Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 05-20-2016, 08:56 PM   #1
Bodalenko
Steve Bodalenko
Drives: Toyota 86 GTS
Header heat cycling and retighten.
Title says it all.
I know the header nuts should be tightened to 22 ft/lbs but wondering;
1. How many heat cycles people are doing before retighten?
2. Should headers/nuts be tightened when headers are stone cold e.g. First thing in morning, or while touchable warm after final heat cycle.?
Posted this in the open forum but need info reasonably quick..
Bodalenko is offline   Reply With Quote
Old 05-20-2016, 09:07 PM   #2
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
1. Imho, just "1" heat cycle, all you are really doing is warming up the header to accounting for thermal expansion
2. As mentioned above, I would torque it down while warm.
The Following User Says Thank You to BigFatFlip For This Useful Post:
Bodalenko (05-21-2016)
Old 05-22-2016, 05:20 AM   #3
dratom
Drives:
I retorqued after 1 heat cycle while cold. I think only one nut moved. Torque values would be at room temperature.
dratom is offline   Reply With Quote
The Following User Says Thank You to dratom For This Useful Post:
Bodalenko (05-22-2016)
Old 05-22-2016, 07:50 AM   #4
Bodalenko
Steve Bodalenko
Gave it a couple of heat cycles then let it cool to almost room temp. Torqued to 22 ft/lb and all good. No rattles and no leaks. Had to remove the Nameless and reinstall the OEM. Nameless with 4" resonators is just obnoxiously loud. OEM is quiet to point of boring but it'll have to do till I can get something that is somewhere between obnoxious and boring!
P&L EL HEADER/P&L OVERPIPE HEAT WRAPPED PERRIN CRANK PULLEY AND MORE Anthony7515 Engine, Exhaust, Bolt-Ons 6 06-22-2015 04:20 PM
Heated Seat Cycling im2lazy789 Issues | Warranty | Recalls / TSB 15 12-15-2014 02:44 PM
New Tire heat Cycling Lunatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-08-2014 07:29 PM
Heat cycled. forwallblakmail Tracking / Autocross / HPDE / Drifting 23 06-25-2014 11:45 PM
A/C cycling while driving Crazy Drew Issues | Warranty | Recalls / TSB 11 05-01-2014 05:54 PM
