Old 05-17-2016, 03:12 AM   #43
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Originally Posted by FRSBRZGT86FAN View Post
I'm confused why are people saying this gives more power and torque, all it does is remap throttle response. I won't believe this scam till someone shows dyno proof it gained power. This isn't a worthwhile mod, its a farce that gives you the assumption of speed, power and a "better torque range" as you described, buy an open-flash tablet and you can actually get some real results.
They provide a dyno map on their site:
http://www.sprintboosterusa.com/
The dyno is not related with our cars, but it gives a proof that it is not just a throttle remap for response.
Old 05-17-2016, 03:20 AM   #44
ryoma
ryoma's Avatar
this is what I don't understand. the thing plugs into the throttle pedal connector. it does not plug into the OBD2 plug to flash a new tune to the ECU. as far as I know, the throttle pedal connector does nothing other than send a voltage signal to the throttle plate and/or ECU. it does NOT read or write anything to the ECU.
with that said, how would this device change anything other than a more "responsive" throttle and add more power? the throttle plate can only open so much... you can't open it 120% for extra power.
Old 05-17-2016, 03:57 AM   #45
Kodename47
Kodename47's Avatar
Drives: UK GT86
It cannot give any more power. The throttle plate motor opens to its maximum position on the OEM settings. This is confirmed by logging the TPS voltages. All the ECU does is calculate the desired throttle valve from the pedal voltage, which is learnt. By changing the input does not mean that the output can be any larger. At all times on this ECU if you command WOT you get WOT. This isn't an FB20 where the torque and throttle tables are integrated with boost settings etc. It's purely for throttle plate mapping.
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-17-2016, 11:46 AM   #46
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Totally a false dyno map, dyno your car with and without it. You're being conned.
Old 06-17-2016, 05:02 AM   #47
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
A nice video that explains the details of sprintbooster. You can see also the delay in the throttle body:
[ame="https://www.youtube.com/watch?v=MyJtac6d05U"]Sprint Booster on 'Performance TV' - SEMA SHOW 2013 - YouTube[/ame]
Old 06-17-2016, 05:31 AM   #48
themadscientist
Hotlink Terrorist
themadscientist's Avatar
Drives: 2015 WRB BRZ Spec S
Throttle control used to be so affordable.
Old 06-17-2016, 05:48 AM   #49
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
You didn't watch the video.
Old 06-17-2016, 05:55 AM   #50
themadscientist
Hotlink Terrorist
You didn't get the point I was making.
Old 06-17-2016, 06:41 AM   #51
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Oh yes, apologies:
The Following User Says Thank You to nikitopo For This Useful Post:
themadscientist (06-17-2016)
Old 06-17-2016, 07:40 AM   #52
themadscientist
Hotlink Terrorist
TOYOTA EMBLEMS FOR YOUR FRS! @ PURE AUTOMOTIVE PERFORMANCE Pure Automotive Exterior Parts - The Rest 12 02-18-2013 06:36 PM
Anybody want to help me pick up my car at Pure Automotive? TyperRspec789 Mid-Atlantic 4 01-31-2013 03:07 PM
Anyone tried the Sprint Booster? Black Tire Engine, Exhaust, Transmission 6 01-27-2013 05:13 PM
Throttle Controllers harajukukei Engine, Exhaust, Transmission 31 07-28-2012 01:40 AM
