Old 04-29-2014, 08:08 PM   #1
Crazy Drew
Drives: Smells like tires when I drive
A/C cycling while driving
So, as it starts to warm up down here in Texas I've decided to start using my a/c again. I bought this car late last year and only used the a/c for a couple weeks before winter hit. I've now noticed that while driving down the road (side streets and highway) that my a/c seems to be cycling on and off. Does anyone else have this problem? This is the first car I've had do this that wasn't over or under filled on freon.
I know it's normal for a compressor to cycle at idle in a car but this seems to do it all the time and the more load I put the a/c under the worse the temperature swings seem to get. As of right now it seems to cycle back and forth between really cold and warm about every 3-5 seconds.
I'm due for an oil change in a few hundred miles and I'll probably have the dealer look at it then. I'm mostly just curious if anyone else is experiencing this as a "known issue" or if I have an uncommon problem.
Crazy Drew is offline   Reply With Quote
Old 04-29-2014, 09:13 PM   #2
PMPB
Drives: BRZ Sport-tech
If I remember correctly, I think mine cycles on-to-on about every 15 seconds. I can tell because I hear the clutch 'tweet' as it engages.
PMPB is offline   Reply With Quote
Old 04-30-2014, 03:37 AM   #3
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Do you have automatic climate control? I've noticed this on my auto climate at any degree above 65 degrees.
N1rve
Old 04-30-2014, 05:37 PM   #4
Crazy Drew
I don't have auto climate control, just the standard FRS knobs.
@PMBP - Mine cycles at idle at a slower rate, maybe every 15 seconds. What I'm seeing though is a difference in air temperature coming out of the vents like the compressor is cycling while driving. My past experience with other cars makes me think I'm tripping either the high pressure or low pressure switches in the a/c system. The air never gets hot but while cycling I bet it changes about 10 degrees momentarily.
Old 04-30-2014, 05:51 PM   #5
t.chk
Drives: Subaru BRZ Limited
I have the automatic climate control and it turns it on and off as needed. When it is off it slow warms up till the system turns the A/C back on again. Also noticed it when you apply...generous power...it turns it off till you are done.
t.chk is offline   Reply With Quote
Old 04-30-2014, 06:36 PM   #6
HapaHaole
Drives: Grocery cart
if you are at WOT, it will cycle off. If the temp in the vehicle is being effected then you need to get it checked for either a bad pressure switch or evaporator temp sensor.
HapaHaole is offline   Reply With Quote
Old 04-30-2014, 08:13 PM   #7
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
It's perfectly normal for your A/C to cycle on and off even if you don't have "automatic" A/C.
billwot is offline   Reply With Quote
Old 04-30-2014, 09:43 PM   #8
PMPB
The A/C will always cycle, even when driving. It'd probably have to be driving through death valley on the hottest day to keep the A/C on 100% of the time. The fact that the air goes from back and forth between hot and cold at a rapid rate makes me think there is a problem with the interior sensor and it keeps switching between hot/cold. Because once the A/C cycles off, it's not like the evaporator core turns hot instantly, far far from it.
Old 04-30-2014, 10:28 PM   #9
DJCarbine
Thupercharged
DJCarbine's Avatar
I had a previous newer car that would cycle the AC excessively. Threw my gauges on and saw the pressure on the low side falling fast when the AC kicked on, but kept falling below the low limit cutoff. Added a bit more refrigerant to prevent it from falling below during AC operation (a VERY small amount) and the gauge read a steady low side pressure while on that corresponded to the ambient temperature. Never had it cycling like crazy again.
Throw a cheap gauge on the low side and see what sort of pressures you are reading when it cycles on/off. It MIGHT need more refrigerant, but cycling (not excessive) is normal from what I understand. Specs on the limit switches might be in the service manual
TL;DR for everyone else-Put gauges on to see exactly what its doing, don't add refrigerant willy-nilly or overfill the system
::edit
More expensive gauges than normally found on an autozone R134 can are required for any thorough diagnosis, is the car still under warranty?
2013 FRS
Vortech V3 11psi
Old 05-01-2014, 12:00 PM   #10
Crazy Drew
::edit
Yeah, car is still under warranty. I'll have the dealer look at it this weekend when I get my oil changed.
I know just enough about a/c systems to get myself in trouble. That's what made me think it's slightly under or over filled. Much more likely to be under filled.
I'm working on a friend's a/c system this weekend. Autozone actually rents out full manifold gauge sets and vacuum pumps. Worst case if the dealer doesn't have time I'll throw some gauges on it myself. I considered last night wiring in some indicator lights real quick on the low pressure switch and compressor clutch to get a visual indication while driving. My main concern right now is burning up the compressor clutch if it really is cycling that often. As I've stated in my previous post it's about 3-5 secs between when I feel the air warming up and it getting cold again so I'm thinking it's cycling "excessively".
Old 05-01-2014, 02:52 PM   #11
HapaHaole
Does anyone know if the AC system has a sight glass?
SOLD: 2014 BRZ Limited WRB 6 Speed.
Old 05-01-2014, 04:54 PM   #12
DJCarbine
Thupercharged
DJCarbine's Avatar
def sounds like underfilled, throw a gauge on the low side and I bet its tripping the low limit
2013 FRS
Vortech V3 11psi
Driving on PCH through Big Sur was so fun wrb Northern California 4 12-02-2013 10:46 PM
Hot Key After Driving joelg Issues | Warranty | Recalls / TSB 12 07-10-2013 12:21 PM
Driving section - actually driving the things somewhere bcj Site Announcements / Questions / Issues 6 04-08-2013 11:28 AM
Driving in the wet Turdinator AUSTRALIA 47 11-28-2012 03:23 AM
Driving too much! F3dzo Scion FR-S / Toyota 86 GT86 General Forum 15 07-15-2012 01:14 AM
