Old 06-29-2016, 01:10 PM   #1
FNCrazy
Rambling Man
FNCrazy's Avatar
Drives: 2013 FR-S 6MT - In Heaven Now
Final Gear Ratios
I know this may not be the right subforum, but I had a question after Jay Leno mentioned it.
I have no need (anymore) to go 130+ in my car. What everyone seems to be seeking is more acceleration. Instead of bolt ons, Cai, etc, couldn't you change the final Gear ratio to achieve a little more acceleration while sacrificing top end?
Just a layman's (and Jay Leno's lol thoughts)
Oh, and first post, love it here!
Sent from my SM-G935V using Tapatalk
FNCrazy is offline   Reply With Quote
Old 06-29-2016, 01:43 PM   #2
gramicci101
Off Topic
Increasing the ring and pinion ratio will sacrifice top speed in favor of acceleration. Like you said though, you don't really need to run at top speed. However, it will raise the RPM for a given speed. So if previously you were cruising at 70 mph at 3K RPM, now you might be cruising at 70 mph at 3.4K RPM. That kind of thing.
It's a pretty popular mod for the A/T guys; there are plenty of threads about it.
Old 06-29-2016, 01:53 PM   #3
FNCrazy
Rambling Man
FNCrazy's Avatar
Oh! So a little more work for the engine and worse gas mileage?
Old 06-29-2016, 01:55 PM   #4
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
You'll gain in feeling, but not on actual results. You'll accelerate stronger in each gear, but overall you'll use a higher gear (3rd instead of 2nd, 4th instead of 3rd, etc). How often it depends the final drive ratio. We discussed it many times and you can search the forum history. If you need more acceleration, the best approach is to have more power or less rotating mass.
The Following User Says Thank You to nikitopo For This Useful Post:
Icecreamtruk (06-29-2016)
Old 06-29-2016, 01:56 PM   #5
gramicci101
Off Topic
Yep. As with most vehicle mods, it's a trade-off. It's supposed to make a decent improvement in acceleration though, so for some people it's worth it.
Old 06-29-2016, 02:00 PM   #6
FNCrazy
Rambling Man
FNCrazy's Avatar
So for the power I want, it's about 5-6k plus odd bits I don't know about.
So what's this rotating mass you're talking about?
I promise to do more searching, but I seem to find posts that only partly answer my questions. I'll work harder!
Old 06-29-2016, 02:06 PM   #7
gramicci101
Off Topic
Rotating mass is everything that rotates due to the engine turning. Engine internals, pulleys, the flywheel, transmission internals, driveshaft, diff internals, axles, brake discs, wheels, and tires. These all represent a significant amount of weight, and power spent turning all these things around is power that could be going to the ground to move you forwards. Obviously, some things you're not going to be able to change. However, you can lighten the pulleys, flywheel, driveshaft, brake discs, and wheels pretty easily. Less weight requires less power to move the weight and allows more power to be put to the ground.
But there are tradeoffs. A heavy (OEM) flywheel has a lot of inertia, so when you push the clutch in to shift, the RPMs drop slowly instead of plummeting. This makes for smoother shifts with less fucking up. A lighter flywheel has less mass, so less inertia. Now when you push the clutch in the RPMs drop like a rock. Your shifts need to be on point, every time, or they're going to suck.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
avishenoy1 (06-29-2016), nikitopo (06-29-2016)
Old 06-29-2016, 02:58 PM   #8
avishenoy1
avishenoy1's Avatar
Drives: 2015 FR-S Release Series 1.0
Excellent explanation of the tradeoffs of rotational mass reduction. This will theoretically net you faster acceleration, however there are many other factors involved. The same goes with changing the final drive, you will accelerate faster at lower speeds with a higher final reduction ratio since you will be in the power band sooner, but you also sacrifice acceleration at higher speeds when you're stuck in 5th or 6th.
Edit: For Automatic owners this is usually a very good tradeoff, since it makes the longer gearbox ratios more similar to the manual in terms of acceleration. Since 6th is so overdriven in our tranny, it's really only useful for cruising and offers very little in terms of acceleration since you're near the top speed of the car well before redline in 5th with the stock ratios.
avishenoy1 is offline   Reply With Quote
The Following 2 Users Say Thank You to avishenoy1 For This Useful Post:
gramicci101 (06-29-2016), nikitopo (06-29-2016)
Old 06-29-2016, 03:04 PM   #9
gramicci101
Off Topic
Agreed. There are tradeoffs to everything. I love my drivetrain bushings; they remove a lot of slop out of the drivetrain. But at the cost of higher NVH. I'm ok with that, but it's good to know what the cost will be before committing to something.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 06-29-2016, 04:47 PM   #10
FRS Justin
Drives: 2013 Asphalt FRS
SO what are you really wanting? Be specific so you can get sound advise.....
I have run just about every ratio you can think of.
Just remember you cant have both ways. If you want a gear to race light to light on the street or to give you the ability to drift the car with ease no problem but you wont be going 140mph anymore more like 120mph to get those results but a lot goes into picking the right ratio. Tire size, weight, RPM's, Manual or auto trans, just to name a few..
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following User Says Thank You to FRS Justin For This Useful Post:
FNCrazy (06-29-2016)
Old 06-29-2016, 04:54 PM   #11
FNCrazy
Rambling Man
FNCrazy's Avatar
Thanks Justin...
I don't have it 100% decided overall, but here's what I've got so far. All stock 6mt, with possibly a cat back and some lesser performance mods at most.
Maybe 115, 120MPH top speed (depends on how much it helps acceleration), but I've gone way over 150 plenty of times, and having a son now, that no longer interests me. Also, I'm not going to be "stop light to stop light," but I guess you could put it that way. I can't see on this phone if I've answered all your questions... If not, follow up coming
Old 06-29-2016, 04:56 PM   #12
FNCrazy
Rambling Man
FNCrazy's Avatar
I would like to replace my wheels and tires at some point, but sticking with 17's. And just to be clear, we are talking rear end gear right?
Old 06-29-2016, 05:32 PM   #13
FRS Justin
I would run a 4.56 ratio then it will still let first gear be usable and have a lot more bottom end. 120mph will be easy to reach in 6th 5th gear will max out around 104mph. The most I would do is a 4.88 but that is a extreme street gear and first is pretty useless.
When your ready to get a set call Mark at spencer fab in N.H. he will hook you up.
710whp
Old 06-29-2016, 05:36 PM   #14
FRS Justin
Yes rear diff gears,
I ran a 13.58 1/4 mile with a 4.56gear
[ame="https://www.youtube.com/watch?v=o6uvBexBYX8"]Copy of 13.58 FRS Pass - YouTube[/ame]
710whp
Where to buy LSD & Final Drive/Gear? GT86_PRAGUE User/Vendor/Sponsor Reviews, Feedback, Comments 4 01-09-2015 08:42 PM
Tuning adjustments for different final drive ratios? PantsDants Software Tuning 9 01-29-2014 04:18 PM
Guesses about Gear Ratios and Wheel Torque Deslock Engine, Exhaust, Transmission 63 08-27-2013 02:42 AM
any way to change the gear ratios in manual? SuperDave Engine, Exhaust, Transmission 17 10-19-2012 11:07 PM
Guesses about Gear Ratios and Wheel Torque Deslock BRZ First-Gen (2012+) — General Topics 4 12-01-2011 07:15 AM
