#561 | |
Noticeably better, however e85 is much faster as to be expected, so if you have e85 stick with it, but if you plan to go back to pump 93 or 91 use it.
#562 |
Drives: '22 BRZ
Nope, can't get E85 anywhere (the one local place NEVER has it, but every time I drive by they're advertising it... morons)
#563 |
Then this new tune is worth it, the power band feels more punchy in the lower 2k-5k range, and then it comes alive after that. It's almost more linear.
| The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post: | DocWalt (05-25-2016), FrostedFlakes (05-25-2016) |
#564 | |
Sent from my Nexus 6P using Tapatalk
| The Following User Says Thank You to D_Thissen For This Useful Post: | tdotBRZ (05-25-2016) |
#565 | |
Drives: 2014 BRZ Limited SWP 6MT
| The Following User Says Thank You to tdotBRZ For This Useful Post: | D_Thissen (05-25-2016) |
#566 | |
Drives: FR-S Whiteout
I'm curious to see what kind of maf voltages you are hitting with the setup. It looks like with the UEL setup and cam timing you can still run a lot of ignition advance at the very top end past 6000rpm. From experience, I know that colder IAT's will register higher maf voltage compared to warmer IAT's. (typically higher maf v = more whp) Though I'm not sure if that just how the maf sensor reacts to different temps or if it's because of the denser air charge at lower temps and the maf sensor reading is accurately reflecting the increased air flow at lower temps.
Intent > Content
cowardice is the mother of cruelty. |
#567 |
Drives: Asphalt FR-S MT
New Stage 2 UEL (91-93 and E85) OTS tune files
Completely "fixed" what I thought was wrong with the car. The car now has at least adequate power for the chassis it has.
And even better it has had adequate power all the through out the power band (no torque dip) It's still no drag car but at least it doesn't feel like the car is dragging an anchor behind it anymore Sent from my iPhone using Tapatalk |
#568 | |
You should try e85
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | Kronos (05-25-2016) |
#569 | ||
Load = (MAF g/s)/rpm*60 Thus: - At the track on v2.074 tune, my engine load peaked around 1.31 @ 6871 RPM. Doing a quick reverse calculation, peak MAF = 150.0 g/s. IAT was 61 F. - With the OFH aggressive tune, my engine load peaked around 1.23 @ 7177 RPM. Peak MAF = 147.1 g/s. IAT was 95 F. (I compared my average MAF numbers vs. those in the track log posted by @tdotBRZ and they were slightly lower, which makes sense given he also has a greddy intake. Ambient temps look to have been similar.) - At the track with stage 1, my engine load peaked around 1.13 @ 6954 RPM. Peak MAF = 131.1 g/s. IAT was 81 F.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | solidONE (05-26-2016) |
#570 |
MAFv is affected by temperature, that's why there's an IAT comp table. It just doesn't seem to do a very good job because fuel trims still change between hot and cold days.
#571 |
There is a tool in VGI's tool that was done by Kodename47 to help rescale the MAF temp compensation table. I've done some adjustments to the table and am happy with the results where fluctuating IAT doesnt have as much of an effect on fuel trims than the stock tables. Although, most just leave it alone an scale their MAF to average IATs.
Intent > Content
#572 | |
Intent > Content
#573 |
Did some hot weather (85-95 F) testing today. 30 miles of highway. Then four 2nd gear pulls and a 3rd gear pull. FLKC gradually grows with each successive run, ultimately pulling 2.6 to 3.9 timing from 6800 RPM to redline on the 3rd gear pull. This tune is definitely a little aggressive on my car, probably not ideal for track.
http://datazap.me/u/darksunrise/ofh-...zoom=6206-8714 The rest of the hot weather logs looked ok. FLKC and KC stayed below -0.69, except two instances of KC of -1.41 @ 3300 RPM and -2.81 @ 3800 RPM. IAM stayed solid at 1.00 the whole time. I'm thinking this tune might be ok to track on with 3-4 degrees less timing from 6700 RPM to redline. Or perhaps more timing compensation but not sure whether to adjust for coolant temps or IATs, as I didn't see a strong correlation in the logs. @solidONE - I recorded MAFv on these logs. I think I remember seeing peak values around 4.01v on some runs. Interested to hear how that compares.
#574 | |
Drives: 2013 Raven FRS
| Just how noticeable is OFT+OFH and stage 2 tune? | BBYZILA | Software Tuning | 58 | 03-20-2018 12:56 PM |
| OFT 2.0 Stage 1 93 Tune | MurderRider | Software Tuning | 57 | 03-21-2016 01:30 AM |
| Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 09:15 PM |
| FA20club.com Turnaround Times On Modified Tune Files | FR-S Matt | Software Tuning | 103 | 11-13-2013 02:48 PM |
| So whate does stage 3 tune do? I already have 2 | Frsexxxy | Engine, Exhaust, Transmission | 17 | 05-14-2013 07:30 AM |
