Old 06-10-2016, 01:51 PM   #1
Norinradd
Drives: 2013 frs
Dealer flashed ecu now cel and tcs unscannable
Car was idleing odd. Dealer flashed ecu with software to fix it. Didnt chsnge idle issue. Cleaned my maf sensor with maf sensor cleAner and i put new oiled airfilter on intake. Car went to shit. Sputtering stalling. Check engine light, slip indicator light. Went back to dealer. They tried to read codes and the car was a ghost. Obd Wouldnt evenrecognize the car. Didnt find anything. It has NEVER been tuned
Why couldthe dealer update ecu but not read codes? Ifeel they screwed it up
2013 silver frs, injen intake, agency power header, hks exhaust, no kitties, ecutek tune
Norinradd is offline   Reply With Quote
Old 06-10-2016, 01:54 PM   #2
fumanchu1
Drives: 2013 Brz C38 (bought not built :P)
Why are you creating a duplicate thread to discuss the same issues? Also wouldn't this be a better idea in the software or engine section as opposed to the TSB section?
fumanchu1 is offline   Reply With Quote
The Following User Says Thank You to fumanchu1 For This Useful Post:
86kahl (06-10-2016)
Old 06-10-2016, 02:15 PM   #3
Norinradd
Drives: 2013 frs
I have no idea what "tsb" means. Its an issue do dowith dealer. Other posts title isnt accurate to the issue
Old 06-10-2016, 02:19 PM   #4
Vampyre
Vampyre's Avatar
Drives: 2014 FR-S Asphalt
Technical Service Bulletin. Usually how they release info on recalls.
Vampyre is offline   Reply With Quote
The Following User Says Thank You to Vampyre For This Useful Post:
Norinradd (06-10-2016)
Old 06-10-2016, 02:55 PM   #5
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Hmmm maf cleaner... For this car I don't recommend.... Our maf is so sensitive.
Anyway, take back to dealer.
Btw, after reflash I had to run my car like 40min so codes could be read.
The Following User Says Thank You to Packofcrows For This Useful Post:
Old 06-10-2016, 02:59 PM   #6
Norinradd
Drives: 2013 frs
Ah yes i had my battery unplugged all day as well. I figure im only 15 minutes from dealer so maybetje ecu hadnt fully rebooted yet
Old 06-10-2016, 07:09 PM   #7
86kahl
86kahl's Avatar
Drives: whiteout, dark tint
Totaled.
86kahl is offline   Reply With Quote
The Following 3 Users Say Thank You to 86kahl For This Useful Post:
continuecrushing (06-14-2016), dnieves (06-14-2016), Spartarus (06-11-2016)
Old 06-10-2016, 07:53 PM   #8
Norinradd
Drives: 2013 frs
Originally Posted by 86kahl View Post
Totaled.
Old 06-10-2016, 07:54 PM   #9
Packofcrows
Takes longer. I used to reset ecu when smogging.....other car.... and i always had my mechanic (smog person) pissed off that i didnt run my car long enough. Was usually about 40min of driving it. Letting it warm up while sitting didnt ever seem to do the trick.
Tcoat (06-11-2016)
Old 06-11-2016, 02:59 AM   #10
86kahl
86kahl's Avatar
Old 06-13-2016, 10:41 PM   #11
Norinradd
Drives: 2013 frs
Car runs amazngly and no lights come on until about 40 minutes of driving. Then CEL comes on and car runs like poop.
Old 06-14-2016, 09:25 AM   #12
stevesnj
stevesnj's Avatar
Maybe take it to another dealer?
My 2016 Build thread
Old 06-14-2016, 01:57 PM   #13
Norinradd
Drives: 2013 frs
Ithink ihave a pretty good theory on what happend. Car was not tuned previously. Injen intake had maf sensor on threshhold. Once the dealer reflashed ecu to i assume recalibrate maf sensor trim for idle sputter that it threw my injen intake even further off. Hence the light coming on and it running worae. If only ONE PERSON in lowermainland could have a damn stock intake for me to test this theory
Old 06-14-2016, 02:36 PM   #14
jasonojordan
Drives: 2013 satin white brz limited
so you have an intake but no tune....
jasonojordan is offline   Reply With Quote
Just flashed OFT Stage 2 UEL Luftwaffel Software Tuning 14 11-30-2015 10:33 PM
Just flashed 2015 FRS with OFT Flat_4_Life Software Tuning 4 03-23-2015 10:22 PM
Anyone one flashed back and had a problem at the dealer? (chirp chirp chirp) OkieSnuffBox Software Tuning 16 11-18-2014 05:56 PM
Flashed ECU Djen Software Tuning 5 08-13-2013 10:00 AM
What car is flashed in the Mazda 3 commercial Yruyur Other Vehicles & General Automotive Discussions 10 03-29-2013 01:23 PM
