#337 | |
Yea, @RedFRS4me sell your oft while your at it, you shouldn't be data-logging if you don't know how to read AFR You could've read steve99's thread and learned this as well: http://www.ft86club.com/forums/showt...01#post1842501 Cruise and idle around 14 Overrun –throttle closed will often read 20 Under load low to mid RPM , AFR around 12-13 Under load high RPM , AFR Mid 12 than tapering to maybe high 11 over 7000 on OFT tunes.
#338 |
Drives: '23 BRZ Limited
And even that is conservative.
If you're NA with a solid tune and ignition timing, no real reason to drop richer than 13:1 We typically ran 13.5:1 on the Sport bike tunes, yes I realize much smaller bore so easier to control the flame front. |
#339 |
Drives: 2016 Scion FR-S
Can someone pls see if there is anything wrong here?
http://www.datazap.me/u/dru670/lates...g=0&data=1-2-9 |
#340 | |
Try a 3rd gear pull from 2000rpm until redline. Sent from my Nexus 6P using Tapatalk
#341 | |
Drives: '22 BRZ
#342 | |
Not sure if I received a hardware with issue or it's software idk I really need his expertise here.
#343 |
BTW this is the new OFH tune on a 1320 uel header with drop-in filter relieved that you guys mentioned it's looking fine
#344 | |
Drives: '22 BRZ
| The Following User Says Thank You to DocWalt For This Useful Post: | Dru670 (04-15-2016) |
#345 |
Drives: 2014 BRZ sterling silver
Finally got back from Florida, I copy and pasted my MAF scale and Wayno's Quite start and rad fan edit with the new tune. So far I just drove it to the grocery store and back but I can tell it's better than it was. Seems to be more torque down low. Thanks steve99 for the reply yesterday. will some data logging this weekend.
| The Following 2 Users Say Thank You to oldgunfan For This Useful Post: | DocWalt (04-15-2016), FRSBRZGT86FAN (04-15-2016) |
#346 |
Ah okay makes sense. Hoping for the update soon. What I don't get tho is he responded to my other questions just yesterday but never to this particular issue.
#347 | |
Drives: Firestorm '13
Dude I just told you. Stoich is 14.7:1 and at idle and cruise its dropping below 13.5 and now even lower than that. Ive been running oft for awhile i know when my afr is off. Get off your high horse. This started happening after running the new tune with my OFH.
'13 Firestorm
#348 | |
#349 | |
Drives: 2015 HL FR-S
#350 | |
| Just how noticeable is OFT+OFH and stage 2 tune? | BBYZILA | Software Tuning | 58 | 03-20-2018 12:56 PM |
| OFT 2.0 Stage 1 93 Tune | MurderRider | Software Tuning | 57 | 03-21-2016 01:30 AM |
| Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 09:15 PM |
| FA20club.com Turnaround Times On Modified Tune Files | FR-S Matt | Software Tuning | 103 | 11-13-2013 02:48 PM |
| So whate does stage 3 tune do? I already have 2 | Frsexxxy | Engine, Exhaust, Transmission | 17 | 05-14-2013 07:30 AM |
