Old 06-27-2016, 12:56 PM   #15
ka-t_240
I wouldn't worry about it, the dealer won't fix or replace anything. I see it under the dash all the time.
ka-t_240 is offline   Reply With Quote
Old 06-27-2016, 12:56 PM   #16
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Originally Posted by PandaSPUR View Post
WD40 will make it real easy to scrub off surface rust.
But be warned, WD40 is a "penetrating oil and water-displacing spray" its not actually meant as a lube. So your squeaking problem might fix itself for a little while but it'll come back.
Spray with WD40 to clean off the rust, and then find some actual lube and apply to moving parts.
Everytime I tell people WD40 is a cleaner spray I get this:
If Bimmer owners see this kind of rust they'll park it in front of the dealer and burn it down.
krayzie is offline   Reply With Quote
The Following User Says Thank You to krayzie For This Useful Post:
Tcoat (06-27-2016)
Clutch Pedal rick s Engine, Exhaust, Transmission 51 09-20-2015 11:08 AM
Clutch Pedal Adjustment? EAGLE5 Northern California 41 05-20-2015 02:10 AM
weird noise from clutch pedal area... mongiamc10 Issues | Warranty | Recalls / TSB 5 08-08-2014 07:04 PM
Anyone in Tacoma area willing to help with clutch pedal? EpidemicFRS Northwest 9 03-15-2014 05:02 PM
Anyone know how to stiffen the clutch pedal? 86main Engine, Exhaust, Transmission 3 03-01-2014 04:45 AM
