say i go down to NYC, getting on and off the clutch frequently is common in stop and go, and the engagement point right off the floor makes for a REAL pain in the ass
#firstworldproblems
Shady195 is offline   Reply With Quote
Old 07-27-2016, 04:50 PM   #2
CSG Mike
CSG Mike's Avatar
Let it break in more.
Shady195 (07-27-2016)
Old 07-27-2016, 04:50 PM   #3
ryoma
ryoma's Avatar
my guess is that you still need to break in your clutch over a few hundred miles (or even 1000) before everything will normalize.
The Following User Says Thank You to ryoma For This Useful Post:
Old 07-27-2016, 05:01 PM   #4
Shady195
Has about ~400 miles on it right now..
I figured that might be the case, as some material wears down the engagement point gets easier, which is why im suprised after adjusting it initially it seems like the pickup point is right at the floor again.
Seems fine otherwsie, I guess I'll just need to continue to roll with it. It's a great clutch setup overall, my only real complain more so than that is the gear lash when decelerating, definately noticeable outside of the car
Old 07-27-2016, 05:40 PM   #5
CSG Mike
CSG Mike's Avatar
You should not be getting clutch buzz. How carefully did you torque everything down? Was it done evenly little by little or just zipped on with power tools?
This car is very sensitive to that.
Old 07-27-2016, 05:43 PM   #6
Shady195
Its very quite, its only noticeable on decel around 2-3.5K RPMS, it was the same with the stock setup just not really audible
Gears chatter a bit with the A/C on as well.
I do have some stuff 92A Poly mounts for the trans
I tightened everything down in a star pattern per ACT's guidelines and used loc tite on the threads
Keep in mind I have the Prolite flywheel, not the street lite, and ive read around and was told the Prolite will still make noise.
Old 07-27-2016, 05:50 PM   #7
CSG Mike
CSG Mike's Avatar
Ah, you'll get a bit of chatter with the prolite. It was not really designed for the casual street user, but it's still pretty minimal. That's what's on the CSG BRZs and the shop cars have no chatter, but YMMV.
Shady195 (07-28-2016)
Old 07-27-2016, 05:54 PM   #8
Shady195
I ordered it by mistake, my deadline was tight where i'd be able to do it without being on my back in my driveway so I said screw it, worse comes to worse ill swap it out at somepoint..
I'ts not bad, I don't mind it so much. Just kinda awkward when people look at my car deceling in town
The Following User Says Thank You to Shady195 For This Useful Post:
CSG Mike (07-27-2016)
Old 07-28-2016, 02:24 PM   #9
Shady195
SO I played with the slave arm adjustment a little more. Though I was worried it would not "disengage" the clutch all the way if I brought it in more I decided to anyways..
I was fearful I had it adjusted so far that maybe I had over extended the pressure plate fingers or maybe bent the pivot arm
Well my engagement point seems about the same as it was, still pretty much right up off the floor but its actually a bit easier to feather the clutch out with throttle without it feeling like its grabbing so quickly, it is engaging fully when i get off the pedal so I'm not worried about that
Guessing it just took some trial and error to find the "Sweet" spot.
Old 10-11-2016, 03:13 PM   #10
BRX
BRX's Avatar
Drives: Toyota GT86
I installed my ACT SB7 clutch with the normal flywheel and I have the same "feeling" you describe. Backing out the garage I only need to lift the clutch pedal less than half an inch to get it to engage. The engagement point later on varies depending on how warm the transmission is. If it is cold it catches early on, once it warms up it won't engage until the pedal is half way up. And whenever I get the engagement point wrong in first gear it shakes the whole vehicle before it gets up to speed. Once I'm out of 1st it drives like a dream.
I'm thinking of going back to the stock flywheel and getting an SB clutch or something just to keep a consistent engagement point as this seems a bit silly and slightly ruins the enjoyment of driving in town.
BRX is offline   Reply With Quote
Old 10-11-2016, 08:33 PM   #11
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
Im using the extreme plate with nornal fllywheel and disc not puck, also deleted the spring on the peddle and the car drives fantastic. Heavier peddle like a v8 and never get a floaty feel. Never once adjusted the pedal. Always have full control and feel the engagement and disengagement.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 10-11-2016, 09:14 PM   #12
simpleisbest
Senior Citizen
Drives: Scion FR-S
Check your slave cylinder to make sure it is actually moving without any delay or hesitation. If it is good, it is possible your clutch fork may have bent due to the higher clamping force of the ACT kit.
simpleisbest is offline   Reply With Quote
Old 10-12-2016, 02:28 PM   #13
BRX
BRX's Avatar
Drives: Toyota GT86
Spring was removed when I first bought the car and mine too drives great once it gets rolling. I just hate stopping at traffic lights and driving in heavy stop and go traffic. Sometimes it goes perfectly, other times I either lift my feet too much and it shudders or I don't lift enough and it burns up the clutch a bit. It was NOT like this with the factory clutch.
I'll check out the slave cylinder. However I doubt it's the fork as it drove like this since I put the transmission back in with the ACT clutch. Another thing to note, I had to adjust the pedal position a lot after installation. It would actually stall when stopping in gear as pressing the pedal all the way would not disengage the clutch before it would warm up. That might be due the clamping force as I was still able to shift gears regardless
Old 10-19-2016, 04:02 AM   #14
simpleisbest
Senior Citizen
Drives: Scion FR-S
Sounds like your clutch fork could be already bent. If it is your slave, then simply pop the hood, squeeze the slave cylinder boot to see if there is any collection or hydraulic fluid and check your clutch fluid reservoir to see if you lost any fluid. Considering you needed to adjust the pedal so much to just get the clutch to disengage though, sounds like a bent fork.
Clutch height adjustment Hugo AUSTRALIA 13 04-30-2020 02:12 PM
Clutch Adjustment Issues!! FT-86- Scion FR-S / Toyota 86 GT86 General Forum 39 05-28-2015 10:29 PM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 02:10 AM
Easy Clutch Grab Adjustment frsfreak Southern California 2 03-28-2014 05:13 AM
Clutch Adjustment Concern ZackZ Scion FR-S / Toyota 86 GT86 General Forum 19 09-07-2013 06:01 PM
