Old 05-03-2016, 05:09 PM   #1
Ryan_86
Ryan_86's Avatar
Drives: 2016 Scion FRS - Steel
Konig Oversteer 18x9 will it fit? help.
Planning on getting some better wheels and tires since the stocks are getting boring to me. Pretty new to all this stuff but wanting to know if a 18x9 wheel with an offset of +45 would fit well.
The car will be lowered on Eibach pro kits and I was trying to achieve the flushed look, spacers I feel are going to be required but was wondering what the width of them should be?
18x8 is an option as well if itll fit the car better, 9's are more concave and look better though.
Thanks!
Ryan_86 is offline   Reply With Quote
Old 05-03-2016, 05:24 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Read.
The.
Sticky.
Thread(s).
http://www.ft86club.com/forums/showthread.php?t=15007
http://www.ft86club.com/forums/showthread.php?t=7535
mixtape (05-04-2016)
Old 05-03-2016, 06:12 PM   #3
Ryan_86
Ryan_86's Avatar
theres like 200+ pages. I got some good info from there. They say that 18x9 will clear the stock struts by a few mm, so i would get some spacers, I just dont know the best width.
looking for a spacer mm balance between
clearing stock struts < (flushed, Front (x) mm, Rear (x) mm,) < sticking out way to far.
Old 05-03-2016, 06:20 PM   #4
mav1178
mav1178's Avatar
You can only run about a 3mm spacer on stock studs. Then you'll have to get bolt-on spacers if you don't want to change out wheel studs.
Bolt-on spacers under 20mm will be subject to whether the wheel backpad design can let you use the spacers to begin with.
-alex
Old 05-03-2016, 06:23 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
http://www.ft86club.com/forums/showthread.php?t=94628
Here is a link to my setup.
Ryan_86 (05-03-2016)
Old 05-04-2016, 05:40 PM   #6
djdnz
1337
Drives: 2013 BRZ WRB S/C
Thanks!
I test fit my 18x9 +42 wheels on stock suspension and there was maybe 2mm clearance in the front - too close for my comfort level. With a 18x9+45 you are 3mm closer to the strut than i was - so pretty sure you will not fit without spacer.
djdnz is offline   Reply With Quote
Old 05-04-2016, 06:33 PM   #7
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
You'll need spacers.
+35 is the best offset for this car if you plan on lowering & running camber on a 9" wide wheel. With enough camber you get very very minor poke, if you're at stock height you'll look like a monster truck lol.
I almost bought a +42 wheel but I decided I didn't feel like buying spacers & extended studs...not worth it imo no regrets
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 05-05-2016, 03:34 PM   #8
Ryan_86
Ryan_86's Avatar
my mistake the offset is +42, on the 18x9's, Probably will end up getting some spacers. just wondering the best width.
fit, spacers, tires, wheels
Konig Oversteer 18x8 + 18x9 Leonardo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 51 10-05-2018 11:59 AM
Wheel Directory: 16x7.5" Konig Oversteer NWFRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 04-10-2016 02:21 AM
Controlling Oversteer? Neokolzia BRZ First-Gen (2012+) — General Topics 29 09-22-2014 11:58 PM
frs oversteer in brz mechanical? swpbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 03-18-2014 10:48 PM
5x114.3 18x9 +35 Konig Torch Black/machined JoeBoxer Wheels and Tires 1 05-13-2013 10:08 AM
