Old 02-22-2016, 09:35 PM   #1
RickyBobby
Drives: 2013 Firestorm FR-S AT
Battery Water Level
My FR-S was manufactured on 12/12 and I don't think the battery water has been checked (if it was) since then.
For the old fucks like me here checking and adding water to a car battery is nothing new but this maybe helpful to some forum members.
If you still have the original battery it has Lower and Upper level markings on the front of it. You should fill the cells with distilled water to just below or to the bottom of the cell tubes. The bottom of the cell tubes is about at the Upper level marking. Wear rubber gloves and safety glasses.
http://www.interstatebatteries.com/m...tain-a-battery
Screw off caps.
Water levels were low, just above the lead plates.
Upper and Lower level indicators
Added water to just below the cell tube bottoms
Use a small paper cup or syringe to add water to the cells
RickyBobby is offline   Reply With Quote
The Following 9 Users Say Thank You to RickyBobby For This Useful Post:
BirdTRD (04-22-2016), FRSBRZGT86FAN (02-23-2016), Hoahao (02-24-2016), humfrz (02-23-2016), jcw99 (06-11-2017), MJones_RB (06-23-2017), Muaddib (04-30-2016), smg1138 (10-24-2017), Tcoat (04-22-2016)
Old 02-23-2016, 04:12 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I'm guessing this is one of the reasons people like to upgrade to the expensive AGM batteries from people like Optima and there Red top stuff
Old 02-23-2016, 06:30 PM   #3
Oh yes, and ....... after you get finished messing with the battery, DON'T wipe your hands on your pants ........
The Following 5 Users Say Thank You to humfrz For This Useful Post:
Dream20b (02-23-2016), jcw99 (02-24-2016), RickyBobby (02-25-2016), roddy (02-23-2016), Tcoat (04-22-2016)
Old 02-25-2016, 11:51 AM   #4
RickyBobby
Or scratch your nose or other body parts with your gloves on!!
The Following User Says Thank You to RickyBobby For This Useful Post:
humfrz (02-25-2016)
Old 03-15-2016, 05:58 PM   #5
kev60625
Drives: 2013 WRB Subaru BRZ
So I was just checking my oil level and wanted to check the battery level on my13 that was purchased fall of 2013.. I literally couldn't find a water level! So I'm guessing this means it's completely full? Thanks for your help
kev60625 is offline   Reply With Quote
Old 04-22-2016, 05:14 AM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Anyone know if you can check/top off the level on Napa brand batteries?
Old 04-22-2016, 07:11 AM   #7
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Yes you can. Follow this wikihow. http://www.wikihow.com/Check-Car-Battery-Water-Levels
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
finch1750 (04-22-2016)
Old 04-22-2016, 08:26 AM   #8
Attachment 131830
NOTE:
It is important not to fill it above the upper level marker. Like all indicated limits there is an upper marker for a reason. If you overfill you run the risk of it overflowing when put the caps back on or when the battery heats up and the acid expands. It will mess things up!
Old 06-10-2017, 01:58 PM   #9
radroach
Drives: car
I just topped of my battery, I can't believe I've put it off for so long! Had weak starts, felt like this was going to be the breaking point so ran to autozone to get a battery filler tool. Leaving autozone the car barely turned over! Drove home, added a miniscule amount of water to each hole because I didn't do any scientific measuring because i was parked on an incline. Car started up immediately after that!
The Following 3 Users Say Thank You to radroach For This Useful Post:
humfrz (06-10-2017), soulreapersteve (06-10-2017), Ultramaroon (06-11-2017)
Old 06-10-2017, 08:58 PM   #10
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Check and make sure the battery is not hot when you do this. Also check to make sure the battery is not bloated. Unscrew slowly, if you see/hear that there is some gas releasing as you unscrew, let that pressure bleed off slowly.
guybo is offline   Reply With Quote
Old 06-11-2017, 12:37 AM   #11
qqzj
Drives: MDX, Camry
What do you get by doing this? I normally can get 7 yrs out of my batteries. Will doing this extend its life to 10?
qqzj is offline   Reply With Quote
Old 06-11-2017, 01:08 AM   #12
If you don't have to add any water, you get peace of mind.
If you do have to add water, you restore the proper concentration of sulfuric acid in your electrolyte.
"Low maintenance" is not "no maintenance." Not checking it is a crap shoot. You've been lucky.
humfrz (06-11-2017), jcw99 (06-11-2017), radroach (06-12-2017)
Old 06-11-2017, 01:34 AM   #13
alan.chalkley
Drives: 4wd zooks
I keep an eye on the original battery acid level and after 4 years topped it up with distilled water.
The battery is still going strong.
Don't use tap water, it will destroy the battery!
alan.chalkley is offline   Reply With Quote
The Following User Says Thank You to alan.chalkley For This Useful Post:
Old 06-11-2017, 04:16 AM   #14
I thought the caps on most lead acid batteries had a breather hole ......
Best two way dash cam that uses car battery and it's own battery? azynneo Electronics | Audio | NAV | Infotainment 14 01-22-2016 11:23 PM
Help! Battery died, charged battery now getting all sorts of error codes! jermyzy Issues | Warranty | Recalls / TSB 12 11-25-2015 01:35 PM
Shorai Lightweight Battery and KCMachine CNC Machined Battery Tray Package KCMachine Brakes, Suspension, Chassis 111 10-08-2014 09:26 AM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 09:55 AM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
