Old 06-20-2016, 09:25 PM   #15
el-92
el-92's Avatar
Drives: 2014 ASPHALT FR-S MT
Yes sir, more grip means more roll. Swaybars are an easy way to go and an adjustable set gives you some tuning options. Stiffer springs work too.
Remember a little roll is OKAY...but if you're rolling excessively and uncomfortable with the car's handling then yes some swaybars are a good next step.
- Andrew
Cool thanks I'll be ordering your sway bars soon 😎👍🏻
el-92 is offline   Reply With Quote
The Following 2 Users Say Thank You to el-92 For This Useful Post:
Racecomp Engineering (06-21-2016), smg1138 (06-21-2016)
Old 06-21-2016, 07:19 PM   #16
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
- Andrew
@Racecomp Engineering Are the RCE swaybars good for AutoX or mostly designed for track? I've read different things about adding a stiffer bar in back. In currently running a 20mm Whiteline bar up front and stock rear.
smg1138 is offline   Reply With Quote
Old 06-24-2016, 12:11 PM   #17
It depends on the rest of your set-up. For an STX car that's already on coilovers with 400/400 rates, the front 20mm bar is probably all you need. If you were stuck with running softer springs, then I would recommend them.
Also for an SM car on hoosiers, the bars would be helpful IMO.
- Andrew
smg1138 (06-24-2016)
Old 06-24-2016, 06:30 PM   #18
smg1138
smg1138's Avatar
- Andrew
Yeah, I'm running in STX on Tarmac 2's with the 400/400 rates. Thanks for feedback.
The Following User Says Thank You to smg1138 For This Useful Post:
Racecomp Engineering (06-25-2016)
coilovers, rce, tarmac, tarmac 2
RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 589 11-21-2021 05:13 PM
***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** FT-86 SpeedFactory Brakes, Suspension, Chassis 208 09-30-2016 04:43 PM
Recommended tire choice for 18x9.5 +40 all round setup? KruszR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 01-18-2014 04:04 PM
Damper crosstalk ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 08-01-2013 03:21 AM
