Old 04-15-2016, 10:39 PM   #337
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by RedFRS4me View Post
Running rich. Lean is higher numbers
Originally Posted by OkieSnuffBox View Post
See, now you've proven you don't know what you're talking about.
The door is over there ----->
@JB86'd @phrosty
Yea, @RedFRS4me sell your oft while your at it, you shouldn't be data-logging if you don't know how to read AFR
You could've read steve99's thread and learned this as well:
http://www.ft86club.com/forums/showt...01#post1842501
Cruise and idle around 14
Overrun –throttle closed will often read 20
Under load low to mid RPM , AFR around 12-13
Under load high RPM , AFR Mid 12 than tapering to maybe high 11 over 7000 on OFT tunes.
Old 04-15-2016, 10:51 PM   #338
OkieSnuffBox
Drives: '23 BRZ Limited
And even that is conservative.
If you're NA with a solid tune and ignition timing, no real reason to drop richer than 13:1
We typically ran 13.5:1 on the Sport bike tunes, yes I realize much smaller bore so easier to control the flame front.
Old 04-15-2016, 11:06 PM   #339
Dru670
Drives: 2016 Scion FR-S
Can someone pls see if there is anything wrong here?
http://www.datazap.me/u/dru670/lates...g=0&data=1-2-9
Dru670 is offline   Reply With Quote
Old 04-15-2016, 11:17 PM   #340
D_Thissen
D_Thissen's Avatar
Looks like you have a little bit of knock around 3500-4000rpm. I don't think it's anything to be too concerned about though. From what I have read, these motors are a bit knocky and the knock sensor is pretty sensitive.
Try a 3rd gear pull from 2000rpm until redline.
Sent from my Nexus 6P using Tapatalk
Old 04-15-2016, 11:17 PM   #341
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
Looks fine, though your OFT is reporting 0 for IAM. Gotta bug Shiv... Also, I'd like to see some WOT runs from ~2k to rev limit, but what you do have logged at WOT looks pretty much dead on
Old 04-15-2016, 11:24 PM   #342
Dru670
I've emailed shiv multiple times and it's been about a month and half regarding the IAM, MAFV readings and I have not got not one gdamn response. I might even have others data that are not being reported or reported properly Not sure if I received a hardware with issue or it's software idk I really need his expertise here.
Old 04-15-2016, 11:28 PM   #343
Dru670
BTW this is the new OFH tune on a 1320 uel header with drop-in filter relieved that you guys mentioned it's looking fine
Old 04-15-2016, 11:29 PM   #344
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I've emailed shiv multiple times regarding the IAM, MAFV readings and I have not got not one gdamn response. I might even have others data that are not being reported or reported properly Not sure if I received a hardware with issue or it's software idk I really need his expertise here.
It's because the OFT isn't set up to read the 2016 ECUs properly yet. He's been busy, but it's not really a good excuse to ignore the issue with no comment
The Following User Says Thank You to DocWalt For This Useful Post:
Dru670 (04-15-2016)
Old 04-15-2016, 11:34 PM   #345
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
Finally got back from Florida, I copy and pasted my MAF scale and Wayno's Quite start and rad fan edit with the new tune. So far I just drove it to the grocery store and back but I can tell it's better than it was. Seems to be more torque down low. Thanks steve99 for the reply yesterday. will some data logging this weekend.
oldgunfan is offline   Reply With Quote
The Following 2 Users Say Thank You to oldgunfan For This Useful Post:
DocWalt (04-15-2016), FRSBRZGT86FAN (04-15-2016)
Old 04-15-2016, 11:36 PM   #346
Dru670
Ah okay makes sense. Hoping for the update soon. What I don't get tho is he responded to my other questions just yesterday but never to this particular issue.
Old 04-15-2016, 11:42 PM   #347
RedFRS4me
RedFRS4me's Avatar
Drives: Firestorm '13
Originally Posted by FRSBRZGT86FAN View Post
@JB86'd @phrosty
Dude I just told you. Stoich is 14.7:1 and at idle and cruise its dropping below 13.5 and now even lower than that. Ive been running oft for awhile i know when my afr is off. Get off your high horse. This started happening after running the new tune with my OFH.
'13 Firestorm
RedFRS4me is offline   Reply With Quote
Old 04-15-2016, 11:50 PM   #348
Dru670
could intake temps affect it?
Old 04-16-2016, 12:17 AM   #349
HLHachiRoku
Drives: 2015 HL FR-S
The new OFH tune is adjusted to get the most performance out, its aggressive. Have you done any log yet, posted them(sorry haven't seen any if you want to point me to them ^.^? Unless you are dropping below 11.5 wot(might be lower too), or ~12.5 or around at cruising honestly i wouldn't worry about it. If its knocking I would worry, if not, enjoy the powa! haha
HLHachiRoku is offline   Reply With Quote
Old 04-16-2016, 12:38 AM   #350
oldgunfan
oldgunfan's Avatar
When you log make sure you tell your OFT to log AFR and command AFR throttle, RPM, MAF volt and so on. When your LTFT's start running below 5-ish maybe 3 do a 3rd gear pull at WOT and watch your command AFR. You want your AFR to match as close as u can.
Just how noticeable is OFT+OFH and stage 2 tune? BBYZILA Software Tuning 58 03-20-2018 12:56 PM
OFT 2.0 Stage 1 93 Tune MurderRider Software Tuning 57 03-21-2016 01:30 AM
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 TopGearSolutions Engine, Exhaust, Bolt-Ons 90 04-14-2014 09:15 PM
FA20club.com Turnaround Times On Modified Tune Files FR-S Matt Software Tuning 103 11-13-2013 02:48 PM
So whate does stage 3 tune do? I already have 2 Frsexxxy Engine, Exhaust, Transmission 17 05-14-2013 07:30 AM
