| Software Tuning Discuss all software tuning topics. |
Drives: Blue Subaru Brz
4 bar map sensor on complete stock brz
Hi so I just but my brz back to stock. I had an ecutek tune with the ptuning turbo kit. I have not been able to find a stock map sensor and a new one is $300. I was wondering if I could just use an aftermarket 3 bar or 4 bar map sensor on a stick brz since they are about $100?
#2 | |
Drives: UK GT86
.: Stealth 86 :.
#3 |
map sensor scaling
#4 | |
Drives: FT86
you will need access to a flash system anf ecu rom editor if you have ecutek cable/licience ect you wll be able to do it find the MAP multiplier and offset tables in the tune tables and change the two parameters to suit the MAP sensor, o it might just be easier to get a used stock MAP sensor from an auto wreckers/recycler Omni 2.5 Bar MAP The OFT300 (Vortex supercharger) map uses the 2.5 BAR Omni and has CEL-P0068 disabled in the map ok for 2.5 Bar OMNI MAP sensor ECUTEK scaling in BAR Manifold Pressure Sensor multiplier in bar per volt. = 0.500 Manifold pressure sensor offset. Value is measured in bar. = 0.100 MAP Sensor voltage max = 5.0v MAP sensor Voltage min = 0.0v Omni 3 Bar MAP Sensor (Metric in Bar) 0.617 - MULTIPLIER 0.03 - OFFSET scaling limits 0 - 4.75v Omni 4 Bar MAP Sensor Manifold Pressure Sensor Scaling - (imperial PSI) Multiplier - 12.087 Offset - 0.168 Metric/Bar bar/volt .833 offset (bar) .012 Manifold Pressure Sensor Limits - (CEL still comes on ) High Input CEL Above - 5.00v Low Input CEL Below - 0.00v Disable CEL P0103 and P0068 |
#5 | |
#6 | |
Road-hole
Drives: 2013 Whiteout FR-S
I'll trade you.
Jaden |
#7 |
#8 |
Road-hole
ok...
| WTB: Stock MAP sensor, and stock port injectors | Agent_D | Want-To-Buy Requests | 2 | 05-25-2016 06:08 PM |
| WTB stock rear tophats or complete stock suspension | s13kid989 | Want-To-Buy Requests | 3 | 10-09-2014 08:11 AM |
| WTB: Stock MAP Sensor, Stock Frontpipe, Stock Midpipe. | Sterz | Engine, Exhaust, Bolt-Ons | 4 | 07-02-2014 10:22 PM |
| Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? | Acree | Engine, Exhaust, Transmission | 2 | 08-26-2013 07:39 PM |
| FS: Stock Wheels+Stock Tires+TPMS sensor | Pin Flare | Wheels and Tires | 1 | 03-26-2013 12:07 PM |
