Old 01-18-2015, 07:48 PM   #1
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Wheel Directory: 16x7.5" Konig Oversteer
I haven't seen these fitted yet.
16x7.5" Konig Oversteer in "Opal". Weight is 17.9lbs. Offset is +45.
Tires are a Yokohama YK580, 225 /50 R16 92V SL BSW.
I'm still on stock suspension.
NWFRS is offline   Reply With Quote
Old 01-21-2015, 08:48 AM   #2
R2KD
Drives: 13 FR-S Hot Lava
I was waiting to see someone throw these on their car. Looks as good as i thought it would.
R2KD is offline   Reply With Quote
Old 01-21-2015, 10:12 AM   #3
mkiisupra
mkiisupra's Avatar
Drives: 83 Toyota Supra, 16 FR-S RS2.0
Ditto, I was def stalking these wheels a couple of months ago, but sadly no pics at work,
Eric G
mkiisupra is offline   Reply With Quote
Old 01-21-2015, 10:20 AM   #4
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Those look sharp; I've had my eye on them for a while now, but was a little disappointed that a 16x7.5 wheel was nearly 18 pounds...
venturaII is offline   Reply With Quote
Old 01-21-2015, 11:26 AM   #5
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
I'm no wheel expert, but for this kind of money, I'm guessing that they're cast. Maybe they would have been pushing the limits of safety if they had made it 16lbs? Just guessing. As soon as a picture of a broken rim shows up on the internet it's all over-no matter how good they look. According to TreadDepot marketing: "The rim of the Oversteer was spun in a roll forging", whatever that means.
Available in:
Gloss Black.
Gloss White.
And Opal.
16x7.5 +45 17.9lbs
17x8 +45 19.lbs
18x8 +45 19.6lbs
18x9. +42 20.lbs
19x8.5 +45 21.2lbs
Old 01-21-2015, 12:13 PM   #6
R2KD
For our cars, these are also available in:
17x8 +45 19lbs
18x8 +45 19.6lbs
19x8.5 +45 21.2lbs
I was dead-set on these wheels the moment I saw them, about four months ago. I'm REALLY satisfied with how they look on the car. Personally I think they look quite a bit more expensive than they really are. Konig did well. :-)
I think this might be an option if I can get my Kojins sold. Its one extreme or the other, the oversteer or the ssr gtv03s...
Decisions
Old 01-21-2015, 03:02 PM   #7
venturaII
venturaII's Avatar
I was dead-set on these wheels the moment I saw them, about four months ago, and I'm really happy with how they look on the car. I'll likely be keeping these for a very long time. :-)
Yeah, they certainly get props for being affordable. Konig advertises their wheels as being 'flow formed', which is a similar process to forging. (http://flowformingtechnology.com/wha...owforming.html) It seems that it's only applied to the rim portion of the wheel and not the face, but I guess the rim is the area you need the most strength anyways.
I believe TireRack has several low pressure cast and gravity cast wheels in the same size that are lighter, so I'm still a little puzzled as to why the Konigs are so heavy for a relatively small wheel, but I guess the upside would be that the weight means added strength? Dunno. Konig also has several models in similar (or even larger) sizes that are noticably lighter, so again, a little puzzled/disappointed. The two big reasons for my interest in 16's is weight and ride quality.
At any rate, they do look nice against the black, and I bet the taller sidewall of the 16 is a big improvement over the stock 17s; I sure noticed a difference when I put my winter 16s on... The roads up here in central New England are just hideous...
Old 03-23-2015, 07:55 AM   #8
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
I've decided to buy these in a 18x9 with 42+. I can't wait to see them on my car!
SUB-FT86 is offline   Reply With Quote
Old 03-31-2015, 08:51 PM   #9
SUB-FT86
86 Member
18x9 +42
http://
Old 04-01-2015, 01:53 AM   #10
sr86
Drives: ft86 all original
I just order a set from 4wheelonline, with Nitto tires combo. Can't wait to receive and install them.
sr86 is offline   Reply With Quote
Old 04-01-2015, 09:08 AM   #11
fasteddy
Originally Posted by SUB-FT86 View Post
18x9 +42
http://
That looks really good! Are you on stock suspension? If so, how close are you to the strut in the front?
Thanks.
Pat
fasteddy is offline   Reply With Quote
Old 04-01-2015, 11:08 AM   #12
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
18x9 +42
That looks amazing!
Best color combination too.
Old 04-01-2015, 11:11 AM   #13
SUB-FT86
86 Member
Thanks.
Pat
Thanks. You need to see it in person to take in the beauty. I have a 5mm spacer that fits in between the tire and perch. Now keep in mind I'm running 225-40-18. It's pretty close but if it's too close just get a 3mm spacer. I am on stock suspension but I will get me some TRD springs soon and I'll update this thread.
Old 04-01-2015, 11:14 AM   #14
SUB-FT86
86 Member
That looks amazing!
Best color combination too. :-D
Your car was the inspiration but I wanted 18s instead. They look very aggressive and concave like from all kinds of angles. Asphalt ftw!
Wheel Directory: Impreza GT -00 16x7 +53 PBjore Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 11-09-2014 09:46 PM
Wheel Directory: SSR Type-C 16x7.5 +35 makinen Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 09-16-2014 05:02 AM
Wheel Directory: Konig Forward 16x7.0 +40 brzr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 04-30-2014 12:53 AM
Wheel Directory: MSW Type 14 16x7.0 +38 amram Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 01-20-2014 11:13 AM
Wheel Directory: WedsSport SA-90 16x7.0 +33 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-10-2013 01:27 PM
